Author Topic: ADS1102CNL update SDS1102CNL EasyscopeX problem  (Read 1224 times)
Offline hlj.pycadTopic starter
  • Country: cn
« on: April 29, 2023, 07:57:02 am »
I know it's old and not that high spec, but I think it's more than enough for me as the first scope, which I brought it about $50 incl shipping.
And it come to me everythings seem fine
The system status said:
Software Version: 3.01.01.21
Hardware Version: 3-41-1.61
Product Type: ADS1102CAL
SERIES: 01020100300734
and I learn that the ATTEN ADS1102CNL is more or less the same to Sigilent SDS1102CNL, and it can be SDS1102CML if I solder a SRAM chip on it, it will has 2Mpts long memory function, nice!
So the next thing I did was update it to newer SDS1102CNL firmware,
From the below link, I learn that ADS1102CAL can use EasyScopeX or WaveStudio after flash the SDS1102CNL firmware...
https://eevblog.com/forum/testgear/firmware-update-for-atten-ads1102cal-oscilloscope/
daro-1
I've got the ATTEN ADS 1102CAL that I brought secondhand from a local ham radio fest for $275 and I was warned about some of the original firmware issues as it had vers 301.01.01.213 installed when I got it and then I decided to upgrade the firmware based on what I was reading on this forum post and a similar one on this site and upgraded mine to Siglent SDS1102CNL vers 5.01.02.29 which works a treat when you follow the instructions of flashing the firmware first then reboot and then cfg file and reboot again and then do self calibration of the unit, so mine now is basically a Siglent SDS1102CNL and I can't use the original ATTEN ADS 2202CAL USB drivers as it has also upgraded USB flash EEPROM and now identifies itself as an SDS1102CNL when it's plugged into a Windows 7 or 10 based PC, is there anyway I can use this DSO on a PC because there is no known USB drivers for the SDS1102CNL to be able to use this with EasyScope vers 3?
Thanks, I've got it all going under Windows 10 now.  ;D
UPDATE: The latest firmware for the Siglent SDS1102CNL is ver 5.01.02.32 and I found it on here:
http://www.siglentamerica.com/USA_website_2014/Firmware&Software/firmware/SDS1000CNL_SSP_V100R005B01D02P32%20(3).rar
Also I don't think too highly of  EasyScopeX as the interface looks very cheap so I opted to use the Teledyne LeCroy version which they call WaveStudio which looks more polished and professional then EasyScopeX and works quite well with my DSO.
Download WaveStudio and NI VISA downloader from here:
https://drive.google.com/drive/folders/0Bx1eYdyyMol2ZHNsOXpTTTR3SEE?usp=sharing
here is another flash ADS1102CNL to SDS1102CNL and use EasyScopeX and WaveStudio without any problem
https://www.eevblog.com/forum/testgear/atten-ads1102cnl/
I think I installed the NI-Visa driver properly,  I can see a device in devices manager, and NI-Max can detect the scope and send command, but the only command it responses is "*IDN?". EasyScopeX list the scope at "add device", but it will prompt "fail to connect to the device".
And I notice one things, after they flashed the SDS1102CNL firmware, they scope's product type changed to SDS1102CAL and mine is not.
At first, it's no "type" at all, and the power on splash is totally white, then I flash a "Atten_CAL.cfg" download from the forum, both power on "ATTEN" splash and the product type in system status came back, ADS1102 still. So do I need to flash a "SDS1102CNL.cfg" in order to let EasyScopeX recognize my machine?
« Last Edit: April 29, 2023, 08:01:30 am by hlj.pycad »
I am from China, so of course I speak chinglish
Offline tv84
  • Country: pt
Re: ADS1102CNL update SDS1102CNL EasyscopeX problem
« Reply #1 on: April 29, 2023, 08:31:57 am »
Possibly.  :-//
Try this file.
The following users thanked this post: tautech, hlj.pycad
  • Country: cn
« Reply #2 on: April 29, 2023, 08:42:46 am »
Thanks. I've view a lot of related thread and almost all of their problem is answer by you, so is mine!
Problem sovled!
I've ordered the missing SRAM chip to have it became SDS1102CML, so I guess I will need a SDS1102CML.cfg as well then?
Offline tv84
  • Country: pt
« Reply #3 on: April 29, 2023, 10:31:33 am »
Problem sovled!
You did the homework so a little push was in order. Here is the CML cfg. Beware, IIRC CNL lets you go to 200MHz and CML only does 150MHz. Don't know if that is relevant for you.
« Last Edit: April 29, 2023, 10:33:31 am by tv84 »
The following users thanked this post: hlj.pycad
  • Country: cn
« Reply #4 on: May 07, 2023, 04:37:03 pm »
I soldered the 2M sram IC to the PCB with quite some effort... but everything seem fine, I have my sds1102cml now. Thank you for everything, the patch firmware and all the kind replies. :-+
Offline tv84
  • Country: pt
« Reply #5 on: May 07, 2023, 04:44:27 pm »
 :clap: :-+
  • Country: cn
« Reply #6 on: May 08, 2023, 07:45:59 am »
I do a litte test of the save bit depth of the new 2M SRAM ic, then find out that with or without Long Memory mode, dual Channels saving points is full function, in another world, in any time div, the captured waveform length will equal:   ( 2M or 40K ) = Sampling Rate * 2 * Length
We know if only 1 channel is active, either the sampling rate is double, or the capture waveform lenght is double, but, that is not the case to my scope, in fact most of the time div setting, only half memory is used... I list the result in a excel sheet:
Even an old Siglent promotion PPT show tell you if only 1 channel is used, it use all the 2Mpts saving, but my test show is not in time div 500us.
So my question is: do I miss some tweaking to allow 1 channel use all memory in more time div? Or it's a limitation of ADS1102CAL --> SDS1152CML, or it's just false promotion PPT, the real SDS1152CML work exactly like my hacked ADS1102CAL?
« Last Edit: May 08, 2023, 07:48:51 am by hlj.pycad »
