Author Topic: Advantest R3131 extension card  (Read 532 times)
Offline Renaud F5ZRTopic starter
« on: July 21, 2024, 06:40:56 am »
I bought some month ago a faulty and cheap R3131.
I read a lot here about them and realised that I would need an extension card to fix it.
I choose to build one with Veroboard. The base plate I cut in 1.5 mm aluminium on which I bolted the 96 pins Eurocard connectors.
Three Veroboard levels are needed to fill the 96 points.
First level:
To push the next Vero inside I had to remove the little brass posts on one side.
The male wrapping connectors were available so I used them but they were less convenient to solder than the female ones I bought.
Three populated levels:
Of course a careful control is needed before placing the next level.
I added another aluminium plate over the lot with a bending to help insertion. It also avoid to stress the connectors and the solderings.
Paléoélectronicien, paléomécanicien.
Offline nctnico
Re: Advantest R3131 extension card
« Reply #1 on: July 21, 2024, 07:48:59 am »
That is quite a bit of work. But there is an alternative: I typically solve this issue by soldering wires to the board to connect to a scope or any other kind of test equipment. The wires extend beyond the casing. This way cooling of a module isn't impacted.
« Reply #2 on: July 21, 2024, 08:11:58 am »
Thanks for replying.
It is! But I have a fine mechanical workshop and I like this kind of work.
As I read a lot here about the R3131 I knew that way of doing. As I don't know where this will drive me I made that one.
It could be overkill of course yes! Then it took me only one morning work.
I don't understand your remark about the cooling. I believe the card outside will be naturally cooled. And I could always add some ventilation.
Renaud
Offline coromonadalix
« Reply #3 on: July 21, 2024, 08:17:49 am »
good work   :-+
« Reply #4 on: July 21, 2024, 09:11:37 am »
I've used PC IDE ribbon cable between plugs and sockets......
Just be sure to double/treble up the power rails.....
« Reply #5 on: July 21, 2024, 09:14:26 am »
Yes, I plan to use the free lateral tracks to do just that... once I determine which are the ground and power tracks!
Thanks
Renaud
Offline nctnico
« Reply #6 on: July 21, 2024, 09:32:06 am »
In this case cooling is likely not critical but there are other cases where cooling is critical. I just wanted to propose a different way to tackle the problem.
« Reply #7 on: July 21, 2024, 11:20:09 am »
 Ok, agreed.
And thanks to Coromonadalix I missed before.
« Reply #8 on: July 21, 2024, 11:27:17 am »
Oh, and I just bought a R3361 and wonder if my card will fit?
« Reply #9 on: October 12, 2024, 07:42:01 am »
It doesn't! The R3361 was conceived about 10 years above (1989 I believe) and it is very differently built.
I will now try to fix the unlocked YTO LO status I discovered. https://groups.io/g/advantestinstrument/topic/108915748#msg2160
Of course I would be very grateful if you have any knowledge of his design.
Best
Renaud
