Author Topic: Hacking the OWON SDS7102 to SDS8102 or better  (Read 5944 times)
Offline sbeukers
« on: January 22, 2013, 03:29:07 pm »
Hi all,
I was just poking around in the firmware of the owon SDS7102 and i found something interesting.
First manualy unpack the file by opening it with 7-zip (winrar etc doesn't work)
Then go to the following directory
....\$_OUTDIR\SDS7102
you will find 5 file in there
OS_H2
OS_H4
OS_H5
OS_H6
OS_H8
Open those files with 7-zip and find
help
me
os
readme.txt
In readme.txt there is a line that says help=xxxx serial number i guess.
The files in the folder \SDS8102 and others are just slightly different.
Well I thought that maybe... just maybe we can take the firmware from the \SDS8102\OS_Hx and modify the readme.txt then put it in \SDS7102\ and pack it back to OS_Hx
Is there a chance that the number after OS_H? stands for a certain hardware revision.
Anyone brave enough to try this?
grt Sjoerd
Offline rf-loop
Re: Hacking the OWON SDS7102 to SDS8102 or better
« Reply #1 on: January 22, 2013, 07:06:00 pm »
No way!
HW is really different.
SDS7102 use ADC08D500 clone
SDS8102 and 8202 use ADC08D1000 clone made by RuiFeng. (propably same as Rigol DS2000 serie.)[/b]
Also new SDS7102 versions have (typical) BW -3dB point between 170-220MHz depending of voltage range if you have seen tests. It is more than enough for realtime 1GSa/2x500MSa/s scope.
Then also 7102 have full speed memory up to 2x10Mpoints. With one channel it can capture 1GSa/s to 10M sampling buffer. And with 2 channel in use it can 2 x 500MSa/s to both channels own 10Mpoints memory.
If go to 8xxx models all memory over 10k is same speed as in 7102. 8xxx do not give anything more.
If practice and theory is not equal it tells that used application of theory is wrong or the theory itself is wrong.
Huawei HarmonyOS 2.0  | 6G | Arcfox α-S
Offline sbeukers
« Reply #2 on: January 22, 2013, 10:26:55 pm »
How do you know that the hardware is really different?
I really doubt that.
The Rigols were the same, why not the Owons?
*edit* I am really happy with the bandwidth of my scope but hacking stuff is always fun.
« Last Edit: January 22, 2013, 10:40:37 pm by sbeukers »
Offline Matje
« Reply #3 on: January 22, 2013, 11:03:59 pm »
Judging from his signature I would guess he sells this stuff. ;-)
