Author Topic: Advice for a Short circuit detector  (Read 2433 times)
Offline zanzeooTopic starter
« on: January 05, 2023, 09:39:11 pm »
Hello
I have a trouble with a 12 layer board, Vcc is shorted somewhere with GND.
In the past i used a TONEOHM 950 which is very useful in that case. But so much expensive ( 10K$ )
I thinking to buy or make a Short circuit  detector more simple or less expensive.
Do you have any recommandations
Thx
Offline DL2XY
Re: Advice for a Short circuit detector
« Reply #1 on: January 05, 2023, 09:54:01 pm »
Thermal Imager ?!
« Reply #2 on: January 05, 2023, 09:55:49 pm »
it does not work well with small current... :-[
Offline Gyro
« Reply #3 on: January 05, 2023, 10:04:38 pm »
You don't say whether the PCB is populated or not, but assuming not.
Set a bench PSU in current current limit mode to as high a current as you sensibly can (somewhere around the expected circuit current consumption or higher) and put it across VCC and GND. Then go around with a DMM (hopefully a 4 1/2 or 5 1/2 digit) on its most sensitive mV range and work across the board, starting at the inputs and measure the voltage between VCC and GND points. The lower the mV (maybe 10s of uV) reading, the closer you are to the short. This can actually be a pretty sensitive method.
If the PCB is populated, it's pretty much the same as above, but set the PSU to less than the normal VCC rail voltage before going into current limit mode.
Best Regards, Chris
The following users thanked this post: MegaVolt
« Reply #4 on: January 05, 2023, 10:07:42 pm »
Yes the board is populated
i found a video of a TONEOHM 950 :
Offline Gyro
« Reply #5 on: January 05, 2023, 10:19:10 pm »
That's easier then. Assuming the PCB was bare board tested (who wouldn't on a 12 layer), you're looking for a component, probably a decoupling cap. The current limit and measure method is easier when you have a specific number of parts to go around rather than having to look up specific test points. Turn off the PSU before clearing the fault to avoid any PSU overshoot or inductive kick issues.
Best Regards, Chris
The following users thanked this post: zanzeoo
Offline kripton2035
Offline BillyO
« Reply #7 on: January 05, 2023, 11:31:40 pm »
Do you have access to a meter that will resolve down to 1 milli-Ohm?   Most 5.5 digit meters will.  That should be plenty capable of finding shorts between voltage planes.
« Last Edit: January 05, 2023, 11:33:12 pm by BillyO »
The following users thanked this post: MegaVolt, djadeski
« Reply #8 on: January 06, 2023, 06:48:54 am »
Yes i have a milliohmeter and tried to find the lowest "resistor" between VCC and GND , but found almost the same value everywhere. I suspecting a bad via between plane ( this board came just from production )
I will try the method of Gyro. But i would like to invest in a short detector for my compagny , so if you have an advice for a good equipement it's fine
Thx u
« Reply #9 on: January 06, 2023, 06:53:12 am »
I'have already removed a lot of caps , the plane that is shorted has almost no more component on it ...just some IC maybe a small part of solder stuck under ?
Offline kripton2035
« Reply #11 on: January 06, 2023, 10:40:45 am »
you need 0.1mΩ resolution to find a short with enough spatial precision.
I assume you did but are you using a 4 wires probes ?
it's strange you don't find any differences with a milliohm meter.
Offline 807
« Reply #12 on: January 06, 2023, 01:49:13 pm »
If you have an LM317 handy, then here's a cheap way of doing it...
Offline artag
« Reply #13 on: May 04, 2023, 09:31:11 am »
I was looking for a Toneohm. There are some on ebay but they're expensive - £3-400.
But I've found a few Omnitest Hy Trak for 1/10 of that (eg https://www.ebay.co.uk/itm/225274209822).
They appear to do nominally the same thing : measure milliohms with a display and a tracking audio tone. Are they equivalent ? I've read  that Toneohm have some special technique for finding groundplane shorts but that might apply to only some models, and I don't know how good it is.
Offline Miti
« Reply #14 on: May 04, 2023, 02:29:59 pm »
How about this short finder project?
I have one from jdobry and the troubleshooting technicians love it.
https://www.eevblog.com/forum/testgear/finding-short-on-motherboards-with-a-shorty-(with-display)/
Fear does not stop death, it stops life.
Offline artag
« Reply #15 on: May 04, 2023, 04:35:10 pm »
Yes, there are plenty of options to build my own.
But what I wanted to know was why the Toneohms are apparently so attractive, even against other reputable commercial options.
