When working on my last project involving I2C comm, and with both hardware and software bugs involved, I have finally come to the point where I MUST buy a better scope. Currently I have a Tektronix TDS3034B and it is almost useless for debugging I2C.
With only 10Kpts of memory (!), I was able to only see one I2C byte transfer. And each transfer being apart about 20ms, there was no way I could display multiple byte transfers. One thing I was able to do was to use B trigger with edge count to position myself to a certain I2C clock and view what's happening around there. But this didn't work when I needed to stop the scope at the problem point. Once the scope is stopped, you only have the measly 10Kpts to look around.
So, after doing some extensive research, I have narrowed down my list to the 350MHz DSOX4034A and the 600MHz DSO9064A from Agilent.
I can get the 350 MHz 4034A for the price of the 200MHz 4034A, but I need to buy the I2C, SPI, RS232, and UART options, resulting in a price of around $11000.
The 9064A comes with a free 500Mpts memory upgrade and a free software option (I2C, SPI, RS232, UART), resulting in a price of $17000.
Price wise, there is a $6000 difference, but feature wise, the 9000 seems light years ahead:
350 MHz ve 600 MHz
4Mpts vs 500Mpts memory
5Gsps vs 20Gsps sampling rate
2 Zone trig vs 16 Zone trig
1000 segments vs 131072 segments
But, the 4000x seems to have a higher waveform update rate, 1000000 vs 250000.
Also, the 4000x comes with nice 700MHz passive probes, whereas the 9000 comes with 500MHz ones. Not really important, because the bandwiths I'm looking at makes this irrelevant, but still a difference.
Another scary point, 9000 is running Windows and even has an Antivirus software in it !!!
Also, the 9000 serial trigger support seems to be better than the 4000. The max speed for UART and SPI are higher with the 9000. Also, the collected data can be saved to a file and examined on another PC. The 4000 doesn't seem to have this capability...
So these are the differences that I was able to come up with. I would love to hear your opinions about which one to choose. Both scopes will really be a big blow to my budged, but it will be much worse if I buy a 4000, only to find out that I should have bought the 9000.
