Hi all,
I'm exploring the options for a Spectrum analyser to add to my bench that currently has mainly Keysight and Rhode & Schwarz equipment.
My use-case to start is for general use on the bench, and progress onto more advance cases as I start to tweak and configure antenna designs on PCB, all under the 3GHz spectrum. VNA/Smith chart analysis would be helpful in that regard.
Other applications would be working with amplifier circuits, THD measurements etc.
Options:
One that peaked my interest is this FPC1500 model from R&S at Farnell:
- FPC-COM2 is a bundle of FPC1500 spectrum analyser with other options (Tracking generator, VNA, signal generator, preamplifier, modulation analysis, receiver mode, advanced measurements).
- Feature set: FPC1500 spectrum analyzer, Tracking generator, VNA, Signal generator, preamplifier, Modulation analysis, Receiver mode, Advanced measurements, Power cable, USB cable for connection to PC
https://export.farnell.com/rohde-schwarz/fpc-com2/spectrum-analyzer-5khz-to-3ghz/dp/3052020?st=rhode%20&%20schwarz%20spectrum%20analyserIt has most, if not all, the extra features and a max 3Ghz freq. range. This may be limiting to some, but this does keep the price down.
Alternatively, here's a handheld R&S unit sold on eBay:
https://www.ebay.co.uk/itm/324716919054Should I go for a new unit or consider the used unit?
Thanks, M.
