Author Topic: Agilent 34410A without LXI  (Read 981 times)
Offline StefikMichalTopic starter
  • Country: sk
« on: May 08, 2024, 10:27:36 pm »
Hello, some time ago, I bought an Agilent 34410A from an auction site. I was just playing with it, scrolling through the menus, measuring some values, and saw some weird thing. Although it has an RJ-45 LAN connector, the LXI marking above it is whithened, and there is also no LXI logo on the front panel. You can see that in the attached pictures. I haven't tested the network functionality yet, but from my judging, it's some kind of early model (because all the other 34410As I've ever seen had the LXI logo). What does that mean for me from the perspective of network capabilities as a hobbyist?
Online coromonadalix
Re: Agilent 34410A without LXI
« Reply #1 on: May 08, 2024, 10:50:52 pm »
fw version ?   there are fw upgrades available  as for  LXi
normally  it should  answer scpi commands  thru lan or usb, verify in the menu if they are active
install R&S visa package   you have 32bit and 64 bit tool in them to send commands  ...
  • Country: sk
« Reply #2 on: May 08, 2024, 10:55:51 pm »
Thanks for reply. I don't remember FW version, will check that when I got home.
