Author Topic: Advice on buying a bench DC PSU  (Read 1986 times)
Offline bsodmike
  • Country: lk
Re: Advice on buying a bench DC PSU
« Reply #25 on: March 04, 2020, 05:03:59 pm »
I checked the manual for E36313A to double check if this could be run as a bipolar output (i.e. if you wanted say generate +/-15v, by connecting two terminals together. (Page 3 here shows this config in the datasheet for the BK Precision model 9130B) https://bkpmedia.s3.amazonaws.com/downloads/datasheets/en-us/9130B_Series_datasheet.pdf
Have you been able to run your Keysight this way? Thanks!
You can do that with the E36313A too. It is a basic feature of every dual channel power supply. In tracking mode you can adjust both positive and negative voltage in one go.
I thought so too, it didn't seem like that configuration was anything special; odd that BK Precision would try to sell you on that though!  On the keysight, the auto-serial mode with Chan 2 + 3 seems pretty neat, for an extended range to 50vdc.  This going to run me $2,860 but I'm throwing in the towel and going with the keysight.  Thanks!
Offline nctnico
« Reply #26 on: March 04, 2020, 05:42:24 pm »
IMHO the GW Instek GPP-4323 offers good value for money while avoiding the short comings of the Siglent (no keypad) and Rigol (channels not fully isolated).
Hey, nice one, only i see no youtube movies, is it new ?
There is a good review here:
https://www.electrobob.com/gpp-4323-power-supply-review/
