Yes, there is a third resistor R3 near the other two that connects the outer conductor of the beaded coax to ground. I believe it is directly beneath the coax, although some designs (the newer Keysight patent and the Anritsu design) place it on the same plane as R1, R2 but on the opposite side of the coax landing pad. It should be about 9.417 ohms.
