Poll
No Green Trace on Oscilloscope when turn on.
Please Help
0 (0%)
Not Showing green trace
0 (0%)
Total Members Voted: 0
Author Topic: Dick smith Q1803 Oscilloscope  (Read 884 times)
Offline samsonTopic starter
« on: June 04, 2022, 05:35:58 am »
Hi, I have a Dick Smith Q1803 Oscilloscope and when I turn it on there is no green trace on the tube.
Triggering is working but no display. It was working only for a while and know it is blank tube.
The tube lights up on the back and that is about it.
Any help please.
« Last Edit: June 09, 2022, 05:08:26 am by samson »
Offline wilfred
Re: Dick smith Q1803 Oscilloscope
« Reply #1 on: June 04, 2022, 06:08:09 am »
You've checked the intensity is not on minimum? And adjusted the vertical position to make sure the trace hasn't moved beyond the top or bottom of the screen?
Also set the time/div to something that will give a line rather than a moving dot.
I did find this which might offer a few things to try.
https://www.austech.info/showthread.php/89126-DSE-Q1803-10Mhz-Oscilloscope-Repair
Good luck with it.
