Author Topic: Old Dick Smith Multimeter?  (Read 4060 times)
Offline numloxxTopic starter
« on: May 07, 2016, 04:06:05 am »
Hi all,
Since I bought the EEVBLOG BM235 DMM, I thought I would get rid of some of my older DMM's that I don't use anymore, and I found one that I believe it from Dick Smith.
Product code is Q1051 and there is what I think is a date code 02/99.
Planning to send it in to Dave later on.
Re: Old Dick Smith Multimeter?
« Reply #1 on: May 07, 2016, 04:52:26 am »
And into the bin it will go.  >:D
« Reply #2 on: May 07, 2016, 07:00:34 am »
Ah good point. No worries. I'll wait until I have some other more interesting gear to send him. Thank you :)
Offline crispy_tofu
« Reply #3 on: May 07, 2016, 07:46:29 am »
Looks like one of those DT-830 multimeters, honestly quite meh...  ;)
Online Fungus
« Reply #4 on: May 07, 2016, 10:50:41 am »
I was going to say the same, did Uni-T clone the 830?
They're quite different on the inside though.
Offline 001
  • Country: aq
« Reply #5 on: August 29, 2018, 02:27:06 pm »
Ohho!
It looks MORE ROBUST then noname 830 meters!
DIP components and MOV for input protection and additional voltage reference  is not common for cheap DMMs
Compare it with nowday noname https://www.eevblog.com/forum/testgear/dt-838-digital-multimeter-just-curious/
Looks like good  piece of nostalgy of 90th )))))))
« Last Edit: August 29, 2018, 02:33:15 pm by 001 »
Offline jeroen79
« Reply #6 on: August 29, 2018, 06:57:33 pm »
Or the DT-830 meters are a clone of this one.
I wonder how much different it is.
I can see the same overall structure but with more through-hole stuff and the ICL7106 chip-under-a-blob on a separate PCB.
If you look around a bit on the internet you can sorta see the evolution of this meter from cheap to cheaper.
For example:
https://hartgeloetet.blogspot.com/2014/09/messgerat-dt-830b-mal-3.html
DT-830 reviews tend to rather negative but I would be interested in an overview of it's history and lineage.
« Last Edit: August 29, 2018, 06:59:41 pm by jeroen79 »
The following users thanked this post: 001
