Author Topic: I don't need no stinking calibration  (Read 6767 times)
Offline staxquadTopic starter
  • Eye Candy
« on: June 13, 2013, 04:30:52 am »
22*C, warm up > 8 hours
Prime Technology - General Resistance DAS-47AL, 7 digit 0 to 1V, 0 to 10V Kelvin Varley Divider
resolution 0.1 micro volt
accuracy 0.0015%
T.C. typical 0.7ppm/*C, max 1.5ppm/*C
can select either HP 3478A, connect the  +10V reference and it will not twitch for hours, steady +10.0000VDC
my Fluke 87III shows +9.996VDC
shielded Kelvin Varley Divider at the top and reference voltage adjust shielded box at the bottom
amplifier zero adjust at the top left corner
shielded transformer box
« Last Edit: June 13, 2013, 05:23:29 am by staxquad »
"TEPCO Fukushima you long time"
You say Vegemite, I say Yosemite. (Ve-gem-mit-tee, Yo-zey-might)
"For starters : you're Canadian...."
Offline ftransform
Re: I don't need no stinking calibration
« Reply #1 on: June 15, 2013, 11:06:04 am »
are you working on an moth fart detector?
  • Eye Candy
« Reply #2 on: June 15, 2013, 03:41:46 pm »
edit:  I'm still trying to figure out what you said.  So far, either you are saying the unit is old, or it's sensitive.  For old, I hope the unit carries on; for being sensitive, right now I only have confidence in 6 of the digits which only covers my meters, nothing more.   Hope to eventually check the unit on a calibrated meter to validate the 7 digits.
you don't eat pudding?
if you don't like old, you can still get it new, only $8570 (most likely updated circuitry), also constant current but only 6 digits
http://www.newark.com/shurite-meters/das-56a/das-56a-dial-a-source-general-resistance/dp/73K4753
http://www.primetechnology.com/PartsDetails.aspx?PartsId=144&Parentid=59&ParentType=C
http://www.primetechnology.com/cp/images/PartsDocument/83658.pdf
newer versions a little too rich for my blood at $500 used on ebay
« Last Edit: June 16, 2013, 12:34:11 am by staxquad »
Offline codeboy2k
« Reply #3 on: June 15, 2013, 11:16:51 pm »
ok.. now you done it... you made me want to build one  :-+
  • Eye Candy
« Reply #4 on: June 15, 2013, 11:59:06 pm »
the pdfs then
« Last Edit: July 27, 2013, 04:33:46 am by staxquad »
Offline edavid
« Reply #5 on: June 16, 2013, 12:38:03 am »
Does it buzz as much as my DAS-56A's do?  I can't leave them on, they drive me nuts.
Offline ltz2000
« Reply #6 on: December 02, 2015, 05:59:16 pm »
Last week I helped a friend who also has a loud Dial-A-Source.
There is no cure for the sound. The transformer key design parameter seems to be the low capacitive coupling and the quietness comes far behind.
Doesn't surprise me at all. A real engineers daydream and assemblers nightmare. A number of small printed circuit boards here and there and maximum amount of wire between them. Full of tiny custom metal boxes and mounting brackets needed to solve the design flaws made in the earlier stage of the process.
Most likely not. The one that I tried to cure was built in the late 90s and looks exactly the same. Most of the parts from the 90s, modern looking solder masks etc. But here and there components, like operational amplifiers and transistors, from the early 80s or even late 70s.
The electrical safety was horrible. Doll house wire used for the internal mains connections. Which were of course tied together with the sensitive low voltage DC wiring. A live turret pin was so close to the metal enclosure wall that I needed an ohmmeter to see if it makes a connection or not. The gap was too tight for a piece of paper.
Online Vgkid
« Reply #7 on: December 02, 2015, 06:22:23 pm »
Show us the KVD already, that is what we really want to see.
The following users thanked this post: Netion
Offline ltz2000
« Reply #8 on: December 02, 2015, 06:43:19 pm »
Nothing special. Thumb wheel switches, ten resistors soldered on each of them. The resistors are good stuff *, General Resistance brand of course.
http://www.primetechnology.com/cp/images/PartsDocument/163323.pdf
* EDIT: If you don't ask Mr. Pettis.
« Last Edit: December 02, 2015, 06:49:50 pm by ltz2000 »
Offline mtdoc
« Reply #9 on: December 02, 2015, 06:44:25 pm »
Very nice.  Looks like there's a DAS-46 on ebay right now for $149.  No DAS-47 though.
We don't need no stinking calibration - Ha!  I can't resist:
Offline fivefish
« Reply #10 on: December 02, 2015, 06:53:16 pm »
OP: Nice.
Here's another one.
