Hi everyone,
got some issues with my RIGOL DS1054Z
so I wanted to share it with you and maybe someone can help out.
So this is the case, I am using Buspirate to generate SPI signal.
Buspirate configuration:
Mode: SPI
Speed: 1 MHZ
Clock polarity: Idle low *default
Output clock edge: Activate to idle *default
Input sample phase: Middle *default
CS: /CS *default
Output type: Normal (H=3.3V, L=GND)And after setting up my scope (which you can see from the pictures) I send [ 0x20 ] to SPI.
Scope has SPI decoder ON and crazy thing is that after decoding it shows decoded number as 00000000
Just to be sure Buspirate works I connected it to my Saleae Logic analyzer and it showed all was ok, everything that I've sent logic analyzer showed as ok.
So this is how my scope looks like...
Thanks in advance!!
