Author Topic: Agilent E7495 linux root account  (Read 88316 times)
Offline Urs42
« on: February 16, 2015, 04:49:55 pm »
I found out i'ts running linux on an ARM CPU, i can't have any Linux Box without root access, so i did some password cracking:
User: guest
Pass: noname
User: root
Pass: wh1skers
You can log in to it with telnet, it has many serial ports, i suspect that most of them are used to communicate with the Spectrum Analyzer Part. The Powerup Config of the Device is stored in /flash/egServer/registry/Powerup/ if you want to change some default settings. There is an ftp client on the device, if you run a ftp server on your computer, you can use it to copy files from and to the device. Binaries from debian woody will work on the Device.
Offline jwm_
    • Not A Number
Re: Agilent E7495 linux root account
« Reply #1 on: February 17, 2015, 01:38:39 pm »
That is great, time to email them and ask for the source code. Depending on their mood, we may get the source to drivers for their hardware in it.
Offline Wuerstchenhund
« Reply #2 on: February 17, 2015, 05:52:09 pm »
Nice find! Yes, the E7495 is a nice device, and great for hacking or expanding its capabilities, probably more so than most other VSAs in that price class.
You should be able to get the source code for the OSS stuff from Keysight but I believe the hardware drivers are closed source binaries.
But hey, there's a lot that could potentially be done with that thing. Maybe someone can fix the sometimes temperamental screen capture function, or even modify it so that it works with USB drives as well.
Offline Urs42
« Reply #3 on: February 17, 2015, 07:14:49 pm »
There is no USB Storage Support in the kernel running on the device, and the module is also missing :-(
The kernel Version that is running on the device is available on the internet, the .config from the kernel would help with building a matching module, i'm not sure if it's possible to build it without the .config.
They are Obligated to give us the source, because of the GPL...
I think that the mounting and unounting of the cf card is done with shell scripts, it should be possible to switch the scripts to USB.
The licensing of options is done with the flexlm license manager, i have no idea how secure this thing is. There are many Options that don't need additional hardware. I think it might be possible to copy licenses from one device to another.
Offline jwm_
    • Not A Number
« Reply #4 on: February 17, 2015, 07:17:51 pm »
If it does just communicate with its devices over serial links, it would be easy to interpose a driver to capture and sniff the data. also possible for usb, but a bit trickier if we can't load a kernel module.
can you post its full boot logs, lspci and lsusb?
I was thinking of picking up one of those for use as a general spectrum analyzer, how hampered will i be that it was designed for a specific purpose? Will i always be fighting the UI that keeps on wanting me to repair base stations?
Offline Lukas
    • carrotIndustries.net
« Reply #5 on: February 17, 2015, 09:24:06 pm »
Btw, you can download a firmware upgrade from Keysight and reverse engineer as you like.
Strangely, this device runs some embedded sort of java! xkcd: http://xkcd.com/801/
They took advantage of that, so the PC software they offer simply is the same one that runs on the device, with the difference that it doesn't connect to localhost.
You're wondering why this thing takes so long to boot? This may be part of the answer:
# There's some defect in the GUI that results in
# intermittent hangs on startup (very rare, but some
# boxes can hit it regularly). This delay is a workaround
# to avoid them. When the root cause is found and fixed
# this delay can be removed.
sleep 16
« Last Edit: February 17, 2015, 09:25:40 pm by Lukas »
« Reply #6 on: February 17, 2015, 09:28:43 pm »
Not hampered at all. It's a normal Vector SA which covers from 500kHz to 2.5GHz (E7495A)/2.7GHz (E7495B) all the way from zero span to full span.
Also no need to "fight" the menu. You can ignore the BTS specific software and selectr "Spectrum Analyzer" directly in the main menu.
I'm working on a review of my E7495B, with some luck I might finish it this weekend.
« Last Edit: February 17, 2015, 09:30:21 pm by Wuerstchenhund »
Offline Urs42
« Reply #7 on: February 18, 2015, 05:30:14 am »
The GUI Part of the Software is java, there is also a server part that is not written in Java. Some parts of the Software are missing in the Firmware update.
Some details from a running system:
[root@Linux /root]$dmesg
Linux version 2.4.19-rmk7-ads5 (sreynard@elgato2.soco.agilent.com) (gcc version 2.95.2 19991024 (release)) #30 Wed Apr 28 13:36:58 UTC 2004
CPU: StrongARM-1110 revision 9
Machine: ADS GraphicsMaster
Warning: bad configuration page, trying to continue
On node 0 totalpages: 8192
zone(0): 256 pages.
zone(1): 7936 pages.
zone(2): 0 pages.
On node 1 totalpages: 8192
zone(0): 256 pages.
zone(2): 0 pages.
Kernel command line: console=tty1 mem=32m@0xC0000000 mem=32m@0xC8000000 rw ramdisk_size=8192 initrd=0xC0800000,3m root=/dev/ram sa1100_pcmcia_opts=sock:0(speed_io:100,fast_mode),sock:1(speed_io:80)
Relocating machine vectors to 0xffff0000
Console: colour dummy device 80x30
Calibrating delay loop... 137.21 BogoMIPS
Memory: 32MB 32MB = 64MB total
Memory: 59552KB available (1716K code, 360K data, 88K init)
Dentry cache hash table entries: 8192 (order: 4, 65536 bytes)
Inode cache hash table entries: 4096 (order: 3, 32768 bytes)
Mount-cache hash table entries: 1024 (order: 1, 8192 bytes)
Buffer-cache hash table entries: 4096 (order: 2, 16384 bytes)
Page-cache hash table entries: 16384 (order: 4, 65536 bytes)
POSIX conformance testing by UNIFIX
Linux NET4.0 for Linux 2.4
Based upon Swansea University Computer Society NET3.039
Initializing RT netlink socket
sa1111_pcibuf: initializing SA-1111 DMA workaround
SA1111 Microprocessor Companion Chip: silicon revision 1, metal revision 1
Starting kswapd
JFFS version 1.0, (C) 1999, 2000  Axis Communications AB
JFFS2 version 2.1. (C) 2001 Red Hat, Inc., designed by Axis Communications AB.
ttyS0 at I/O 0xf0100000 (irq = 50) is a 16550A
ttyS1 at I/O 0xf0120000 (irq = 51) is a 16550A
ttyS2 at I/O 0xf0140000 (irq = 52) is a 16550A
ttyS3 at I/O 0xf0160000 (irq = 54) is a 16550A
ttySA0 at MEM 0x80050000 (irq = 17) is a SA1100
ttySA1 at MEM 0x80010000 (irq = 15) is a SA1100
ttySA2 at MEM 0x80030000 (irq = 16) is a SA1100
Console: switching to colour frame buffer device 80x30
initialize_kbd: Keyboard reset failed, no ACK
Keyboard timed out[1]
keyboard: Timeout - AT keyboard not present?
pty: 256 Unix98 ptys configured
UCB1200 generic module installed
ucb1200 touch screen driver initialized
ucb1200 adc driver initialized
UCB1200 audio driver version 2.2 initialized
UCB1200 audio driver Click-Avoid patch: TT <tthaele@papenmeier.de>
UCB1200 Mixer driver version 0.1 initialized. TT <tthaele@papenmeier.de>
smartio driver initialized. version 1.10, date:28-Jun-2002
SmartIO ID     : 0x5002
Device Version : 6(0x36)
Device Type    : 0x8535
SA1100 Real Time Clock driver v1.00
Uniform Multi-Platform E-IDE driver Revision: 6.31
ide: Assuming 50MHz system bus speed for PIO modes; override with idebus=xx
smc9194.c:v0.14 12/15/00 by Erik Stahlman (erik@vt.edu)
eth0: SMC91C96(r:9) at 0xf00e0000 IRQ:58 INTF:TP MEM:6144b ADDR: 00:60:0c:00:4c:5f
RAMDISK driver initialized: 16 RAM disks of 8192K size 1024 blocksize
loop: loaded (max 8 devices)
PPP generic driver version 2.4.2
Sound: SA1111 UDA1341: dsp id 3 mixer id 0
SA1111 audio out: SA-1111 SAC DMA channel 6 in use
DMA request for SAC output failed
physmap flash device: 4000000 at 8000000
Physically mapped flash: Found 2 x16 devices at 0x2000000 in 32-bit mode
0: offset=0x0,size=0x40000,blocks=128
1: offset=0x2000000,size=0x40000,blocks=128
Using buffer write method
SA1100 flash: probing 32-bit flash bus
SA1100 flash: Found 2 x16 devices at 0x2000000 in 32-bit mode
Using static partition definition
Creating 3 MTD partitions on "SA1100 flash":
0x00000000-0x00100000 : "zImage"
0x00100000-0x00400000 : "ramdisk.gz"
0x00400000-0x04000000 : "User FS"
Linux Kernel Card Services 3.1.22
  options:  [pm]
SA-1100 PCMCIA (CS release 3.1.22)
usb.c: registered new driver usbdevfs
usb.c: registered new driver hub
hcd/ohci-sa1111.c: starting SA-1111 OHCI USB Controller
hcd/ohci-sa1111.c: ohci-hcd (SA-1111) at 0xf4000400, irq 109
usb.c: new USB bus registered, assigned bus number 1
hub.c: USB hub found
hub.c: 1 port detected
usb.c: registered new driver hiddev
hid-core.c: v1.8.1 Andreas Gal, Vojtech Pavlik <vojtech@suse.cz>
hid-core.c: USB HID support drivers
mice: PS/2 mouse device common for all mice
NET4: Linux TCP/IP 1.0 for NET4.0
IP Protocols: ICMP, UDP, TCP
IP: routing cache hash table of 512 buckets, 4Kbytes
TCP: Hash tables configured (established 4096 bind 4096)
NET4: Unix domain sockets 1.0/SMP for Linux NET4.0.
NetWinder Floating Point Emulator V0.95 (c) 1998-1999 Rebel.com
RAMDISK: Compressed image found at block 0
Freeing initrd memory: 3072K
EXT2-fs warning: checktime reached, running e2fsck is recommended
VFS: Mounted root (ext2 filesystem).
Freeing init memory: 88K
hub.c: USB new device connect on bus1/1, assigned device number 2
hub.c: 4 ports detected
enable_irq(114) unbalanced from c032558c
Trying to free nonexistent resource <ce8a6000-ce8a600f>
hda: SILICONSYSTEMS INC 128MB, ATA DISK drive
ide0 at 0xce8a6000-0xce8a6007,0xce8a600e on irq 114
hda: 254208 sectors (130 MB) w/0KiB Cache, CHS=993/8/32
Partition check:
 hda: hda1
ide_cs: hda: Vcc = 3.3, Vpp = 0.0
 hda: hda1
 hda: hda1
VFS: Can't find ext2 filesystem on dev ide0(3,1).
 hda: hda1
 hda: hda1
cramfs: wrong magic
 hda: hda1
 hda: hda1
 hda: hda1
 hda: hda1
 hda: hda1
 hda: hda1
cramfs: wrong magic
 hda: hda1
 hda: hda1
AVR driver initialized. version 1.1, date:Aug  6 2004
[root@Linux /proc]$cat /proc/cpuinfo
Processor : StrongARM-1110 rev 9 (v4l)
BogoMIPS : 137.21
Features : swp half 26bit fastmult
Hardware : ADS GraphicsMaster
Revision : 0000
Serial : 0000000000000000
[root@Linux /proc]$
I think this module is used to reprogram a avr controller in the device
[root@Linux /root]$lsmod
Module                  Size  Used by
avrprog                 5416   0 (unused)
[root@Linux /root]$
[root@Linux /root]$cat /proc/interrupts
  0:      42792   ADS_ext_IRQ
  1:          0   sleep
 11:          0   GPIO 11-27
 12:          1   LCD
 17:       1224   serial_sa1100
 26:      62869   timer
 27:          0   rtc timer
 30:          2   rtc 1Hz
 31:          0   rtc Alrm
 49:        223   SA1111
 50:      40201   serial
 52:        982   serial
 54:        191   serial
 57:          0   UCB1200
 58:       1059   eth0
 63:          8   sio
 87:          0   keyboard
 97:          0   SA1111 audio out
 98:          0   SA1111 audio in
 99:          0   SA1111 audio out
100:          0   SA1111 audio in
109:         24   ohci-hcd
114:        240   ide0
116:          0   SA1111 PCMCIA card detect
117:          0   SA1111 CF card detect
118:          0   SA1111 PCMCIA BVD1
119:          0   SA1111 CF BVD1
Err:          0
[root@Linux /root]$
[root@Linux /root]$ps aux
USER       PID %CPU %MEM   VSZ  RSS TTY      STAT START   TIME COMMAND
root         1  1.1  0.8  1384  544 ?        S    Feb13   0:07 init
root         2  0.0  0.0     0    0 ?        SW   Feb13   0:00 [keventd]
root         3  0.0  0.0     0    0 ?        SWN  Feb13   0:00 [ksoftirqd_CPU0]
root         4  0.0  0.0     0    0 ?        SW   Feb13   0:00 [kswapd]
root         5  0.0  0.0     0    0 ?        SW   Feb13   0:00 [bdflush]
root         6  0.0  0.0     0    0 ?        SW   Feb13   0:00 [kupdated]
root         7  0.0  0.0     0    0 ?        SW   Feb13   0:00 [mtdblockd]
root         8  0.0  0.0     0    0 ?        SW   Feb13   0:00 [khubd]
root        40  0.0  0.0     0    0 ?        SWN  Feb13   0:00 [jffs2_gcd_mtd3]
root        56  0.0  1.1  1480  744 ?        S    Feb13   0:00 /sbin/cardmgr -f
root       587  0.0  1.0  1568  644 ?        S    Feb13   0:00 dhcpcd -DH -t 10
root       610  0.0  0.8  1680  544 ?        S    Feb13   0:00 syslogd -m 0
bin        636  0.0  0.7  1456  444 ?        S    Feb13   0:00 [portmap]
root       666  0.0  1.0  1592  644 ?        S    Feb13   0:00 inetd
root       679  0.0  0.8  1704  544 ?        S    Feb13   0:00 /bin/sh /etc/rc.d/rc3.d/S51timeUpdate.sh start
root       680  0.0  1.2  1788  772 ?        S    Feb13   0:00 /bin/bash /flash/elgato/utils/keepTimeUpdated
root       681  0.0  0.5  1672  336 ?        S    Feb13   0:00 sleep 1200
root       701  0.8 11.4 93644 7176 ?        S    Feb13   0:05 /flash/egServer/elgato -xaemon -o /dev/ttyS0 -e /dev/ttyS0
root       710  0.0  0.7  1572  476 tty1     S    Feb13   0:00 /sbin/getty 38400 tty1
root       711  0.0  0.7  1572  484 ttyS/ttySA0 S Feb13   0:00 /sbin/getty -L ttyS0 38400 vt100
root       712  0.0  1.2  1796  808 ?        S    Feb13   0:00 /bin/bash /root/catch_sleep.sh
root       724  0.0 11.4 93644 7176 ?        S    Feb13   0:00 /flash/egServer/elgato -xaemon -o /dev/ttyS0 -e /dev/ttyS0
root       725  0.0 11.4 93644 7176 ?        S    Feb13   0:00 /flash/egServer/elgato -xaemon -o /dev/ttyS0 -e /dev/ttyS0
root       726  0.0 11.4 93644 7176 ?        S    Feb13   0:00 /flash/egServer/elgato -xaemon -o /dev/ttyS0 -e /dev/ttyS0
root       727  0.0 11.4 93644 7176 ?        S    Feb13   0:00 /flash/egServer/elgato -xaemon -o /dev/ttyS0 -e /dev/ttyS0
root       729  0.0 11.4 93644 7176 ?        S    Feb13   0:00 /flash/egServer/elgato -xaemon -o /dev/ttyS0 -e /dev/ttyS0
root       730  0.0 11.4 93644 7176 ?        S    Feb13   0:00 /flash/egServer/elgato -xaemon -o /dev/ttyS0 -e /dev/ttyS0
root       731  0.0 11.4 93644 7176 ?        S    Feb13   0:00 /flash/egServer/elgato -xaemon -o /dev/ttyS0 -e /dev/ttyS0
root       732  0.0 11.4 93644 7176 ?        S    Feb13   0:00 /flash/egServer/elgato -xaemon -o /dev/ttyS0 -e /dev/ttyS0
root       738  0.2 11.4 93644 7176 ?        S    Feb13   0:01 /flash/egServer/elgato -xaemon -o /dev/ttyS0 -e /dev/ttyS0
root       751  0.0 11.4 93644 7176 ?        S    Feb13   0:00 /flash/egServer/elgato -xaemon -o /dev/ttyS0 -e /dev/ttyS0
root       752  0.0 11.4 93644 7176 ?        S    Feb13   0:00 /flash/egServer/elgato -xaemon -o /dev/ttyS0 -e /dev/ttyS0
root       753  0.0 11.4 93644 7176 ?        S    Feb13   0:00 /flash/egServer/elgato -xaemon -o /dev/ttyS0 -e /dev/ttyS0
root       754  0.0 11.4 93644 7176 ?        S    Feb13   0:00 /flash/egServer/elgato -xaemon -o /dev/ttyS0 -e /dev/ttyS0
root       755  0.0 11.4 93644 7176 ?        S    Feb13   0:00 /flash/egServer/elgato -xaemon -o /dev/ttyS0 -e /dev/ttyS0
root       756  0.0 11.4 93644 7176 ?        S    Feb13   0:00 /flash/egServer/elgato -xaemon -o /dev/ttyS0 -e /dev/ttyS0
root       757  0.0 11.4 93644 7176 ?        S    Feb13   0:00 /flash/egServer/elgato -xaemon -o /dev/ttyS0 -e /dev/ttyS0
root       758  0.0 11.4 93644 7176 ?        S    Feb13   0:00 /flash/egServer/elgato -xaemon -o /dev/ttyS0 -e /dev/ttyS0
root       759  0.0 11.4 93644 7176 ?        S    Feb13   0:00 /flash/egServer/elgato -xaemon -o /dev/ttyS0 -e /dev/ttyS0
root       774  1.1 22.2 18540 13968 tty2    S    Feb13   0:07 /flash/siege/bin/_siege -Xmx23m -DlocalAddress=127.0.0.1 -Dserver=127.0.0.1 -DLogger.level=2 -
root       776  0.0 22.2 18540 13968 tty2    S    Feb13   0:00 /flash/siege/bin/_siege -Xmx23m -DlocalAddress=127.0.0.1 -Dserver=127.0.0.1 -DLogger.level=2 -
root       777  0.0 22.2 18540 13968 tty2    S    Feb13   0:00 /flash/siege/bin/_siege -Xmx23m -DlocalAddress=127.0.0.1 -Dserver=127.0.0.1 -DLogger.level=2 -
root       778  0.0 22.2 18540 13968 tty2    S    Feb13   0:00 /flash/siege/bin/_siege -Xmx23m -DlocalAddress=127.0.0.1 -Dserver=127.0.0.1 -DLogger.level=2 -
root       779  0.0 22.2 18540 13968 tty2    S    Feb13   0:00 /flash/siege/bin/_siege -Xmx23m -DlocalAddress=127.0.0.1 -Dserver=127.0.0.1 -DLogger.level=2 -
root       780  9.9 22.2 18540 13968 tty2    S    Feb13   1:02 /flash/siege/bin/_siege -Xmx23m -DlocalAddress=127.0.0.1 -Dserver=127.0.0.1 -DLogger.level=2 -
root       781  0.0 11.4 93644 7176 ?        S    Feb13   0:00 /flash/egServer/elgato -xaemon -o /dev/ttyS0 -e /dev/ttyS0
root       782  0.0 11.4 93644 7176 ?        S    Feb13   0:00 /flash/egServer/elgato -xaemon -o /dev/ttyS0 -e /dev/ttyS0
root       783  0.0 11.4 93644 7176 ?        S    Feb13   0:00 /flash/egServer/elgato -xaemon -o /dev/ttyS0 -e /dev/ttyS0
root       784  0.0 11.4 93644 7176 ?        S    Feb13   0:00 /flash/egServer/elgato -xaemon -o /dev/ttyS0 -e /dev/ttyS0
root       785  0.0 11.4 93644 7176 ?        S    Feb13   0:00 /flash/egServer/elgato -xaemon -o /dev/ttyS0 -e /dev/ttyS0
root       786  0.0 11.4 93644 7176 ?        S    Feb13   0:00 /flash/egServer/elgato -xaemon -o /dev/ttyS0 -e /dev/ttyS0
root       787  0.0 11.4 93644 7176 ?        S    Feb13   0:00 /flash/egServer/elgato -xaemon -o /dev/ttyS0 -e /dev/ttyS0
root       788  0.0 22.2 18540 13968 tty2    S    Feb13   0:00 /flash/siege/bin/_siege -Xmx23m -DlocalAddress=127.0.0.1 -Dserver=127.0.0.1 -DLogger.level=2 -
root       789  0.0 22.2 18540 13968 tty2    S    Feb13   0:00 /flash/siege/bin/_siege -Xmx23m -DlocalAddress=127.0.0.1 -Dserver=127.0.0.1 -DLogger.level=2 -
root       790  0.0 22.2 18540 13968 tty2    S    Feb13   0:00 /flash/siege/bin/_siege -Xmx23m -DlocalAddress=127.0.0.1 -Dserver=127.0.0.1 -DLogger.level=2 -
root       791  0.0 22.2 18540 13968 tty2    S    Feb13   0:00 /flash/siege/bin/_siege -Xmx23m -DlocalAddress=127.0.0.1 -Dserver=127.0.0.1 -DLogger.level=2 -
root       792  0.0 22.2 18540 13968 tty2    S    Feb13   0:00 /flash/siege/bin/_siege -Xmx23m -DlocalAddress=127.0.0.1 -Dserver=127.0.0.1 -DLogger.level=2 -
root       795  0.2 22.2 18540 13968 tty2    S    Feb13   0:01 /flash/siege/bin/_siege -Xmx23m -DlocalAddress=127.0.0.1 -Dserver=127.0.0.1 -DLogger.level=2 -
root       798  0.0 11.4 93644 7176 ?        S    Feb13   0:00 /flash/egServer/elgato -xaemon -o /dev/ttyS0 -e /dev/ttyS0
root       799  0.0 11.4 93644 7176 ?        S    Feb13   0:00 /flash/egServer/elgato -xaemon -o /dev/ttyS0 -e /dev/ttyS0
root       800  0.0 11.4 93644 7176 ?        S    Feb13   0:00 /flash/egServer/elgato -xaemon -o /dev/ttyS0 -e /dev/ttyS0
root       801  0.0 11.4 93644 7176 ?        S    Feb13   0:00 /flash/egServer/elgato -xaemon -o /dev/ttyS0 -e /dev/ttyS0
root       802  0.0 11.4 93644 7176 ?        S    Feb13   0:00 /flash/egServer/elgato -xaemon -o /dev/ttyS0 -e /dev/ttyS0
root       803  0.0 11.4 93644 7176 ?        S    Feb13   0:00 /flash/egServer/elgato -xaemon -o /dev/ttyS0 -e /dev/ttyS0
root       804  0.7 11.4 93644 7176 ?        S    Feb13   0:04 /flash/egServer/elgato -xaemon -o /dev/ttyS0 -e /dev/ttyS0
root       805  0.0 11.4 93644 7176 ?        S    Feb13   0:00 /flash/egServer/elgato -xaemon -o /dev/ttyS0 -e /dev/ttyS0
root       806  0.0 11.4 93644 7176 ?        S    Feb13   0:00 /flash/egServer/elgato -xaemon -o /dev/ttyS0 -e /dev/ttyS0
root       807  0.0 11.4 93644 7176 ?        S    Feb13   0:00 /flash/egServer/elgato -xaemon -o /dev/ttyS0 -e /dev/ttyS0
root       808  0.0 11.4 93644 7176 ?        S    Feb13   0:00 /flash/egServer/elgato -xaemon -o /dev/ttyS0 -e /dev/ttyS0
root       809  0.0 11.4 93644 7176 ?        S    Feb13   0:00 /flash/egServer/elgato -xaemon -o /dev/ttyS0 -e /dev/ttyS0
root       810  0.0 11.4 93644 7176 ?        S    Feb13   0:00 /flash/egServer/elgato -xaemon -o /dev/ttyS0 -e /dev/ttyS0
root       811  0.0 11.4 93644 7176 ?        S    Feb13   0:00 /flash/egServer/elgato -xaemon -o /dev/ttyS0 -e /dev/ttyS0
root       812  0.0 11.4 93644 7176 ?        S    Feb13   0:00 /flash/egServer/elgato -xaemon -o /dev/ttyS0 -e /dev/ttyS0
root       813  0.0 11.4 93644 7176 ?        S    Feb13   0:00 /flash/egServer/elgato -xaemon -o /dev/ttyS0 -e /dev/ttyS0
root       814  0.0 11.4 93644 7176 ?        S    Feb13   0:00 /flash/egServer/elgato -xaemon -o /dev/ttyS0 -e /dev/ttyS0
root       819  0.0 22.2 18540 13968 tty2    S    Feb13   0:00 /flash/siege/bin/_siege -Xmx23m -DlocalAddress=127.0.0.1 -Dserver=127.0.0.1 -DLogger.level=2 -
root       824  0.0  1.3  1956  848 ?        S    Feb13   0:00 in.telnetd
root       825  0.0  1.5  1824  948 pts/0    S    Feb13   0:00 -bash
root       839  0.0  1.3  2736  876 pts/0    R    00:03   0:00 ps aux
[root@Linux /root]$
The serial port /dev/ttyS/ttySA0 is used for a serial console, and elgato is using ttyS0, ttyS2 and ttyS3. I think ttySA0 and ttySA1 are available on the back of the device.
The java part of the software is using /dev/rpg which is a simlink to /dev/sio15 i'm not sure what this is.
Offline Urs42
« Reply #8 on: February 18, 2015, 05:36:37 am »
It would be interessting to add some non GSM/UMTS signals to the signal generator,  the data files for the generator are stored in /flash/egServer/Dragonfly/Measurements/Data/ and i have no idea about the format.
« Reply #9 on: February 21, 2015, 12:45:24 pm »
I guess these are waveform binaries for the built-in Arbitrary Waveform Generator.
If we find out the format then we could create our own and push it to the E7495. Maybe even a function could be added to the Java GUI to enable copying waveforms from/to the CF card and PCMCIA card.
Thinking about it, it would make the E7495 into a really flexible tool.
Offline 9aplus
« Reply #10 on: February 22, 2015, 02:16:40 pm »
Hello to all,
It is nice to know that someone else is digging out around E7495B software....
Own one unit just couple of months, working just fine, except remote SW on PC with new windows version XP and later.
Therefore I made debug of JAVA code in attempt to write own SW... for PC operated under Linux (Ubuntu 12 and later)
and new Windows versions.
I am interested to join efforts to bring this nice instrument to full use :)
Here my hardware configuration ->
« Last Edit: February 22, 2015, 02:18:34 pm by 9aplus »
Offline 9aplus
« Reply #11 on: February 22, 2015, 03:02:28 pm »
Here just for educational evaluation
decompiled Java egclient app...
https://www.dropbox.com/s/waxxkz9c44h7dy2/egclient.src.zip?dl=0
Offline Urs42
« Reply #12 on: February 22, 2015, 03:36:11 pm »
The remote software consists of two parts egclient.jar and  RemoteGui.jar. egclient.jar is also the GUI that you see on the device itself. RemoteGui.jar is a wrapper around egclient.jar it provides some additional buttons, for example the ESC/Lcl Button that is needed to switch between the local and remote mode. egclient.jar runs just fine on a Debian 7 System, didn't test any Windows version because i don't have one. The problem with running egclient alone, is that you can't press the ESC/Lcl button, so the remote control dons't work :-(
java -Dserver=10.10.0.101 -DlocalAddress=micro -classpath "egclient.jar:xerces.jar:JimiProClasses.zip:RemoteGui.jar" elgato.gui.MainWindow
I do have the same options installed.
Offline 9aplus
« Reply #13 on: February 22, 2015, 04:38:16 pm »
Must try than on my Ubuntu 12.04 LTS but so far no luck with j2re-1_4_2-linux-i586.bin from Oracle site....
Do you agree to the above license terms? [yes or no]
yes
Unpacking...
tail: cannot open `+473' for reading: No such file or directory
Checksumming...
1
The download file appears to be corrupted.  Please refer
to the Troubleshooting section of the Installation
Instructions on the download page for more information.
Please do not attempt to install this archive file.
q@ubuntu:~/Desktop$
« Last Edit: February 22, 2015, 04:51:24 pm by 9aplus »
« Reply #14 on: February 22, 2015, 05:08:47 pm »
Nice. I'd love to have options 240 and 245, as well as 230 and 235. My unit only came with CDMA+EV-DO unfortunately.
Offline 9aplus
« Reply #15 on: February 22, 2015, 05:23:08 pm »
Right,
but on the other hand I was not so lucky with SW keys ->
Offline Urs42
« Reply #16 on: February 22, 2015, 05:48:05 pm »
I'm using the openjdk-6 Package from Debian.
I think you can copy the license file from one device to another if you change the hostid on the target device. But i'm not sure...
Online PA0PBZ
« Reply #17 on: February 22, 2015, 06:01:31 pm »
The E7495 firmware looks very much the same as for the N1996 CSA SA, I can even use the remote client on my CSA. The license manager on the CSA is easy to patch so that it accepts any license code, maybe it is the same for the E7495. The license daemon on the CSA is called TORO, but I could not see something simular in the ps output posted above.
Offline Urs42
« Reply #18 on: February 22, 2015, 06:09:24 pm »
The licensing is done by the elgato process. I think they are using flexlm. Here is the license file from my device, i did remove the HOSTID and SIGN Values.
$ cat elgato.lic
FEATURE 200 agilent 1.000 permanent uncounted \
HOSTID=ID_STRING=XXXXX SIGN=YYYYYYYYY
FEATURE 220 agilent 1.000 permanent uncounted \
FEATURE 240 agilent 1.000 permanent uncounted \
FEATURE 245 agilent 1.000 permanent uncounted \
FEATURE 205 agilent 1.000 permanent uncounted HOSTID=ID_STRING=XXXXX \
SIGN=YYYYYYYYY
Online PA0PBZ
« Reply #19 on: February 22, 2015, 06:23:45 pm »
Yes, that is FlexLM, same as N1996A and E4406A.
Offline theatrus
« Reply #20 on: February 22, 2015, 06:39:19 pm »
Looks nearly identical to the N1996A.
The good news is the binaries have most of their symbols intact - objdump (for ARM) and search for some likely functions :)
Software by day, hardware by night; blueAcro.com
Offline 9aplus
« Reply #21 on: February 22, 2015, 06:50:50 pm »
Here more luck with OpenJDK Java 6 runtime
Now RemoteGUI.jar is running but not happy with egclient.jar version.
Program is offering download of egclient.jar from E7495B but file
transfer ends with 0 size....
Online PA0PBZ
« Reply #22 on: February 22, 2015, 06:52:32 pm »
Well. I just downloaded the firmware and did a quick compare between the toro process and the elgato one. Then I did a search for 16 bytes around the patch area and elgato had only one hit. So for whoever feels lucky, try this: (latest firmware downloaded from HP Agilent Keysight site)
Elgato offset 337A7C, change 01 00 00 EA to 00 00 A0 E1.
Then check your license file if there are any entries without the SIGN = part, because they start to work magically if the patch works and you don't want any weird options enabled. Just take them out.
Good luck and let me know  ;)
Edit: Version A06.25
« Last Edit: February 22, 2015, 06:57:06 pm by PA0PBZ »
Offline Urs42
« Reply #23 on: February 22, 2015, 07:21:54 pm »
Many thanks PA0PBZ, i'll try that.
toroServer looks alot like egServer. It would be interessting to see how similar the hardware of both devices is. FM/AM Demodulation and other Stuff i see in the toroServer directory would be cool...
Online PA0PBZ
« Reply #24 on: February 22, 2015, 07:42:04 pm »
It does, I even see a lot of possible options in the CSA that looks to be for the E7495:
200   CDMA / CDMA 2000 Analyzer
205   1xEV-DO Analyzer
210   CDMA Over Air Test
220   Channel Scanner
230   GSM Analyzer
235   GSM Edge
250   W-CDMA (UMTS) Over Air Test
270   Interference Analyzer
271   Spectrogram
300   DC Bias
330   NEM Software <unknown>
500   Internal Agilent Mfg Source
503   Frequency Range 100 kHz to 3 GHz
506   Frequency Range 100 kHz to 6 GHz
600   Power Meter
700   T1 Analyzer
710   E1 Analyzer
AFM   AM/FM Tune & Listen
HAR   Harmonics Analyzer
IQD   IQ Waveform
N8995A   Stimulus/Response Measurement Suite
N8995A-SR3   Stimulus/Response Measurement Suite, 3 GHz
N8995A-SR6   Stimulus/Response Measurement Suite, 6 GHz
N8996A-1FP   AM/FM Modulation Analyzer
N8996A-2FP   ASK/FSK Analyzer ASK/FSK
N8997A-1FP   W-CDMA (UMTS) Analyzer
N8997A-2FP   HSDPA Measurement
P03   Preamplifier, 3 GHz
P06   Preamplifier, 6 GHz
SEM   Spectral Emmissions Mask
TG3   Tracking Generator, 3 GHz
TG6   Tracking Generator, 6 GHz
TOI   TOI Analyzer
Offline 9aplus
« Reply #25 on: February 22, 2015, 07:51:19 pm »
Yes in deed, that looks like many of E7495B options....
Here still version download trouble....
Offline Urs42
« Reply #26 on: February 22, 2015, 08:12:06 pm »
Try http://192.168.1.209/egclient.jar
@PA0PBZ The patch works perfectly!
Online PA0PBZ
« Reply #27 on: February 22, 2015, 08:16:15 pm »
That was a fast one then, without even having the E7495.  :-+
Offline 9aplus
« Reply #28 on: February 22, 2015, 08:54:59 pm »
So SW options unlocked ;)
Great  :-+
that with link
can not work, but ftp transfer may work....
flie on E7495B is->
 /flash/egGui/
3480541 Nov  1  2007 egclient.jar
Offline Urs42
« Reply #29 on: February 22, 2015, 09:08:27 pm »
I managed to start the remote Gui on my System!
You need the folowing files
egclient.jar
JimiProClasses.zip
RemoteGui.jar
xerces.jar
I think it will only work with the OpenJDK Java 6 runtime
You need to change the server and localAddress parameters, the server is the E7495 and localAddress is the IP of your PC.
java -Dserver=10.10.0.101 -DlocalAddress=10.10.0.156 -classpath "egclient-patch.jar:xerces.jar:JimiProClasses.zip:RemoteGui.jar" elgato.gui.MainWindow
Some helpful Key kombinations
CTRL-H = Help
CTRL-L = Local (This one is important!)
F1 to F7 =  Menu items on the left side
F9 = Mode Button
1 to 7 = Menu items on the right side
Before you can do anything you have to switch to the local mode on your PC, press CTRL-L to do this.
« Last Edit: February 23, 2015, 06:54:21 am by Urs42 »
Offline 9aplus
« Reply #30 on: February 22, 2015, 09:19:54 pm »
Great, I have JDK 6 runtime, but
sorry I am not able to follow you...
Can you please explain step by step for dummies  (me)
Here is directory on my E7495B ->
[root@00-60-0c-00-48-9c egGui]$ls -al
drwxrwxr-x    1 root     root            0 Nov 13  1969 .
drwxrwxr-x    1 root     root            0 Nov 13  1969 ..
-r--r--r--    1 root     root       455489 Nov  1  2007 JimiProClasses.zip
-rw-rw-r--    1 root     root      3480541 Nov  1  2007 egclient.jar
-r--r--r--    1 root     root         8070 Nov  1  2007 libguiutil.so
-r--r--r--    1 root     root       596528 Nov  1  2007 rhino-1.5R4.jar
-rw-------    1 root     root            0 Dec 18  2006 shellexec.log
-r--r--r--    1 root     root      1897838 Nov  1  2007 swing.jar
-r--r--r--    1 root     root      1812019 Nov  1  2007 xerces.jar
E7495B is on 192.168.1.209
PC-Ubuntu 12.04 is on 192.168.205
« Last Edit: February 22, 2015, 09:28:47 pm by 9aplus »
Offline Urs42
« Reply #31 on: February 23, 2015, 05:00:08 am »
@9aplus How do you start the gui, and what is the error message you get?
Offline 9aplus
« Reply #32 on: February 23, 2015, 09:32:27 am »
This error message ->
I am running RemoteGUI.jar with OpenJDK Java 6 runtime
Than after OK, file sistem is opened and after another ->Save
egclient.jar is with 0 size (download started, but not finished)
My intention now is to set up ftp transfer E7495B to PC-Ubuntu of whole egGui folder:
And than to try with start of
on PC again.....
Offline Urs42
« Reply #33 on: February 23, 2015, 11:02:18 am »
The download did work with my E7495, it should work with yours, i have no idea what the problem is. You could try to debug it with tcpdump or ngrep.
Please look at Reply #29, don't klick on anything, open a console and run the java command in my reply. If you can't download the egclient.jar file, telnet in to the E7495 and then copy the file with ftp to the PC, you can find it in the directory /flash/egGui/. Or you could extract the file from the firmware that you can get on the Agilent site.
You are running Firmware 6.23 i'm running 6.25, i think you should update your device first.
Offline 9aplus
« Reply #34 on: February 23, 2015, 11:51:24 am »
Thank you,
yes UPDATE of FIRMWARE may be solution, must find PCMCIA reader first, this PC do not have one...
Here what is answer on java command run ->
q@ubuntu:~$ java -Dserver=192.168.1.209 -DlocalAddress=192.168.1.205 -classpath "egclient-patch.jar:xerces.jar:JimiProClasses.zip:RemoteGui.jar" elgato.gui.MainWindow
Exception in thread "main" java.lang.NoClassDefFoundError: elgato/gui/MainWindow
Caused by: java.lang.ClassNotFoundException: elgato.gui.MainWindow
   at java.net.URLClassLoader$1.run(URLClassLoader.java:217)
   at java.security.AccessController.doPrivileged(Native Method)
   at java.net.URLClassLoader.findClass(URLClassLoader.java:205)
   at java.lang.ClassLoader.loadClass(ClassLoader.java:323)
   at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:294)
   at java.lang.ClassLoader.loadClass(ClassLoader.java:268)
Could not find the main class: elgato.gui.MainWindow. Program will exit.
q@ubuntu:~$
Offline Urs42
« Reply #35 on: February 23, 2015, 11:58:28 am »
It loos like you are running the command in your home directory, that won't work. Run it in the directory where all the java files are.
I pasted the wrong command line, please replace egclient-patch.jar with egclient.jar
java -Dserver=192.168.1.209 -DlocalAddress=192.168.1.205 -classpath "egclient.jar:xerces.jar:JimiProClasses.zip:RemoteGui.jar" elgato.gui.MainWindow
A PCMCIA adapter won't be easy to find. I'm not sure if it's possible to update the firmware with a CF card. Card readers with CF are available in every electronics store (at least here). If you need a PCMCIA card for the upgrade, buy a CF to PCMCIA adapter and a CF card.
If you have a PCMCIA Card in your device, you could also use ftp to copy the upgrade to the card, you need some linux knowledge to do this.
« Last Edit: February 23, 2015, 12:13:24 pm by Urs42 »
« Reply #36 on: February 23, 2015, 12:07:33 pm »
Thank you,
You don't need PCMCIA. The E7495 also has a separate Compact Flash slot, just copy the firmware update to a FAT32 formatted CF card, plug in into the E7495 and switch it on. It will find the file and start the firmware update process.
Offline 9aplus
« Reply #37 on: February 23, 2015, 12:43:18 pm »
Right, thank you :)
must visit the store next door... for CF card than
My Linux knowledge is limited, or a bit rusty, last time running approx 30 years ago
on some Unix XWin on Truevision Graphic Workstation  :palm:
but anyway have manged to start ftp server on Ubuntu and can login
using telnet like root from E7495B...
Here java runing from right folder ->
q@ubuntu:~/Desktop$ cd E7495xRemoteGui
q@ubuntu:~/Desktop/E7495xRemoteGui$ ls -al
total 4420
drwxrwxr-x 2 q q    4096 Feb 22 20:00 .
drwxr-xr-x 7 q q    4096 Feb 23 12:23 ..
-rwxrwxr-x 1 q q 2208850 Mar 25  2005 egclient.jar
-rwxrwxr-x 1 q q  455489 Jan 13  2004 JimiProClasses.zip
-rwxrwxr-x 1 q q   32611 Jun 30  2005 RemoteGui.jar
-rwxrwxr-x 1 q q 1812019 Sep 14  2004 xerces.jar
q@ubuntu:~/Desktop/E7495xRemoteGui$ java -Dserver=192.168.1.209 -DlocalAddress=192.168.1.205 -classpath "egclient.jar:xerces.jar:JimiProClasses.zip:RemoteGui.jar" elgato.gui.MainWindow
1424695201661 INFO util.LocaleManager No locale set, using default.
1424695201677 ERROR:  measurement.ListActuator Value 'en_GB' is not in the list -English (United States)
Exception in thread "main" java.lang.NoClassDefFoundError: ceej/awt/KeyEventFilter
   at elgato.util.Platform.createPlatform(Unknown Source)
   at elgato.util.Platform.<clinit>(Unknown Source)
   at elgato.gui.MainWindow.initKeyManager(Unknown Source)
   at elgato.gui.MainWindow.initializeApplication(Unknown Source)
   at elgato.gui.MainWindow.main(Unknown Source)
Caused by: java.lang.ClassNotFoundException: ceej.awt.KeyEventFilter
   ... 6 more
« Last Edit: February 23, 2015, 12:48:55 pm by 9aplus »
Offline jwm_
    • Not A Number
« Reply #38 on: February 23, 2015, 05:01:16 pm »
Ordered a broken (unknown reasons, non engineer seller) one for $275. Hopefully I will be able to get it up and running or I'll have some spare parts for you all.
Offline theatrus
« Reply #39 on: February 23, 2015, 05:35:57 pm »
Since Sun at the tie wasn't in the business of shipping embedded Linux VMs, this will be using a VM made by these folks:
http://www.skelmir.com/
It looks like the libraries are setup to call into their implementation of AWT. In theory you could use proguard or similar to re-write the class references to normal AWT.
Java: write once, run somewhere
Right, thank you :)
total 4420
   ... 6 more
Offline 9aplus
« Reply #40 on: February 23, 2015, 06:40:44 pm »
Well for sure something is not good regarding The file transfer....
Here is my FTP transfer attempt, maybe someone can find out, what is wrong....
q@ubuntu:/home$ ls -al
total 12
drwxrwxrwx  3 root root 4096 Feb  5 15:21 .
drwxr-xr-x 24 root root 4096 Feb 19 10:27 ..
drwxr-xr-x 34 q    q    4096 Feb 23 17:47 q
q@ubuntu:/home$ sudo chmod 777 q
[sudo] password for q:
total 12
drwxrwxrwx 34 q    q    4096 Feb 23 17:47 q
Enabling all kind of reading and writing on home of user q
q@ubuntu:/home$ sudo /etc/init.d/vsftpd start
vsftpd start/running, process 5611
ftp server start....
q@ubuntu:/home$ telnet 192.168.1.209
Trying 192.168.1.209...
Connected to 192.168.1.209.
Escape character is '^]'.
Linux login: root
Password:
telnet on E7495B
[root@Linux /root]$cd ..
[root@Linux /]$cd ..
[root@Linux /]$ls -al
drwxr-xr-x   19 root     root         1024 Feb 20 08:17 .
drwxr-xr-x   19 root     root         1024 Feb 20 08:17 ..
-rwxr-xr-x    1 root     root           31 Feb 20 08:17 .flexlmrc
drwxr-xr-x    2 root     root         2048 Oct 21  1968 bin
drwxr-xr-x    6 root     root         2048 Oct 21  1968 dev
drwxr-xr-x    6 root     root         1024 Oct 21  1968 etc
drwxrwxr-x    1 root     root            0 Nov 13  1969 flash
drwxr-xr-x    8 root     root         1024 Aug 23  2004 home
drwxr-xr-x    4 root     root         2048 Oct 21  1968 lib
lrwxrwxrwx    1 root     root           11 Aug 23  2004 linuxrc -> bin/busybox
drwxr-xr-x    2 root     root        12288 Apr  4  2000 lost+found
drwxr-xr-x    2 root     root         1024 Aug 23  2004 mnt
drwxr-xr-x    2 root     root         1024 Aug 23  2004 nfs
dr-xr-xr-x   89 root     root            0 Oct 21  1968 proc
drwxr-xr-x    2 root     root         1024 Aug 23  2004 rd
drwxr-xr-x    2 root     root         1024 Feb 20 08:17 root
drwxr-xr-x    2 root     root         1024 Apr  7  2004 sbin
drwxr-xr-t    3 root     root         1024 Feb 20 08:17 tmp
drwxr-xr-x    7 root     root         1024 Apr  7  2004 usr
drwxr-xr-x    7 root     root         1024 Apr  7  2004 var
drwxr-xr-x    2 root     root         1024 Aug 23  2004 xdrive
[root@Linux /]$cd flash
[root@Linux /flash]$ls
COPYRIGHTS.TXT.gz     firmware_upgrade.log  mnt
egGui                 linux                 mntArms
egServer              ln                    siege
elgato                loadkernel            siege_current
[root@Linux /flash]$cd egGui
[root@Linux egGui]$ls -al
changing path to righ folder....
[root@Linux egGui]$ftp
ftp> open 192.168.1.205
Connected to 192.168.1.205.
220 Welcome to VIHOR FTP service.
Name (192.168.1.205:root): q
331 Please specify the password.
Password:
230 Login successful.
Remote system type is UNIX.
Using binary mode to transfer files.
Login to ftp server on Ubuntu PC
ftp> passive
Passive mode on.
ftp> put libguiutil.so
local: libguiutil.so remote: libguiutil.so
227 Entering Passive Mode (192,168,1,205,56,86).
150 Ok to send data.
421 Data timeout. Reconnect. Sorry.
8070 bytes sent in 0.00125 secs (6.3e+03 Kbytes/sec)
ftp> close
Not connected.
ftp> exit
[root@Linux egGui]$quitConnection closed by foreign host.
Transfer started, but takes bit long for small 8kb file (smallest in folder), ftp closed, telnet quit
total 12
drwxrwxrwx 34 q    q    4096 Feb 23 19:10 q
q@ubuntu:/home$ cd q
q@ubuntu:~$ ls -al
total 216
drwxrwxrwx 34 q    q     4096 Feb 23 19:10 .
drwxrwxrwx  3 root root  4096 Feb  5 15:21 ..
drwx------  3 q    q     4096 Feb  5 21:02 .adobe
... lot of flies and folders
-rw-------  1 q    q        0 Feb 23 19:10 libguiutil.so
... lot of files and folders
-rw-------  1 q    q     8935 Feb 23 12:37 .xsession-errors.old
q@ubuntu:~$
Same result, test file libguiutil.so have 0 size....
For reference vsftpd.conf is ->
listen=YES
anonymous_enable=YES
local_enable=YES
write_enable=YES
anon_upload_enable=YES
anon_mkdir_write_enable=YES
dirmessage_enable=YES
xferlog_enable=YES
connect_from_port_20=YES
chown_uploads=YES
chown_username=q
ftpd_banner=Welcome to VIHOR FTP service.
secure_chroot_dir=/var/run/vsftpd
pam_service_name=vsftpd
rsa_cert_file=/etc/ssl/certs/vsftpd.pem
anon_root=/srv/ftp/incoming
Any tips or tricks  :-\
EDIT: for evidence, just made ftp transfer of 40 k file from another PC terminal console, without any trouble....
conclusion my ftp server setup on Ubuntu is OK
E7495B do not like to give his precious files away  ;)
« Last Edit: February 23, 2015, 08:01:32 pm by 9aplus »
Offline Urs42
« Reply #41 on: February 23, 2015, 08:40:36 pm »
The most important line is:
Looks like a network or firewall problem. I have no idea about the default firewall config on a Ubuntu System.  You also had troubles with the HTTP download. I think HTTP should work with any default firewall setup.  Is telnet stable? Can you compare the Output of ifconfig on the PC and E7495? Are there any errors in the output of dmesg on both devices?
Offline 9aplus
« Reply #42 on: February 23, 2015, 11:00:34 pm »
Telnet is stable, tests with mkdir or chmod are ok
HTTP transfer failed on Ubuntu and Windows 7 (second PC was first try) both are on Wireless and E7495 is on LAN Ethernet....
Maybe should test tomorrow with crossover CAT 5 cable or on other LAN hub/switch too. (LAN to LAN)
After booting there are no Errors by dmesg
Regarding Output of ifconfig on the PC and E7495, will see that tomorrow.
Offline 9aplus
« Reply #43 on: February 24, 2015, 12:33:55 pm »
After some re-formating of CF (8 GB Trascend) upgrade done....
but comm / download problem for egclient.jar still exist, at last on HTTP protocol
Offline 9aplus
« Reply #44 on: February 24, 2015, 02:24:13 pm »
Now copy of ifconfig...
Ubuntu PC->
q@ubuntu:~$ sudo /etc/init.d/vsftpd restart
Rather than invoking init scripts through /etc/init.d, use the service(8)
utility, e.g. service vsftpd restart
Since the script you are attempting to invoke has been converted to an
Upstart job, you may also use the stop(8) and then start(8) utilities,
e.g. stop vsftpd ; start vsftpd. The restart(8) utility is also available.
vsftpd stop/waiting
vsftpd start/running, process 3482
q@ubuntu:~$ ifconfig
eth0      Link encap:Ethernet  HWaddr 00:1b:38:07:e1:35
          UP BROADCAST MULTICAST  MTU:1500  Metric:1
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          inet6 addr: ::1/128 Scope:Host
          UP LOOPBACK RUNNING  MTU:65536  Metric:1
          RX packets:1519 errors:0 dropped:0 overruns:0 frame:0
          TX packets:1519 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:147453 (147.4 KB)  TX bytes:147453 (147.4 KB)
wlan0     Link encap:Ethernet  HWaddr 00:1b:77:53:a1:e1
          inet addr:192.168.1.205  Bcast:192.168.1.255  Mask:255.255.255.0
          inet6 addr: fe80::21b:77ff:fe53:a1e1/64 Scope:Link
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:47025 errors:0 dropped:0 overruns:0 frame:0
          TX packets:10301 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:9331190 (9.3 MB)  TX bytes:1644170 (1.6 MB)
E7495B ->
q@ubuntu:~$ telnet 192.168.1.209
Linux login: root
Password:
[root@Linux /root]$ifconfig
eth0      Link encap:Ethernet  HWaddr 00:60:0C:00:48:9C
          inet addr:192.168.1.209  Bcast:192.168.1.255  Mask:255.255.255.0
          UP BROADCAST NOTRAILERS RUNNING  MTU:1500  Metric:1
          RX packets:1852 errors:0 dropped:0 overruns:0 frame:0
          TX packets:59 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:113381 (110.7 kb)  TX bytes:0 (0.0 b)
          Interrupt:58
          UP LOOPBACK RUNNING  MTU:16436  Metric:1
          RX packets:496 errors:0 dropped:0 overruns:0 frame:0
          TX packets:496 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:41823 (40.8 kb)  TX bytes:41823 (40.8 kb)
[root@Linux /root]$
Offline 9aplus
« Reply #45 on: February 24, 2015, 03:32:09 pm »
Another ftp session now wire LAN to LAN... no luck
ftp> open 192.168.1.204
Connected to 192.168.1.204.
Name (192.168.1.204:root): q
Password:
200 PORT command successful. Consider using PASV.
8070 bytes sent in 0.00131 secs (6e+03 Kbytes/sec)
ftp> exit
[root@Linux egGui]$ifconfig
          RX packets:6659 errors:0 dropped:0 overruns:0 frame:0
          TX packets:296 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:414038 (404.3 kb)  TX bytes:0 (0.0 b)
          Interrupt:58
          RX packets:1528 errors:0 dropped:0 overruns:0 frame:0
          TX packets:1528 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:123075 (120.1 kb)  TX bytes:123075 (120.1 kb)
          inet addr:192.168.1.204  Bcast:192.168.1.255  Mask:255.255.255.0
          inet6 addr: fe80::21b:38ff:fe07:e135/64 Scope:Link
          RX packets:9376 errors:1 dropped:0 overruns:0 frame:0
          TX packets:4340 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:1845529 (1.8 MB)  TX bytes:623224 (623.2 KB)
          RX packets:3987 errors:0 dropped:0 overruns:0 frame:0
          TX packets:3987 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:410258 (410.2 KB)  TX bytes:410258 (410.2 KB)
          RX packets:123593 errors:0 dropped:0 overruns:0 frame:0
          TX packets:51103 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:65287362 (65.2 MB)  TX bytes:10418010 (10.4 MB)
q@ubuntu:~$
Must be some of E7495B Linux setting :-[
Offline 9aplus
« Reply #46 on: February 24, 2015, 06:51:21 pm »
Well, after upgrade is done,
at last can use CF memory to get some measurement data out of E7495B
Offline 9aplus
« Reply #47 on: February 24, 2015, 10:16:00 pm »
By the way,
any of you managed to set HW date/clock....
Can not figure what is set sintax?
[root@E749xx /root]$date -s
date: option requires an argument -- s
BusyBox v0.60.3 (2002.06.05-19:04+0000) multi-call binary
Usage: date [OPTION]... [+FORMAT]
Displays the current time in the given FORMAT, or sets the system date.
Options:
   -R      Outputs RFC-822 compliant date string
   -d STRING   display time described by STRING, not `now'
   -s      Sets time described by STRING
   -u      Prints or sets Coordinated Universal Time
[root@E749xx /root]$date -R
Fri, 21 May 2010 21:04:06 +0000
[root@E749xx /root]$hwclock
Fri May 21 21:42:30 2010  -0.969888 seconds
EDIT:
Later managed that sintax->
date -s 2015.02.24-22:29
When you are happy with your system time, remember to set hwclock too,
Set hardware clock to system time ->
hwclock -w
Useful link, it seems that good part of E7495B Linux distribution is sourced from here ->
http://busybox.net/downloads/BusyBox.html
« Last Edit: February 24, 2015, 11:10:57 pm by 9aplus »
« Reply #48 on: February 25, 2015, 06:34:17 am »
One of the things that annoy me with the E7495 is that the default setting for screen shots is a white background. It looks bad on the image above, but it's absolutely crap in other modes like SA mode where the line is in light green.
The setting can be changed in the setup but it has to be done for each mode, and even then will often revert back to white.
It would be great if someone figured out a way to make black background the default.
« Reply #49 on: February 25, 2015, 06:40:31 am »
By the way,
Yes, GPS does it automatically.
As far as I know it uses parts of BusyBox but apparently the Linux on the E7495B is based on an old SUSE Linux variant from around 2004.
Offline Urs42
« Reply #50 on: February 25, 2015, 08:07:21 am »
Warning: Changes in /flash are permanent! You can brick your device! Don't change anything there if you are not sure what you are doing. Before you do anything there, use tar to back up all files from /flash to the CF or PCMCIA card!
In my first post i mentioned that the power up settings are stored in /flash/egServer/registry/Powerup/ i think that you can't change the powerup configuration with the GUI, but you can configure the device, save the configuration to a profile an then use telnet to copy your profile to /flash/egServer/registry/Powerup/. All profiles are stored as supdirectories of /flash/egServer/registry/
Must be some of E7495B Linux setting ?
I'm sorry, i can't see anything wrong from here, it's not easy to debug stuff like this without a way to reproduce the issue. I think the Linux on the E7495B isn't the issue here, It could be a hardware issue with your E7495B or some problem with your Network or Computer(s).
« Reply #51 on: February 25, 2015, 08:23:39 am »
Sure you can. Just save your preset as "powerup"  ;)
However this doesn't seem to help for the screen capture background setting, which still seems to revert to white.
I also couldn't find a parameter for it in the registry, but maybe I just didn't look hard enough or overlooked something.
Offline 9aplus
« Reply #52 on: February 25, 2015, 09:04:01 am »
In that case that is not stored on hwclock or there is no clock backup battery... because my unit was on GPS couple days ago.
Thank you for your kind efforts  :-+
No rush... after all, with all this I am refreshing my Unix know how :)
With CF use can pick up necessary data for now... and remote is in to do list.
E7495B must be capable on VXI or USBTMC commands, that may be also god solution for my future remote...
Considering from last night one other way to bring E7485B version of egclient.jar
to Ubuntu PC...  by simple copy on CF card, but
path ->
on /flash/mnt/cf/
>ls -al
empty folder! (some data like screns, xls and update files are on CF for sure....
Anyone, what is right path for my CF card?
Partition check:
 hda: hda1
enable_irq(115) unbalanced from c032558c
Trying to free nonexistent resource <ce8b7000-ce8b700f>
hdc: TS8GCF133, ATA DISK drive
ide1 at 0xce8b7000-0xce8b7007,0xce8b700e on irq 115
hdc: task_no_data_intr: status=0x51 { DriveReady SeekComplete Error }
hdc: task_no_data_intr: error=0x04 { DriveStatusError }
hdc: 15662304 sectors (8019 MB) w/1KiB Cache, CHS=974/255/63
 hdc: hdc1
ide_cs: hdc: Vcc = 3.3, Vpp = 0.0
 hda: hda1
 hda: hda1
 hda: hda1
 hda: hda1
cramfs: wrong magic
 hda: hda1
 hda: hda1
 hdc: hdc1
 hdc: hdc1
VFS: Can't find ext2 filesystem on dev ide1(22,1).
 hdc: hdc1
 hdc: hdc1
cramfs: wrong magic
 hdc: hdc1
 hdc: hdc1
 hda: hda1
 hda: hda1
 hda: hda1
 hda: hda1
cramfs: wrong magic
 hda: hda1
 hda: hda1
 hdc: hdc1
 hdc: hdc1
 hdc: hdc1
 hdc: hdc1
cramfs: wrong magic
 hdc: hdc1
 hdc: hdc1
Asking because >mount
report same devices with and without PCMCIA and CF card plugged on E7495B
no >lsblk to find out, any other way to do it?
[root@E749xx /root]$mount
rootfs on / type rootfs (rw)
/dev/root on / type ext2 (rw)
/proc on /proc type proc (rw)
none on /dev/pts type devpts (rw)
/dev/mtdb3 on /flash type jffs2 (rw)
« Last Edit: February 25, 2015, 03:21:37 pm by 9aplus »
« Reply #53 on: February 25, 2015, 03:45:37 pm »
I didn't check but without a charged battery in the battery bays or PSU power it will probably forget the date/time as I doubt it has a separate backup battery.
path ->
on /flash/mnt/cf/
>ls -al
You *did* mount the card in the E7495 before you tried to access it, didn't you?
Now that's really easy. It says it right there (I highlighted the relevant part in bold):
Partition check:
 hda: hda1
 hdc: hdc1
hda: hda1
 hda: hda1
 hda: hda1
 hda: hda1
cramfs: wrong magic
 hda: hda1
 hda: hda1
 hdc: hdc1
 hdc: hdc1
 hdc: hdc1
 hdc: hdc1
cramfs: wrong magic
 hdc: hdc1
 hdc: hdc1
 hda: hda1
 hda: hda1
 hda: hda1
 hda: hda1
cramfs: wrong magic
 hda: hda1
 hda: hda1
 hdc: hdc1
 hdc: hdc1
 hdc: hdc1
 hdc: hdc1
cramfs: wrong magic
 hdc: hdc1
 hdc: hdc1
It seems you're using a Transcend 8GB 133x Compact Flash card. But the error messages shouldn't be there.
Is the card formatted properly (FAT32)?
Easy:
# mount /dev/hdc1 /mnt
If you want to access the PCMCIA flash card (or a CF card in a PCMCIA adapter) then it's /dec/hda1 instead.
« Last Edit: February 25, 2015, 03:52:28 pm by Wuerstchenhund »
Offline Urs42
« Reply #54 on: February 25, 2015, 04:08:51 pm »
Some init script stores date and time at shutdown to a file in /flash, this date will be restored at the next boot.
 hdc: hdc1
I'm not sure if this is a critical error, some CF/PCMCIA cards will produce errors like this one, because they don't understand all command that the kernel sends to them while initializing the card.
Offline 9aplus
« Reply #55 on: February 25, 2015, 05:32:38 pm »
CF card is formated properly. That's the same one from which update to A.06.25 is performed
Well
My date went crazy again, both accu was inside unit....
Wed Feb 25 02:10:32 UTC 2015
[root@E749xx /root]$hwtime
bash: hwtime: command not found
Wed Feb 25 06:53:49 2015  -0.763275 seconds
Well my expectation was that the system already done that for me....
Thank you to both of you :)
Must try advices, than report later....
« Last Edit: February 25, 2015, 05:39:48 pm by 9aplus »
Offline 9aplus
« Reply #56 on: February 25, 2015, 05:52:51 pm »
Done... on second attempt after reboot
[root@E749xx /root]$mount /dev/hdc1 /mnt
/dev/hdc1 on /mnt type vfat (rw)
« Reply #57 on: February 25, 2015, 07:31:56 pm »
Yes, but that is only to avoid that new files are written with older timestamps than existing files.
In my experience (I use CF cards a lot for embedded stuff) the Transcend cards are often more problematic than say Sandisk or Apacer. Especially when they are treated as a fixed disk (like in the E7495) and not like a removable device.
However, I have used similar cards (same model, just 1GB and 16GB instead of 8GB) and didn't see such errors.
« Reply #58 on: February 25, 2015, 07:41:32 pm »
Both CF and PCMCIA storage remain unmounted until you press the screen shot button or save some measurement data, where the card gets mounted, written to and unmounted. Ever wondered why saving a simple screen shot takes so long? That's why.
This way the cards can be removed while the E7495 is still running.
Offline 9aplus
« Reply #59 on: February 25, 2015, 09:30:08 pm »
Last session ->
E749xx login: root
Password:
[root@E749xx /root]$cd ..
[root@E749xx /]$cd ..
[root@E749xx /]$ls
bin         flash       linuxrc     nfs         root        usr
dev         home        lost+found  proc        sbin        var
etc         lib         mnt         rd          tmp         xdrive
[root@E749xx /]$cd flash
[root@E749xx /flash]$cd egGui
[root@E749xx egGui]$ls
JimiProClasses.zip  rhino-1.5R4.jar     xerces.jar
egclient.jar        shellexec.log
libguiutil.so       swing.jar
[root@E749xx egGui]$cp egclient.jar /dev/hdc1
[root@E749xx egGui]$umount /dev/hdc1
[root@E749xx egGui]$mount
This is 4th try and failure.... after >cp on CF card file system is gone, full format on Win PC help to restore... data and screen copy
on same CF goes well....
Offline CustomEngineerer
« Reply #60 on: February 26, 2015, 02:53:27 am »
Last session ->
E749xx login: root
Password:
[root@E749xx /]$ls
Your syntax is a little off. "cp egclient.jar /dev/hdc1" is copying egclient.jar over the hdc1 device, not into it. I didn't think unix/linux would actually let you do that. My guess is that it wrote egclient.jar starting at the beginning of the cf card and overwrote the partition table which is why the file system is gone. The correct syntax would be "cp egclient.jar /dev/hdc1/", notice the trailing front slash after hdc1. Though I still would not recommend doing it this way. I would reformat the the CF card, mount it and then copy it with this command. "cp egclient.jar /mnt/" Again, make sure you get the trailing front slash.
« Last Edit: February 26, 2015, 02:58:03 am by CustomEngineerer »
Offline ldhn1uec
« Reply #61 on: February 26, 2015, 12:35:57 pm »
New to the group, new to the unit. At the hamcation flea market i picked up 4 units, all "broken", seems they all work to some extent. one has a broken lcd, all took the firmware upgrade. all have slightly different opotions. dissasembled and reassembled cracked unit,  it still works and is useable with remote software. saw some talk of the download issues, check any/all firewall settings on the host pc as the file is pulled from the pc within the java parent. i had trouble until i used the early 1.4 java package. that worked well on xp and still works on w7. starting to look into modifying the options, i'll post results here. i will also mention that since this is an older unit, don't use cf larger than 2g due to changes in sector sizes.  find a 64 or 128 MEG cf card for transfers and you'll have much fewer problems.  hope that helps.
Lou... N1UEC
Sent from my iPad using Tapatalk
Offline 9aplus
« Reply #62 on: February 26, 2015, 07:42:56 pm »
@CustomEngineerer thank you, that was useful tip, copy now in order  :-+
Concerning overall progress, something still missing.....  Correct path maybe?
RemoteGui.jar is not able to start egclient.jar, even not when all are within Home folder
When run alone egclient.jar makes this screen, and it is not possible to quit OpenJDK Java 6 Runtime.
« Reply #63 on: February 27, 2015, 01:09:23 am »
Glad you were able to get the copy done. For what's going wrong now all I can think of is to make sure that you are starting RemoteGui.jar like Urs42 suggested in Reply #35. Pasting it below. Also note that the command is a little different than when he first suggested it back in Reply #29. Good luck.
Offline 9aplus
« Reply #64 on: February 27, 2015, 12:35:43 pm »
Yes, you are right, just forgot on that advice...
Now all running well  :-+
(except ftp file transfer, but who cares)
Like to thank to all of you. for kind assistance and patience
on this small E7495B tutorial on Java & Linux
Offline 9aplus
« Reply #65 on: February 27, 2015, 06:44:39 pm »
Java application running but something is still not good regarding communication ->
1425060510121 INFO util.Resources Loaded resource file: /elgato/system.properties
1425060510182 INFO util.Resources Loaded resource file: /elgato/gui.properties
1425060510790 INFO util.LocaleManager No locale set, using default.
1425060512755 INFO util.Resources Loaded resource file: /elgato/infrastructure.properties
1425060518929 INFO util.DebugServer DebugServer started on port 5100
1425060519272 INFO gui.MainWindow Display area: java.awt.Dimension[width=472,height=414]
1425060519529 INFO commChannel.DefaultCommandProcessor STATUS: Startup in process...
1425060519725 INFO commChannel.DefaultCommandProcessor STATUS: Startup complete.
1425060521582 INFO commChannel.UDPMeasurementReader Binding to DatagramSocket
1425060521583 INFO commChannel.UDPMeasurementReader Bound to UDP port 37537
1425060522662 INFO mainScreens.ProductFactory Instantiating El Gato Product Factory (class ElgatoFactory)
1425060545849 INFO util.Resources Loaded resource file: /elgato/measurement.properties
1425060599560 WARN commChannel.DefaultCommandProcessor Suspected GUI hang received while waiting for a packet, re-sending readyToReceive
1425060647308 WARN commChannel.DefaultCommandProcessor Suspected GUI hang received while waiting for a packet, re-sending readyToReceive
1425060674497 INFO util.Resources Loaded resource file: /help/help.properties
1425061378924 WARN commChannel.DefaultCommandProcessor Suspected GUI hang received while waiting for a packet, re-sending readyToReceive
1425061738848 WARN commChannel.DefaultCommandProcessor Suspected GUI hang received while waiting for a packet, re-sending readyToReceive
1425062015101 ERROR:  util.FileSystemHelper saveImage(null, /tmpscreenTmp.png, image, true):
null
com.sun.jimi.core.JimiException
   at com.sun.jimi.core.JimiWriter.putImage(JimiWriter.java:242)
   at com.sun.jimi.core.Jimi.putImage(Jimi.java:601)
   at com.sun.jimi.core.Jimi.putImage(Jimi.java:587)
   at com.sun.jimi.core.Jimi.putImage(Jimi.java:575)
   at elgato.infrastructure.util.FileSystemHelper.saveImage(Unknown Source)
   at elgato.infrastructure.mainScreens.PrintScreenMessageScreen.decorateImage(Unknown Source)
   at elgato.infrastructure.mainScreens.PrintScreenMessageScreen.saveScreenImage(Unknown Source)
   at elgato.infrastructure.mainScreens.PrintScreenMessageScreen.printScreen(Unknown Source)
   at elgato.infrastructure.mainScreens.PrintScreenMessageScreen.commitAction(Unknown Source)
   at elgato.infrastructure.mainScreens.MediaMessageScreen.run(Unknown Source)
   at java.lang.Thread.run(Thread.java:701)
1425062015219 ERROR:  widgets.ImageIcon Timed out waiting for image to load
1425062015220 WARN mainScreens.PrintScreenMessageScreen decorateImage: No addition of filename to screen capture image...java.lang.IllegalArgumentException: Width (-1) and height (45) cannot be <= 0
1425062015220 ERROR:  util.FileSystemHelper saveImage(null, /tmp/printScreen_20150127_193334.png, image, true):
null
java.lang.NullPointerException
1425062436250 WARN commChannel.UDPMeasurementReader Error reading measurement packet, ignoring: java.net.SocketException: Socket closed
1425062436273 WARN commChannel.UDPMeasurementReader -80 bytes remaining after reading packet
1425062436287 WARN commChannel.UDPMeasurementReader Error reading measurement packet, ignoring: java.net.SocketException: Socket closed
1425062436287 WARN commChannel.UDPMeasurementReader -80 bytes remaining after reading packet
1425062436288 WARN commChannel.UDPMeasurementReader Error reading measurement packet, ignoring: java.net.SocketException: Socket closed
1425062436288 WARN commChannel.UDPMeasurementReader -80 bytes remaining after reading packet
1425062436289 WARN commChannel.UDPMeasurementReader -80 bytes remaining after reading packet
1425062436290 WARN commChannel.UDPMeasurementReader Error reading measurement packet, ignoring: java.net.SocketException: Socket closed
1425062436292 WARN commChannel.UDPMeasurementReader -80 bytes remaining after reading packet
1425062436292 WARN commChannel.UDPMeasurementReader Error reading measurement packet, ignoring: java.net.SocketException: Socket closed
1425062436295 WARN commChannel.UDPMeasurementReader -80 bytes remaining after reading packet
1425062436296 WARN commChannel.UDPMeasurementReader Error reading measurement packet, ignoring: java.net.SocketException: Socket closed
1425062436296 WARN commChannel.UDPMeasurementReader -80 bytes remaining after reading packet
1425062436297 WARN commChannel.UDPMeasurementReader Error reading measurement packet, ignoring: java.net.SocketException: Socket closed
1425062436297 WARN commChannel.UDPMeasurementReader -80 bytes remaining after reading packet
1425062436303 WARN commChannel.UDPMeasurementReader Error reading measurement packet, ignoring: java.net.SocketException: Socket closed
1425062436307 WARN commChannel.UDPMeasurementReader -80 bytes remaining after reading packet
1425062436307 WARN commChannel.UDPMeasurementReader Error reading measurement packet, ignoring: java.net.SocketException: Socket closed
1425062436315 WARN commChannel.UDPMeasurementReader -80 bytes remaining after reading packet
1425062436316 WARN commChannel.UDPMeasurementReader Error reading measurement packet, ignoring: java.net.SocketException: Socket closed
1425062436316 WARN commChannel.UDPMeasurementReader -80 bytes remaining after reading packet
1425062436317 WARN commChannel.UDPMeasurementReader -80 bytes remaining after reading packet
1425062436317 WARN commChannel.UDPMeasurementReader Error reading measurement packet, ignoring: java.net.SocketException: Socket closed
1425062436318 WARN commChannel.UDPMeasurementReader Error reading measurement packet, ignoring: java.net.SocketException: Socket closed
1425062436318 WARN commChannel.UDPMeasurementReader -80 bytes remaining after reading packet
1425062436319 WARN commChannel.UDPMeasurementReader Error reading measurement packet, ignoring: java.net.SocketException: Socket closed
1425062436319 WARN commChannel.UDPMeasurementReader -80 bytes remaining after reading packet
1425062436320 WARN commChannel.UDPMeasurementReader Error reading measurement packet, ignoring: java.net.SocketException: Socket closed
1425062436321 WARN commChannel.UDPMeasurementReader -80 bytes remaining after reading packet
1425062436327 WARN commChannel.UDPMeasurementReader Error reading measurement packet, ignoring: java.net.SocketException: Socket closed
1425062436328 WARN commChannel.UDPMeasurementReader -80 bytes remaining after reading packet
1425062436328 WARN commChannel.UDPMeasurementReader Error reading measurement packet, ignoring: java.net.SocketException: Socket closed
1425062436329 WARN commChannel.UDPMeasurementReader Error reading measurement packet, ignoring: java.net.SocketException: Socket closed
1425062436329 WARN commChannel.UDPMeasurementReader -80 bytes remaining after reading packet
1425062436330 WARN commChannel.UDPMeasurementReader -80 bytes remaining after reading packet
1425062436331 WARN commChannel.UDPMeasurementReader Error reading measurement packet, ignoring: java.net.SocketException: Socket closed
1425062436331 WARN commChannel.UDPMeasurementReader -80 bytes remaining after reading packet
1425062436332 WARN commChannel.UDPMeasurementReader Error reading measurement packet, ignoring: java.net.SocketException: Socket closed
1425062436333 ERROR:  util.DebugServer Couldn't accept connection
Socket closed
   at java.net.PlainSocketImpl.socketAccept(Native Method)
   at java.net.AbstractPlainSocketImpl.accept(AbstractPlainSocketImpl.java:375)
   at java.net.ServerSocket.implAccept(ServerSocket.java:478)
   at java.net.ServerSocket.accept(ServerSocket.java:446)
   at elgato.infrastructure.util.DebugServer.run(Unknown Source)
1425062436335 INFO util.DebugServer DebugServer stopped
1425062436337 WARN commChannel.UDPMeasurementReader -80 bytes remaining after reading packet
1425062436338 WARN commChannel.UDPMeasurementReader Error reading measurement packet, ignoring: java.net.SocketException: Socket closed
1425062436338 WARN commChannel.UDPMeasurementReader -80 bytes remaining after reading packet
1425062436339 WARN commChannel.UDPMeasurementReader Error reading measurement packet, ignoring: java.net.SocketException: Socket closed
1425062436340 WARN commChannel.UDPMeasurementReader -80 bytes remaining after reading packet
1425062436341 WARN commChannel.UDPMeasurementReader Error reading measurement packet, ignoring: java.net.SocketException: Socket closedq@ubuntu:~/Desktop/E7495xRemoteGui$
Offline jwm_
    • Not A Number
Re: Agilent E7495 linux root account
« Reply #66 on: February 27, 2015, 11:32:32 pm »
got my E7495A for repair but without any accesories or charger. can someone tell me the polarity/voltage of the external power port?
Offline Wuerstchenhund
« Reply #67 on: February 28, 2015, 08:36:15 am »
24Vdc, positive inside, negative outside
« Reply #68 on: February 28, 2015, 08:51:06 am »
It would be interesting to find out how similar the hardware is, and if some of the capabilities of the N1996A could be transferred to the E7495.
Online PA0PBZ
« Reply #69 on: February 28, 2015, 09:11:42 am »
It would be nice to have a service manual for either, but I only found the N1996A one at Agilent for about $400  :palm:
Offline 9aplus
« Reply #70 on: February 28, 2015, 10:00:55 am »
100W PS ->  4+ A current
Offline ldhn1uec
« Reply #71 on: February 28, 2015, 09:58:00 pm »
so, i have found the power supply can bve almost anything with a + center. the spec for the instrument is 10-24 volts at least 65 watts. 12v 5 amps works fine, as well as 19.8v and 4.14a.
my tinkering is going well. DO NOT ALTER the lower limit of the receivers as that will cause the system to fault. 375 is the actual \low limit. (was trying to squeeze vhf out of the swr bridge).
still comparing the dumps of the 4 units to decode the licensing arrangement. does seem that the only changes are the lic files as the other files are present anyway.
anyone have luck rebuilding or replacing the li-ion batteries?
as far as the remote gui, no joy on java 6, go back to java 1.4.2 and all was well. don't forget the loc/remote button to enable full control from the pc. even with a cracked lcd the remote software allows me to work with it.
so far so good 3/4 are working and 1 works but is -10db on spectrum
not bad for $50 each!
Offline 9aplus
« Reply #72 on: March 01, 2015, 10:45:10 am »
You are running 1.4.2 on windows ?
Which one ? My try on Win 7 no luck....
How do you run remote gui on Win os?
Offline Urs42
« Reply #73 on: March 01, 2015, 05:31:31 pm »
Do you have the A or B model? The range of the E7495B goes from 10MHz to 2.7GHz, but the preamplifiers only go down to 375 MHz. 10MHz is written on the front panel, but i can enter frequencies down to 500KHz.
Offline ldhn1uec
« Reply #74 on: March 02, 2015, 03:00:39 am »
i have the 7495A. the spectrum analyzers go down fine, the swr bridge/return loss port will not go below 375m
as far as the gui, you need to uninstall java completely, go to the java site archives and get the 1.4.2 java package and install it. then the gui parts work fine. when i get round to it i may try 6.
attempted to swap lic&hostid files with no luck. seems to be more involved. may try the patch listed above.
Offline 9aplus
« Reply #75 on: March 02, 2015, 03:48:24 pm »
Regarding sensitivity of E74 on low freq...
Last night have tuned down on AM 0,5-1,6 MHz band, result lot of AM carriers - not good....
Therefore just made small test by joining E7495B with FT-817 (Yaesu), same LW antenna with N 1 to 2 switch.
Conclusion is what 817 hear that E74 can "see". Must try also on 3,79-3,80 MHz DX window
during the night or early in the morning (gray zone) too but for day time here is 14.070 MHz PSK stream.
« Last Edit: March 02, 2015, 03:50:08 pm by 9aplus »
Offline Aleuli
« Reply #76 on: March 02, 2015, 07:38:01 pm »
The E7495 does have a higher noise floor bellow 375Mhz(~37dBm more). This is due to internal Pre-AMP limits.
http://www.keysight.com/owc_discussions/thread.jspa?messageID=106466
« Last Edit: March 02, 2015, 07:41:37 pm by Aleuli »
Offline LogicalDave
« Reply #77 on: March 20, 2015, 05:02:34 pm »
I have an E7495A and an E7495B.  Does anyone know:
1) What the latest firmware version is for each and where to download it?
2) Where replacement batteries can be purchased at a reasonable price?
Thanks!
Online PA0PBZ
« Reply #78 on: March 20, 2015, 06:25:42 pm »
Go here http://www.keysight.com/main/facet.jspx?&cc=US&lc=eng&k=E7495A&sm=g then drivers, firmware & software on the left
« Reply #79 on: March 26, 2015, 06:18:29 am »
The batteries are made by Inspired Energy, the original model number is NI2040AG (if it carries the Agilent label) or NI2040MG (if it carries the IE label). There are now variants with larger capacity:
http://inspired-energy.com/standard_products/NI2040/NI2040.htm
In the UK, they're sold by Accutronics:
http://www.accutronics.co.uk/inspired_energy_batteries/ni2040hd24.html
http://www.accutronics.co.uk/inspired_energy_batteries/ni2040ed29.html
« Last Edit: May 02, 2015, 07:49:01 pm by Wuerstchenhund »
Offline The_Hari
« Reply #80 on: May 02, 2015, 11:16:59 am »
Hello Everyone,
I have an e7495a from ebay and i'm very happy with it.
My Questions are:
1. Is it possible to use SCPI over Lan?
2. There is also a Webserver, it asks for a Password but the root-or guest-password doesn't work.
3. Anyone an Idea, how to add other Modulations to the Generator?
Thx to Alll for the nice Work on this Device till now  :-+
Offline duggerd
« Reply #81 on: May 26, 2015, 04:43:17 pm »
I bought one of these a few weeks ago, and through my searching around I have found the service manual for it, as well as the latest FW. The FW is the same for both the E7495A and E7495B models.
Service Manual: https://www.w35ktn5.com/share/e7495serv.pdf
Latest FW (A.06.25): https://www.w35ktn5.com/share/full625.zip
The service manual details the installation of the FW as an upgrade (just unzip to a CF or PCMCIA card) and insert before boot. Then confirm the upgrade using the OK button.
You can also do a fresh install by instead of pressing OK at the upgrade screen, press the bottom button on the right hand side of the screen, the one directly opposite the screen from the NO option on the analyzer.
« Last Edit: April 22, 2020, 04:11:27 pm by duggerd »
The following users thanked this post: BravoV, HandBuilt
Offline The_Hari
« Reply #82 on: May 26, 2015, 11:09:13 pm »
Thank you very much
Feels a little bit faster with the new Firmware  ;)
My next Step will be a self-made Battery, because an original one is way too expensive.
Offline duggerd
« Reply #83 on: May 26, 2015, 11:12:35 pm »
Thank you very much
I was just going to make a battery that attaches to the back of the instrument and connects using the existing DC barrel connector.
It would be interesting to make some batteries that use the SMBus protocol that are not the rare ones that it comes with. You could probably do it with some lithium primary cells and 3D printed endcaps along with a little controller board.
It would probably be cheaper than the $200 that the replacement batteries are going for, even for one-offs.
Offline realcastle
Re: Agilent E7495 linux root account and n1996a
« Reply #84 on: June 09, 2015, 10:06:28 pm »
Hello everybody
In find very interesting this approach of Agilent E7495 ,specially getting access into ARM LINUX system as root.
My problem is on CSA n1996a ,it works very well as guest-TELNET using "noname " password , but unfortunately
telnet as root can not login using the E7495 "wh1skers" password.
Could someone help me?
Thank you. :)
Offline cepillo
« Reply #85 on: June 10, 2015, 01:39:26 pm »
Does anybody can help me with the password?
« Last Edit: June 10, 2015, 01:42:15 pm by cepillo »
Online PA0PBZ
« Reply #86 on: June 10, 2015, 01:42:26 pm »
There's probably nothing behind there, at least on the N1996A there's nothing.
Offline cepillo
« Reply #87 on: June 10, 2015, 03:00:22 pm »
Thanks for the response.
The reason is I can't save (download) the collected data.
I don't have PCMCIA and CF card and readers (or adopters).
According to the Guid :
 -Two RS 232 (DB-9) (reserved for future use)
 -Two USB 1.1 (reserved for future use)
 -One LAN Port 10 Base T
 -PCMCIA Card slot
 -CompactFlash memory (type 1 & 2)
Is USB working after version upgrade?
Offline realcastle
« Reply #88 on: June 10, 2015, 05:43:04 pm »
Thanks to    PA0PBZ
My  CSA n1996a, FW :A.02.07 works full options ! The USB mount and transfer method very simple.
As hex editor I have an Octeta on a Linux MINT OS.
Best regards !
Offline wavebits
« Reply #89 on: July 04, 2015, 07:21:11 pm »
Thanks to everyone that has contributed to this interesting thread..  It looks to be a pretty cool instrument that has some hacking potential.
I just picked up a E7495B from fleabay and have been playing a bit. The original firmware as received was v6.10 which I upgraded with the 6.25 fw from the link in this thread. I was able to telnet into the device and back up the /flash directory to CF first. One thing I am noticing I did not appreciate before the update is a periodic hesitation in the SA display; once about every 10-12 seconds there is a about a 1 second pause in the display response. It is fairly subtle but definitely there. Has anyone else noticed it?
My unit has the 510 complex signal generator. It seems to be a pretty common option.  It sure would be great to get some conventional FM modulation from the SG to provide partial "service monitor"  functionality for testing analog FM radios and repeaters . It can generate QPSK signals for IS95 forward and reverse links so one would guess the hardware may be capable of conventional FM or at least PM modulation with it's internal ARB. Any thoughts?
Even better would be the ability to add more digital modulation modes like P25 and DMR.  That would make it really useful.
Dave, K7DMK
Offline Urs42
« Reply #90 on: September 16, 2015, 11:53:44 am »
Hi wavebits
I did find the data files for the complex signal generator on the device, i think you can find them in
The Content of this Directory:
Size   Filename
788K 1xEVDORev4608ArbPlayback1.bin
788K 1xEVDORev96ArbPlayback1.bin
788K 1xEVDORevArbPlayback1.bin
 12K C2KRevFundamentalRandomPayload.bin
 12K C2KRevFundamentalZeroPayload.bin
1.4M iDENInOneSixthArbPlayback1.bin
 12K IS95RevAccessZeroPayload.bin
 12K IS95RevTraffic144FixedPayload.bin
 12K IS95RevTraffic144ZeroPayload.bin
 12K IS95RevTraffic96FixedPayload.bin
 12K IS95RevTrafficRandomPayload.bin
 12K IS95RevTrafficZeroPayload.bin
The Data is sent to the signal generator over a serial interface. I think that it should be possible to replace those Files. I'm not sure about renaming the menu options on the Device, i think you would have to recompile the gui .jar file to do that.
Offline ve7xen
    • VE7XEN Blog
« Reply #91 on: September 17, 2015, 06:13:19 am »
Hi guys, thanks for all the hard work on this SA! I've just picked one up in good working order and have been playing around, seems like an excellent unit for the money I paid.
I intend to do some more poking around at this box over the coming weeks and will post my findings here.
For now I have mirrored some of the useful files on my web server in case they ever disappear (as the firmware updates apparently have from Agilent's site...): http://www.gotroot.ca/e7495/ . Many thanks to those who found them.
73 de VE7XEN
He/Him
Offline TheSteve
  • Living the Dream
« Reply #92 on: September 17, 2015, 06:20:12 am »
Excellent buy - did you pick the one up that has been for sale on CL locally(Burnaby) for a while now?
VE7FM
Online uski
« Reply #93 on: October 08, 2015, 03:07:30 am »
Hi
Does any of you have the latest E7495B firmware update files ? They seem to have disappeared from Agilent website...
Also, do you know if there are some hardware options or all options user installable ?
Thanks !
Offline ve7xen
    • VE7XEN Blog
« Reply #94 on: October 08, 2015, 03:08:49 am »
Hi
Thanks !
See my post two up from you...
73 de VE7XEN
He/Him
Online uski
« Reply #95 on: October 08, 2015, 03:26:02 am »
Thanks for the firmware !!!  :-+
Do you know about the options ? Specifically is it possible to install option 240 if the unit didn't come with it ? (question before buying, I can't try...)
Offline ve7xen
    • VE7XEN Blog
« Reply #96 on: October 08, 2015, 03:28:13 am »
Yes, all the software options are hackable pretty easily. Read the thread, you need to hex edit one file and maybe fiddle around a bit.
73 de VE7XEN
He/Him
Online uski
« Reply #97 on: October 08, 2015, 03:34:56 am »
Thanks. Wasn't sure if 240 was a software or hardware option.
EDIT: Here's the list of hardware vs software options from the service manual :
« Last Edit: October 08, 2015, 08:26:29 pm by uski »
Offline 9aplus
« Reply #98 on: November 06, 2015, 04:48:09 pm »
Over the time of approx 10 months my unit LCD developed delamination / deterioration
See both up left and bottom corners, and switch off picture of left up, it is between LCD layers...
Unit was stored over the summer in original bag within dark & dry and temperature was never more than 30-32 o C
This is the same unit picture from FEB 2015.
Unit is still good for use, but
now looking for spare screen
or whole broken unit with good LCD  :-BROKE
PS any lead on LCD type and producer is much appreciated  :-+
« Last Edit: November 07, 2015, 08:24:56 am by 9aplus »
Offline 9aplus
« Reply #99 on: November 08, 2015, 03:58:39 pm »
LCD Info from OM Serge @ HP/Agilent-Yahoo group
It's a 10.4" VGA LCD from NEC:
NL6448BC33-50
« Last Edit: November 08, 2015, 06:22:45 pm by 9aplus »
« Reply #100 on: November 09, 2015, 04:16:20 pm »
Offline 9aplus
« Reply #101 on: November 09, 2015, 08:39:14 pm »
Tnx @Wuerstchenhund
Have located few sources, prices going from USD200 to 380Euro
Just must first open my unit to verify model, just to be on safe side.
Offline jwm_
    • Not A Number
« Reply #102 on: November 10, 2015, 08:02:52 pm »
My LCD is undergoing the exact same thing, except is more further along than yours. Unit still works properly, but a good cm of the corners are now gone.
It almost looks repairable, like a gasket or something is being pushed over the lcd or behind the backlight. Have not tried to dissasemble it yet though.
Offline sportq
« Reply #103 on: September 01, 2016, 10:34:46 am »
I just got one of these, an E7495A with all the hardware options except E1 tester. I tried to follow the instructions in post #22 to patch the /flash/egServer/elgato binary however it doesn't seem to work. In fact when I try to go to page 2 of 2 of the SYSTEM menu the device hangs. I've put it back to the original binary and the menu works again. Is there anything else that needs to be modified? It mentions editing the ]tt]elgato.lic[/tt] file but it's not clear what should be done. I'd really like to enable option 300, the DC Bias output.
I've also downloaded the Debian Woody (3.0) ARM iso to get some useful Linux binaries. So far I've extracted and tested busybox  :-+ to test the process but I'll make an archive of useful ones (sshd would be great if it works). If any owners want something specific, let me know.
Lastly, I've contacted Keysight to see if they will release the Linux kernel .config file. It's a while since I hand-rolled a kernel but I'm sure I'll manage it. USB storage support would be very useful, even if it's only 1.0 (12Mbit/s).
Peter
Online PA0PBZ
« Reply #104 on: September 01, 2016, 10:48:22 am »
Hi Peter,
Do you have the correct firmware version? The patch is for version A06.25.
Did you find the to change bytes to be the same?
Offline sportq
« Reply #105 on: September 01, 2016, 10:54:13 am »
Yes, sorry, I should have said, I upgraded to A.06.25 via the link above and the bytes to be changed matched exactly. I reloaded the modified binary into the hex editor to check they had changed too.
Pete
Online PA0PBZ
« Reply #106 on: September 01, 2016, 10:59:08 am »
If your hex editor didn't do anything weird to the file like inserting the bytes and not overwrite them (file length still the same? Can you run a compare?) then the only other thing I can think of is that there is something strange in your license file that is causing this. Can you post the contents, or maybe PM me if you don't want it exposed to the world...?
Offline Urs42
« Reply #107 on: September 01, 2016, 11:42:20 am »
Or send us the MD5 sum of the original and modified file
I think the modified version should have the md5sum
f05c12d848c7faf8866359ae33e1cfec elgato.patch
7e7736a973cccb6b131f803e7f92dcac elgato.orig
I'm not 100% sure about the two checksums, i'm at work and my computer at home not on.
Offline sportq
« Reply #108 on: September 01, 2016, 11:54:43 am »
I'm away from the device too, I'll post the checksums later. Thanks for all your help.
One other interesting observation the processor board has an IrDA port but I don't think it's available on the case. There's a script to start it in /etc/
Peter
Offline sportq
« Reply #109 on: September 01, 2016, 08:06:07 pm »
Confirm the md5 checksum:
$ md5 elgato.mod
MD5 (elgato.mod) = f05c12d848c7faf8866359ae33e1cfec
... and both the original and modified files have 5165908 bytes.
Peter
Offline DogP
« Reply #110 on: October 22, 2016, 10:52:27 am »
I recently grabbed one of these (E7495A)... Thanks for all the work everyone's put into it so far.
I've been having fun with it, like most of us in this thread. :)  I rebuilt one of my battery packs, and got it running my own waveforms... so I'll post that stuff when I get some time tomorrow.
I'm seeing the exact same thing... did you ever work it out?  What I've noticed is that the options actually work (i.e. other tests, waveforms, etc. show up and are usable), but going to pg. 2 of the system menu causes it to hang.  I'm curious whether it's something to do with E7495A.  I upgraded my firmware to 6.25 as well.
BTW, I'm pretty sure the DC Bias option is only supported on the E7495B.  I tried removing it from my .lic file, just in case that was the problem, but it didn't fix it.
Can anyone else that has the modified file confirm that they're able to access pg. 2 of the system menu?  Are you running an E7495A or E7495B?
Thanks,
Pat
Online PA0PBZ
« Reply #111 on: October 22, 2016, 11:45:59 am »
... going to pg. 2 of the system menu causes it to hang.  I'm curious whether it's something to do with E7495A.  I upgraded my firmware to 6.25 as well.
So this only happens after you patch the elgato binary? What if you replace the .lic file with an empty one or just one option?
Edit: Please PM me your original .lic file. I found a problem with the one sportq was using and we solved it.  :)
« Last Edit: October 22, 2016, 11:48:46 am by PA0PBZ »
Offline DogP
« Reply #112 on: October 22, 2016, 12:12:05 pm »
Yeah, it's just with the patched binary... but I got it working.  I just had to add SIGN=000000000000 to the end of the lines.  It seems that the license page barfs without some SIGN value for features it has.
Thanks,
Pat
Offline sportq
« Reply #113 on: October 22, 2016, 12:16:55 pm »
Pat, really interested in the waveforms you've created. What are they? FM and AM would be useful but I'm not sure there would be any control over the modulation parameters.
Pete
Offline DogP
« Reply #114 on: October 22, 2016, 07:55:48 pm »
Currently, I've just been making test files... mostly offset CW to make sure I understand the format and specifics of how it works.
It's not a great signal generator... for most modulated signals (arbitrary and internally generated), it looks like they're simply mixing a 60 MHz IF with an LO (at the desired frequency + 60 MHz).  So, the desired signal, LO, and an image are all very strong.  The one signal (iDEN) looks like they're using a 24 MHz IF, but probably still at the same internal sample rate or something, as there are images 12 MHz off from the desired and upper image (one being up 60 MHz from the desired freq).  So, if you just need a signal present in a narrow bandwidth it's fine, but without a suppressed carrier or images, it's not a very good general purpose generator.
It's also not very flexible.  If you change the size of the file, it looks like the software knows that it needs to process more or less (generating takes shorter or longer), but when it actually plays it, it's always the size of the original file.  I'm guessing it writes the file into RAM of the signal generator depending on the actual file size, and then tells the generator to play a hardcoded size depending which "file" you're playing.  So, if you give it a file smaller than the original, you can see it play your file and then the end of whatever file you played before that... and a longer file never plays anything beyond the size of the original file.
The files are also short.  The 1xEVDORev bin files are all only 80ms long, and the iDENInOneSixthArbPlayback1.bin file is 1.44 seconds long.  The "Arb" in the name means that it's an arbitrary waveform... the other files are basically just parameters to use to make the signal (for example IS95RevAccessZeroPayload.bin is just 12KB of 0s... obviously not an actual waveform file).  Those non-Arb waveforms look like they may be generated and uploaded to the signal generator in a similar way though, so it may be possible to write your own program on the box to generate and upload your own waveform... if you can figure out the interface/protocol.
The file format for the Arb files is simply a complex (interleaved I and Q) signed 16-bit integer (no header or anything).  The integers are little endian, and it's I then Q (i.e. bytes 0 and 1 are I, 2 and 3 are Q... and so on).  The EVDO files are 2.5Msps and the iDEN file is 250Ksps.
Attached are some screenshots of various signals (simply cabled between RF Out and RF In).  The selected output frequency of all of them is 2 GHz.  The 10k file is a tone at +10 KHz, the 50k file is a tone at +50 KHz.  I tuned the spectrum analyzer to 2 GHz for the close-in views, and to the LO frequency for the wide views.
I also attached those files in case you'd like to try them out.  Simply copy them to the signal directory and rename them to the desired file name (50k is for an EVDO file, 10k is the iDEN file) and select it in the signal generator to play them back.
If anyone can figure out how to make the generator play different length files, that'd be great.  It seems to fail generating files larger than ~2MB, but even so, a 2 second 250Ksps (or 200ms 2.5Msps) file, remapped to a CF card instead of internal flash would be pretty nice.
Pat
Offline DogP
« Reply #115 on: October 22, 2016, 11:14:46 pm »
Here are a bunch of pics from my battery pack rebuild.  It's a 9 cell 18650 pack, with SMBus, fuel gauge, protection, etc.  I'll try to go through the process, and mention any gotchas as well.  But first of all... let me start by saying I've never rebuilt an 18650 battery pack, and I don't own a battery tab welder.  So, I bought batteries with tabs already attached, so I could solder to them (soldering directly to 18650s is hard, and the heat isn't good for the battery).  The battery tab welder would have made things quicker and easier though.
The obvious things: safety first... lithium batteries hold a lot of charge and can be dangerous, catch fire, etc.  Pay attention to battery polarity, and don't attempt this if you don't know what you're doing.
I chose the HyperPS brand batteries, with tabs attached, which were <$3 each shipped on ebay (these: www.ebay.com/itm/272359448176 ).  They claim guaranteed >2600mAh, but suspicious of unknown brands, I made sure to test them in my BT-C3100 charger/tester before building the battery pack.  These actually tested quite well, >2800mAh each.  In case you don't know, fake 18650 cells claiming ridiculously large capacity (6000mAh, 9800mAh, etc) are all over the place, and generally they are actually junk (<1000mAh).  A real 18650 will generally be around 2000-3000 mAh.  The original batteries were MOLI FSPE.70037 (ICR-18650G), which were 2000mAh cells.
GOTCHA: make sure the length of the new cells are close to that of the original cells (~65mm).  The original cells are unprotected, so you'll probably want to stick with unprotected cells, as the protection circuit generally adds a little bit of length, and there isn't a lot of extra room.
To open the pack, peel back the short side of the label (or cut it, though if you leave it in one piece, it works well to hold the pack together).  Go around the edge of the pack with a knife to crack the small dots of superglue holding the plastic pieces together at the edges.  You can also crack the glue by twisting it like you're popping ice cubes out of a tray.
GOTCHA: the pack was assembled in the bottom half (side with the battery contacts), and then some RTV was put on top and closed up.  You want to disassemble it in the reverse order.  If you pull the pack out of the bottom (like I did), it'll bend the battery contacts and rip the LCD cable (I ended up replacing it with standard 0.05" ribbon).  Instead, you should open the pack by prying the top from the batteries.  Then, once the top is open, lift the pack straight out of the bottom.  Clean out any large globs of RTV from the case so they don't interfere with the fit of the new cells.
Once it's out, desolder the two tabs from the PCB, undo the Kapton tape holding the fuses, and cut the metal strips connecting the fuses to the batteries (leaving as much of the strip as possible, as you'll probably want to reuse it), and remove the PCB and fuses.  Once that's removed, you can pop apart the original pack and see how it's connected... it's 3 series packs of 3 batteries in parallel.  You'll want to start by assembling your 3 parallel battery packs.  If using the solder kind, rotate the tabs so you're soldering away from the center of the battery, so it'll solder easier, and apply less heat to the battery.  Make sure the tabs also line up on all packs, so they're easy to connect in series.  The battery pack is tight, so try to keep the solder fairly low profile.  Once they're all assembled, drop them in for a quick test fit.
Next, you need to add the tabs that go to the PCB.  Look at their placement on the original pack, and try to get it as close as possible on the new pack, so the PCB will fit properly.  I added Kapton tape between the packs, so all current will flow through the tabs... though that's not very important, as they're connected in series anyway.  I then soldered the tabs between packs together and slipped a piece of heatshrink over them and taped them down with Kapton.  I then transferred over the tape from the old batteries to the new ones for the boards and fuses, and put a few pieces of Kapton over the pack to keep it held together.  I desoldered the red and black wires from the PCB (so the PCB was completely out of the way), and connected the fuse tabs to the tabs on the ends of the pack, and cut off any extra tails.  I then put Kapton over the ends, since there wasn't enough room in the pack for the cardboard endcaps that were on the originals.
This gives you batteries fully assembled, with a red and black wire and two tabs sticking up.  Then solder the red and black wires to the PCB and press it down over the tabs and solder the tabs.  Then carefully drop the entire pack into the bottom of the shell, making sure the battery contacts go straight into the slots.  You may need to pry the plastic back a bit on the LCD end to pop the LCD in place.  Then with a multimeter, make sure you have around 11V across the points where you soldered the red and black wires.
Finally, temporarily close the lid, slide it into the E7495, and make sure it's functional before permanently closing it up. Once you know it works, I'd put a few dabs of superglue around the plastic shell, pull the label tightly over the shell and seal it up (the label should still be tacky, but will probably need a bit of glue/adhesive for a permanent seal).
The battery fuel gauge will be wrong (mine said 0% when it started, even though it already had a half charge), but after a full charge and discharge, it figured itself out.  There's an option to refresh the battery on the E7495 (automatically charges, discharges, and recharges), though it didn't work for me (it never completed because the gauge never showed that it was fully charged).
Anyway, I hope this helps... or convinces you to just spend the $200 on a new one. :-P
Pat
« Last Edit: October 22, 2016, 11:19:34 pm by DogP »
Offline TheSteve
  • Living the Dream
« Reply #116 on: October 23, 2016, 12:30:47 am »
Nice rebuild of the battery. I need to find some cheap/free packs from the 7495's big brother the N1996A to rebuild. I rarely want to run it on batteries but once in a while it could be handy.
btw for anyone doing a battery rebuild like this be sure to start with all cells having an equal charge status.
VE7FM
Offline smgvbest
    • Kilbourne Astronomics
« Reply #117 on: October 23, 2016, 01:20:31 am »
Thank you for the battery rebuild,   that will come in very handy.  I've got one battery going thru the recondition now and the other no so healty so this is great timing.
Also thank you for the hack to enable options.   I don't have the HW for Opt 500 or the E1/T1 options but every thing else enabled just fine.
Does anyone know how to get to a self test screen or if it even has one?
Sandra
(Yes, I am a Woman :p )
Offline DogP
« Reply #118 on: October 23, 2016, 01:45:44 am »
Ah, yes... good call on the charge status.  Another note... according to the manual, the E7495 heavily drains batteries even when turned off.  It says 18% per day, just to monitor for the power button :palm: .
I know what you mean about batteries though... plugged in is nice on the bench, but laziness usually gets the best of me, and not having to find an outlet somewhere else makes me more likely to use it.  That's why I've got a battery powered oscilloscope as well.
Oh, somewhat related... I tested the batteries I pulled from the original MOLI battery pack.  One battery was shorted, which drained all 3 of those connected cells to 0V and ruined them.  The other 6 actually tested good, between 1700 and 1900 mAh.  So, I'll keep them around for future projects where a mediocre used cell will work fine.
Under system->pg. 2->service->verification there's a display and button test... but it's not much of a self test.  I'm not aware of anything like a memory, etc. test.
Pat
Offline DogP
« Reply #119 on: October 23, 2016, 10:42:14 am »
For anyone interested in making your own waveforms, but not really sure where to start... here's a quick tutorial for making a compatible FM file in Octave (should work in MATLAB too).  You'll need the communications package installed (I believe you'll need the communications toolbox for MATLAB).
I'm using the piano2.wav file from this page: http://www.kozco.com/tech/soundtests.html as an example.  Below is the code... first you read the wav file, resample it from 48Ksps (audio file sample rate) to 250Ksps (iDEN file sample rate), and take just one channel of the stereo file (and rotate the matrix).  Then you FM modulate it to a complex baseband signal.  Then to get the signal ready to output, you need to scale it to full 16-bit integer scale, shorten it to 360000 samples (length of original iDEN file), and break the real/imag part of the complex signal into seperate columns of the matrix (for fwrite to output properly).  Finally, simply open the file for writing, write the file, and close it.  Then copy it to your E7495, put it in place of the iDEN file, and test it out!  The process is basically identical for the EVDO signals, except they're 2.5Msps, and only 200000 samples long.
pkg load communications
piano=wavread("piano2.wav");
music=resample(piano(:,1).', 250, 48);
fm=amodce(music, 250000, "fm", 7500);
cp_fm(1,:)=real(fm(1:360000))*32767;
cp_fm(2,:)=imag(fm(1:360000))*32767;
myfile=fopen("fm_music.bin", 'w');
fwrite(myfile, cp_fm, "int16");
fclose(myfile);
Of course the E7495 doesn't go down to the normal FM broadcast band (only goes down to 375 MHz), so I used an RTLSDR dongle with SDR# to demodulate the FM at a frequency it could work at, to verify it worked.
Pat
Offline DogP
« Reply #120 on: October 26, 2016, 06:40:44 am »
Does anyone know what the actual differences are between the E7495A and E7495B?  I know the front panel of the E7495A says 10MHz-2.5GHz and E7495B says 10MHz-2.7GHz, but as far as I can tell, both have the same frequency ranges (spectrum analyzer goes from 500KHz to 2.7GHz, antenna/cable analyzer and signal generator goes from 375MHz to 2.5GHz).
The only differences I've found (though can't confirm since I don't have both to actually compare) are that the B has the DC Bias option, the signal generator has slightly higher maximum output power for most signals, and accepts more external reference frequencies.
Did the B come out after the A and have an upgraded CPU, memory, flash, or anything like that?
BTW, I did some more testing on waveform files, and it appears that the largest file it'll fully process is 2MB (corresponds to 200ms @ 2.5Msps, or 2s @ 250Ksps).  I haven't gotten it to actually play any longer than the original file length though.
Thanks,
Pat
Offline DogP
« Reply #121 on: November 02, 2016, 05:48:59 am »
I've noticed a few strange things with my E7495A... can anyone else confirm that these are or are not normal, and that your box does what would seem "normal"?
1) Fairly regularly when I turn the box on from the off state, the screen lights up, then fades to black, but it doesn't actually boot (nothing shows on the screen at all).  I press the power button again to turn it off (either off or standby), and then press it again, and it boots fine on the 2nd attempt.  It doesn't look like it's an LCD issue... it looks like it's just not booting (it never connects to the network, when it does come on it goes through the full boot process, etc).
2) When I connect a GPS antenna with a good view of the sky, I easily get GPS (bottom left says GPS Locked), location usually shows ~8 satellites tracked, but the GPS icon in the bottom right never goes to the green dot (I've left it tracking for over 24 hours).  It always stays at the yellow triangle.  Because of that, I can't run the Time Base Adjustment (it requires me to wait for the green dot).  Switching to the internal reference shows a green dot, and the frequency accuracy seems pretty good, so I don't think the TCXO is bad.
Also, I noticed that it shows time on the screen, but it never gets set to the correct GPS time (and it appears that the time/date gets reset to the time/date that was set at boot every 30 seconds, even if I manually set it over telnet).  The GPS location looks correct though (drops a dot right on my neighbors house :-P ).
3) I rebuilt my 2nd battery pack, and like the first one, going through the battery recalibration procedure never finished.  It says that it'd take up to 12 hours, and on the first battery I left it running for almost 2 days and it never finished, so it aborted... on the 2nd battery, I left it running since I rebuilt the pack on Friday night... so almost 5 days.  I finally aborted it tonight.  The battery voltage was slowly creeping upward around 12.4 (going up around 10mV per day) but never hit 12.6V (4.2V per cell)... not sure if it didn't think it was done because of that, or something else.  It almost always showed 0 mA current.  The percentage shown is usually 99%, though it sometimes bounces down to 98% or up to 100%.
The battery life seems fine (~1.5 - 2 hours per battery), so I'm not too worried about it... just seems strange (and my OCD would like that fuel gauge error to say 0%, not 10% ;) )... I also tried just running the batteries down and recharging them normally, but that didn't make a difference.
Related to that... the 2nd battery rebuild went smoother than the first.  I'll update my rebuild post above with a couple more notes/pics.
BTW, I did a fresh firmware install of 6.25 (pressing the bottom right button, across from NO), and it didn't make any difference.
Thanks,
Pat
« Last Edit: November 02, 2016, 05:53:31 am by DogP »
Offline TheSteve
  • Living the Dream
« Reply #122 on: November 02, 2016, 06:15:30 am »
Are you using the factory power adapter? Does the unit always boot first try with the batteries removed?
VE7FM
Offline DogP
« Reply #123 on: November 02, 2016, 07:57:42 am »
I'm using an aftermarket power adapter... actually, I've tried two different ones (one of them is a generic 24V 5A supply, the other is a universal 19.5V laptop power supply).  Unfortunately, it's not something that I can reliably reproduce.  I was able to get it to happen running from battery only, with the 24V supply with a battery installed, and with the 19.5V supply and no battery installed.
Not sure if it's a temperature, cap, etc. issue... I assume it's not normal, but wondering if anyone else has run into this issue.
Thanks,
Pat
Offline jwm_
    • Not A Number
« Reply #124 on: November 05, 2016, 03:00:19 am »
Anyone figure out a fix for the screen bezel coming undone? The system works fine, but part of the screen is obscured. Picture attached
Offline DogP
« Reply #125 on: November 05, 2016, 09:13:33 pm »
If you look at the service manual, there's a detailed procedure for removing and disassembling the display.  Pg. 111 removes the front panel from the unit, and pg. 145 removes the display from the front panel.  Once there, it looks like the gasket is accessible (MP29).
Pat
Offline DogP
« Reply #126 on: December 08, 2016, 11:54:09 am »
I spent a bit of time looking at this again, trying to get some remote access/control working.  As noted earlier, the E7495 has a webpage, but doesn't accept the normal login.  I noticed a similar non-working login on port 5025.  Using netstat, I saw that elgato was listening on those ports.  When looking in the /flash/egServer directory, I noticed a passwd file.  It looked different than the standard *nix passwd file, but appeared to have a hashed root password in it (RzSdSbSdye).
Rather than trying to crack the password, I decided to try simply renaming the passwd file and rebooting.  Surprisingly, it didn't recreate it, and now simply accepts any login! (on both the webpage and port 5025).
The webpage has a bunch of configuration stuff, though the coolest thing seems to be the "Transducer I/O" section.  For example, if you click "Active STIM" you can select 16 (Spectrum Analyzer), and then go to the "Channel I/O" page and click "Array" under Channel 1 to get the spectrum data.  You can set parameters, etc. as well, which get set using http POST.  I'm not really familiar with it, but I believe this is IEEE 1451 standard stuff.  Maybe there's a way to tell elgato to do these operations directly, rather than through http.
Port 5025 now accepts any login as well, though I was hoping it'd be SCPI (commonly on that port)... instead, it looks like it's something called the "DMC Shell".  Typing "help", it says "The Dmc Shell accepts "C" like function statements and assignments" and gives some examples... not sure how useful it is.
I also took a look at the remote GUI... it didn't seem to work on Windows with Java 8 (even using the commands further up in the thread).  Rather than dig into it, I installed Java 1.4.2 in a VM, grabbed the jre directory, and explicitly ran RemoteGui.jar using that version of java ("jre\bin\java -jar RemoteGui.jar").  By doing that, the remote GUI worked first try.
I was interested in how it communicated, so I sniffed the packets.  It looks like most stuff goes over port 5028.  The commands and acknowledgements go over TCP, and the spectrum display data goes over UDP.  It looks like there’s some status (power, GPS, etc) coming out 1027 as well.
I had to make sure Windows allowed the data through the firewall (without it, the TCP commands would go through, but the UDP data wouldn’t, so the GUI would never show the spectrum).  Also, Windows 7 temporarily goes back to basic graphics (disabling Aero) when you run Java 1.4.2.
The commands going over 5028 don't look to be any standard I'm familiar with.  Some examples are (without the quotes, <\n> is hex 0A): “cmd: local<\n><\n>”, "cmd: set<\n>topic: display.global<\n>printFilter: 0<\n><\n>", etc.  If you dig through the elgato binary, you can see a bunch of available commands (and you can test them out using nc).
Oh, and I quickly glanced at the decompiled egclient posted earlier in the thread... if you look in the manufacturing directory, it appears that there’s a Snake and Tetris game, seemingly in a hidden menu on the Display Test screen.  It wasn’t immediately obvious how to access it though.
Pat
Offline DogP
« Reply #127 on: December 09, 2016, 08:28:41 am »
Heh, it bugged me having games on here that I couldn't get to, so I tracked it down. :-P
Though the code has it with the DisplayTestScreen stuff, it really doesn't have anything to do with that.  To get there, you click the Spectrum Analyzer / Tools menu, then quickly click the bottom right display button 3 times.  Then the "Extras" buttons pop up with Tetris and Nibbles.
DogP
Offline TheSteve
  • Living the Dream
« Reply #128 on: December 09, 2016, 08:50:49 am »
Nice find!
You can enable the same web login etc on the E7495's big brother, the N1996A by renaming the /flash/toroServer/passwd file.
VE7FM
Offline DogP
« Reply #129 on: December 10, 2016, 10:38:12 am »
Here's a quick (and kinda pointless) mod... I didn't really like this being called a "Base Station" test set, since it's never gonna test another base station in its life. ;)  So I opened up the egclient JAR file (with 7-zip), and replaced the cell tower background with a generic modern Agilent background (that they use on their documentation, etc... grabbed from: http://eprocurement.agilent.com/ ).  I also got rid of the "Base Station" text.  It's just a matter of modifying the ModeScreen.jpg and ModeScreen_overlay-E7495A.png (-E7495B if you've got the B model).
The colors on the LCD aren't very accurate (it had a much greener tint than it should have), so I adjusted the hue/saturation a bit to get it kinda close to the original blue, and it turned out pretty good.
Oh, and something interesting I noticed... in the JAR file is a graphic for the an E7496A.  AFAIK, that doesn't exist... I wonder what the specs of that unit would have been.
Pat
Offline kirill_ka
  • Country: ru
« Reply #130 on: January 11, 2017, 10:49:17 am »
Thank you all for information in this thread. Because of it now I have a new toy (A model).
The "DMC shell" looks like some kind debugger. It knows functions and variables of elgato process. I don't think it's useful without source code.
Interesting thing I found that E7495 is supported by toro executable - N1996A server.
I guess, E7495 might be used during N1996A development when N1996 hw was not ready. Maybe E7496 = N1996.
Up to this point I got "toro" running on E7495 with some tweaking. It responds to SCPI and HTTP and looks quite healthy. toroGui starts but it might be useless due to keypad differencies.
Next thing is to deal with license file and options. Spectrum analyser refuses to work without license. I don't expect a lot, because toro doesn't handle E7495 as N1996.
We'll see...
« Last Edit: January 13, 2017, 08:21:31 am by kirill_ka »
Offline DogP
« Reply #131 on: January 12, 2017, 09:17:34 am »
Interesting thing I found that E7456A is supported by toro executable - N1996A server.
I guess, E7456 might be used during N1996A development when N1996 hw was not ready. Maybe E7496 = N1996.
Up to this point I got "toro" running on E7456 with some tweaking. It responds to SCPI and HTTP and looks quite healthy. toroGui starts but it might be useless due to keypad differencies.
Next thing is to deal with license file and options. Spectrum analyser refuses to work without license. I don't expect a lot, because toro doesn't handle E7456 as N1996.
We'll see...
Hmm... interesting!
I'm not quite sure I totally understand though... what is the E7456?  When you run toro, is that what it detects your E7495A as?  That's a good guess that maybe E7496 = N1996, since both pieces of hardware seem to be related.
Regarding toroGui, maybe you could run it over the network, like the E7495 remote GUI, in which case the keypad wouldn't be a problem (using a virtual keypad on the PC)?
Pat
Offline kirill_ka
  • Country: ru
« Reply #132 on: January 13, 2017, 09:08:37 am »
Typo... 95, not 56. Fixed that. toro detects E7495A as E7495A. There's a special option for it called GPSA. I see two separate option lists (E7495 and N1996) inside the executable.
Unfortunately that GPSA (= general purpose spectrum analyser) doesn't work. I mean it tries. It seems to load dsp program Dragonfly/Measurements/KernelBasic/Superfly/gpSpecAn  but fails to communicate with it.
"Basic" sectrum analyser (Dragonfly/Measurements/KernelBasic/Superfly/nSpecAn) works according to web page (Active STIM/Transducer IO), but SCPI and GUI both trying to use GPSA.
Now I'm out of ideas what to try. Maybe older N1996 firmware...
Anyway, if you want to try:
1. copy flash/toroServer from N1996 firmware A.02.07 to CF/PCMCIA formatted as ext2 (fat may work, I didn't try it)
2. change baud rate in toroServer/registry/df1.ini 921600 -> 230400
3. patch toro executable and add GPSA license option to license/elgato.lic
4. copy cals from egServer
5. copy Dragonfly/Firmware/E7495A and Dragonfly/Firmware/CPXSRC from egServer
If you don't copy, toroServer includes older firmware versions and tries to update. A bit frightening. It failed to update CPXSRC. After reboot elgato recovered the firmware, but it took some minutes to start.
6. copy Dragonfly/Receivers/comPort4 from egServer
Although, It didn't change anything.
7. killall _siege; /etc/rc.d/init.d/egServer stop
8. run toro from toroServer directory
Attaching output from toro.
« Last Edit: January 13, 2017, 10:05:36 am by kirill_ka »
Offline kirill_ka
  • Country: ru
« Reply #133 on: January 13, 2017, 09:24:01 am »
Debug log from GPSA.
That "waiting for getMessage(1000)" looks like a problem.
Offline kirill_ka
  • Country: ru
« Reply #134 on: January 22, 2017, 09:07:50 am »
I didn't see if it was mentioned, GSM analyser provides some time domain display. It's quite limited, but still usable. Bandwidth is fixed 500kHz. Frequency is in 200kHz increments, but config file can be tweaked for finer adjustments.
Here's analogue video signal caught from the air:
Offline kirill_ka
  • Country: ru
« Reply #135 on: January 25, 2017, 01:07:55 pm »
Length seems to be hardcoded in DSP program genIS95.
AFAIK debug log show what is passed to DSP. It's modulation type (4, 5, 6, 7 - separate value for each Arb file). And then the ARB file is written to DSP memory.
To get debug output:
1. Save settings (save state button) to <set>
2. Set debug parameter in registy/<set>/sourceStim.ini
3. connect to that DMC shell
4. activate <set>
5. play with generator
Debug output will appear in DMC shell.
Offline kirill_ka
  • Country: ru
« Reply #136 on: February 11, 2017, 09:45:24 pm »
I just noticed a weird thing. If I change sig gen amplitude in spectrum analyser mode, signal level jumps up about 25dB. This only happens if spectrum analyser runs in full span (500kHz-2.7GHz). Amplitude control still works, but signal level is higher than normal (i.e. at -50dBm setting, actual level is -23dBm). It recovers after suspend-resume cycle.
Offline technogeeky
  • Older New "New Player" Player Playa'
« Reply #137 on: February 27, 2017, 04:07:50 am »
I just picked up one of these for a bargain (partially broken / incomplete). The only known problem is a intermittent busted LCD screen. Since I don't necessarily plan to use it in a portable mode, I may not replace the LCD right away especially if I can get all of this PC-based GUI stuff working. The other problem I anticipate is that it seems like I am just getting the unit -- no accessories whatsoever. Maybe when the seller ships the backpack to me, it might have some items in it.
So, I have a slew of questions:
For reference, the unit I supposedly will have in a few days is:
Agilent E7495A Options:
  • 200
  • 205
  • 210
  • 220
  • 510
  • 600
  • 700
My current questions:
  • What are the minimum set of accessories I will need to test the unit, and test the self-calibration? It seems like I need rather specific cable lengths, specific Agilent-branded 10dB pads, etc. Can I get away with cheaper parts?
  • Does anyone know the full list of power sensors that will work with this device? It seems like there are only one or two.
  • When I entered the model and serial number on Keysight's site, the list of options did not match the advertised list, nor did it match the list on the metallic sticker shown in the auction. Does anyone know if this is normal? Is it possible that this unit was upgraded after initial selling? I know the sticker on the device says Agilent last calibrated it in 2013.
  • Does anyone know what kind of power supplies one can get away with? One of the manuals lists a range of voltages. I have a whole slew of power bricks, but I don't think I have a 24V 4A one. I don't have any batteries to charge, so presumably I don't need that much current anyway.
  • I doubt I have any PCMCIA flash cards. Do I need to buy a specific size? Like really, do I need exactly a 64MB one?
  • The service manual mentions an optional, internal 90dB attenuator. But I can't find any reference to this anywhere else. Do any of your units have this? Do all units have it? Does nobody have it?
I will no doubt have further questions, but for now I don't even have the device in hand.
Thanks in advance!
Offline DogP
« Reply #138 on: February 28, 2017, 08:19:10 am »
I'll try to take a crack at your Qs...
1. What are the minimum set of accessories I will need to test the unit, and test the self-calibration? It seems like I need rather specific cable lengths, specific Agilent-branded 10dB pads, etc. Can I get away with cheaper parts?
I don't think there's anything special about the ones supplied.  I'm personally using standard cables and attenuators, and a homemade short, open, and load.
2. Does anyone know the full list of power sensors that will work with this device? It seems like there are only one or two.
The manual specifies that it works with the 8481A, 8481D, and 8482A (and CFT variants).
3. When I entered the model and serial number on Keysight's site, the list of options did not match the advertised list, nor did it match the list on the metallic sticker shown in the auction. Does anyone know if this is normal? Is it possible that this unit was upgraded after initial selling? I know the sticker on the device says Agilent last calibrated it in 2013.
Got a link where you entered the info?  I can try mine and see if it's different as well... though I personally wouldn't worry what Agilent thinks you've got.  If you go into setup and read out your options, that's what you've got.  And if you hack the file described earlier in the thread, you can have all the software options. :-P
4. Does anyone know what kind of power supplies one can get away with? One of the manuals lists a range of voltages. I have a whole slew of power bricks, but I don't think I have a 24V 4A one. I don't have any batteries to charge, so presumably I don't need that much current anyway.
The manual states +9V to +25V DC (55W).  I've personally run mine from a 24V 5A supply (cheap Chinese power pack) as well as a universal 90W 19.5V laptop power supply.
5. I doubt I have any PCMCIA flash cards. Do I need to buy a specific size? Like really, do I need exactly a 64MB one?
I'm not aware of any limitations... I'm using an 8GB card in mine.
6.The service manual mentions an optional, internal 90dB attenuator. But I can't find any reference to this anywhere else. Do any of your units have this? Do all units have it? Does nobody have it?
If mine has it, I'm not aware of it.
Pat
Offline technogeeky
« Reply #139 on: February 28, 2017, 10:19:40 pm »
Well, I forgot an important question. I just got my unit today, so before I do something stupid...
  • Is the power supply center-pin positive? Yes*.
* I looked through this thread more carefully; it's 9-24V DC, somewhere between 3 and 5 amps; center-pin positive.
« Last Edit: March 01, 2017, 03:13:01 am by technogeeky »
Offline kirill_ka
  • Country: ru
« Reply #140 on: March 01, 2017, 02:08:08 pm »
I've read somewhere that 8484 should work. I got 8481D, but not tested yet - cable is on the way.
I use CF with CF to pcmcia adapter. Note that there's also CF slot (it works same as PCMCIA, but doesn't allow to close the door).
It's for signal generator (source). I think, it's included if it allows to change level to -90 dBm.
Offline kirill_ka
  • Country: ru
« Reply #141 on: March 01, 2017, 02:52:57 pm »
Here it is, ATTN OUT to J7/SOURCE IN connection.
Offline technogeeky
« Reply #142 on: March 04, 2017, 08:40:29 am »
Another few questions:
1) Is it possible to keep the power meter reference output on but go back to the spectrum analyzer window, to see it? Apparently this is possible to do with the signal generator, but not with the spectrum analyzer.
2) Does anyone have the Service Test software? By this I mean the software package that lets you test all of the functions of the device, as described in the service manual. Perhaps this is something which is on the machine but is not available until you login as root (or some other method to gain access)?
3) In terms of disassembly, what actions are likely to destroy any hope of keeping the calibration? E.g. can I (without automatic ruining of calibration):
  • Disconnect the internal flexible SMA connectors?
  • Disconnect the internal rigid SMA connectors (without bending the rigid cables)?
  • Open the various metal cans, while being ESD protected and latex gloved, but without noting torque values for the screws?
If you'd prefer, a qualitative assessment of what I can take a look at would be fine with me. I don't (yet) have a suitable torque wrench, so I don't think I'll be doing any of this until after I get one. But I've heard that it's common for these connectors to be overtightened from the factory, and presumably I wouldn't want to repeat that over tightening.
Thanks!
Offline DogP
« Reply #143 on: March 04, 2017, 10:52:52 am »
1) I don't think so, besides maybe manually poking a register under the hood somewhere to turn it on.
2) I assume you're referring to the "Agilent E7495A/B Performance Verification and Adjustment software"?  I've never come across it, and I don't think it's on the unit itself... I'm pretty sure that's PC based software, similar to this: http://www.keysight.com/en/pd-1000000762%3Aepsg%3Apro-pn-N2717A/performance-verification-and-adjustment?cc=US&lc=eng .  It seems like it's generally option 0BW, which includes service and calibration manuals and software, but I don't see this option listed for the E7495, so it may have never been available for customers.
3) I'd say you can open the case of the unit, but as soon as you disconnect ANY RF cable, you're going to ruin the calibration.  Maybe you'll get it close to original spec, but it'll likely change slightly, and the whole point of calibration is that the system is calibrated for those conditions.  Once it changes, you either need to recalibrate, or just live with the fact that your unit isn't calibrated.  I don't know what you're hoping to see, but I definitely wouldn't remove any of the cans.  It might not affect "calibration" much, but you'll likely affect the shielding effectiveness, and increase your noise floor, interference, spurs, etc.
I've never heard about Agilent overtightening of the connectors... that's surprising (I'd figure Agilent would have a pretty good handle on connector torque).  There are different torque specs depending on the connector material, specific type, and application though, so they might be tighter than the 8 in-lbs of a standard SMA torque wrench.  For example: http://www.amphenolrf.com/connectors/sma.html says 4-6"lb recommended for commercial grade parts, 7-10" lb recommended for industrial/military grade parts, and 15" lb maximum for industrial/military grade parts.  Generally, brass parts should be torqued less than stainless steel.
Pat
Offline technogeeky
« Reply #144 on: March 04, 2017, 02:18:31 pm »
OK. I'll take a poke around. I also want to reset all of the default setups because they are very silly for my usage. What the hell is "Chan 500" and why did they like it so much? :)
Yes indeed. I really hope to get this one day, so perhaps someone here has come across it. I guess I could ask Keysight for it, but I doubt that will get very far.
Well, I am just very curious by nature; and I've never torn down any RF equipment. I also figured it would be nice to get pictures and/or part numbers and post them, since nobody has posted even block diagrams, let alone schematics.
I think my only references are two or three videos of Shahriar's @ The Signal Path. And perhaps it was specifically HP gear that was overtightened. In any case, given the above it won't be a problem since I won't be taking it apart.
Online PA0PBZ
« Reply #145 on: March 04, 2017, 02:54:34 pm »
If I remember correctly the software it is supposed to work with specific TM equipment (think sig gen, rf meter and such), and as long as you don't have those it will be of no use at all
Offline technogeeky
« Reply #146 on: March 04, 2017, 09:40:44 pm »
Oh. I thought this unit sort of contained most of the hardware it needed to test itself. I also figured they left space in the UI for those buttons, so maybe it was on the machine. Ah well. It's still an incredible buy at $300 shipped (and now) fixed.
Offline technogeeky
« Reply #147 on: March 06, 2017, 04:54:20 am »
In searching around for possible calibration software information (both on the unit and in general), I have so far only found this document which describes TME or Test Management Environment.
This is the aforementioned piece of software which runs on a computer (apparently with some IO libraries and a GPIB card of some sort).
It seems you can download the latest version though it needs a license key. It seems there are very old calibration applications (C.xx.xx), old calibration applications (D.xx.xx) and newer ones (E.xx.xx).
The are two new facts that I think this document brings to light, however. One concerns Agilent internal numbering for these devices:
  • The N1996A CSA is internally known as N7813A
  • The E7495x BST is internally known as N7816A
However, the reason I know this is new information is the same reason I also know this is not useful information: a search for N7816A reveals nothing except the above PDF.
Secondly, it seems like a very small subset of devices are labeled (internal Agilent only) which presumably means only Agilent themselves can run that cal application. These include:
  • Our E7495x units.
  • An ACQ/SW unit 34970A.
  • All of the Dragonfly-based Digital Receivers (E640xx, E745xx, E747xx).
I guessed that this is because all of these units incorporate 'Dragonfly' units (the E7495s appear to), but the 34970A seems to be an exception to this. I won't speculate further.
In any case, I wonder if we could appeal to Keysight to release the software and licenses for this, since it's long since unsupported; and they won't even do CALs for these devices anymore.
Offline technogeeky
« Reply #148 on: March 06, 2017, 08:21:07 am »
If anyone cares to test, I had a theory that perhaps turning off some levels of logging/debugging might help. It turns out that there is no straightforward way to stop the debugging processes, but you can disable any logging.
Simply edit this file with the following changes:
/flash/linux/etc/rc.d/init.d/egGui
-DLogger.level=2
to:
-DLogger.level=0
Unfortunately I can't find a good thing to test this with. But the UI does seem a bit snappier. I wonder what other options are there for -Dxxx.
Also, I played around with the files in /flash/egServer/Dragonfly/Recievers, like E7495A and CPXSRC. You can indeed change things here and sometimes see the effects (e.g. you can change E7495A to have Freq Range be 3000e6, and it makes it possible to enter that value). However, some of these changes will have no effect for other reasons (here, I assume it's because there is actually a filter which sharply cuts off at ~ 2.7GHz).
However however, I could not find a way to try and make the signal generator make higher or lower frequency signals.
Did anyone actually try porting things from the N1996 over to ElGato? The only things I'd really be interested in are FM/AM demodulation and audio playing, and Harmonics viewing.
Offline kirill_ka
  • Country: ru
« Reply #149 on: March 07, 2017, 09:23:20 am »
N1996A spectrum analyser code doesn't work with E7495 for some reason. It attempts to work, but DSP code seems to hang somewhere. See my post above. If you can find different versions of N1996A firmware, we might have a better luck.
Offline kirill_ka
  • Country: ru
« Reply #150 on: March 07, 2017, 09:30:52 am »
Limitations are spread in configs, gui, elgato, dsp code and hardware. I mean along with configs there are many hardcoded values.
Offline kirill_ka
  • Country: ru
« Reply #151 on: March 07, 2017, 09:38:29 am »
There's a separate serial port which is used to communicate with power meter hw. It's closed immediately when you exit the power meter. If I have time, I'll try to decode the protocol.
Online PA0PBZ
« Reply #152 on: March 07, 2017, 10:01:22 am »
If the 7495 is anything like the N1996 (and we have a lot of reasons to believe so) you will not be able to go above 2.7GHz.
The N1996 has 2 receive paths, one for 0.1MHz - 2.7GHz and the other for 2.7GHz to 3/6GHZ. Since the N1996, depending on the model, has an upper limit of 3 or 6GHz both receive paths are there, and that is why you can change the 3GHz model to 6GHz by changing the upper limit value. Since the 7495 goes to 2.7GHz only I assume that the upper part is missing in the 7495. See below the N1996 receive path:
Offline technogeeky
« Reply #153 on: March 07, 2017, 04:06:52 pm »
Do you have any idea about extending the range (power) or (frequency) of the signal sources? Also, it seems the N1996A has a zero-span mode. I wonder if this could be enabled on this device. Also, I wonder if we can expose the number of sample points (in fact, I find it downright weird that these aren't at least listed somewhere, let alone adjustable).
« Last Edit: March 07, 2017, 04:08:26 pm by technogeeky »
Offline TheSteve
  • Living the Dream
« Reply #154 on: March 07, 2017, 05:18:34 pm »
I was able to extend both the power and frequency range of the signal source in a N1996A. The power range difference was only a few dB so I changed it back to stock as the real maximum output varied with frequency. I extended the frequency range down to 1 MHz from 10 MHz. I believe the E7495A has similar text files which can edited however I have read someone tried lowering the source range on an E7495A in the past and it would crash the unit when you tried to enter a lower frequency.
VE7FM
Offline technogeeky
« Reply #155 on: March 08, 2017, 04:11:17 am »
I thought I might have some insight into this problem, but it appears you already noticed what I noticed. The GPS never goes GREEN, it stays at YELLOW TRIANGLE.
I think the problem lies with the time/clock itself. Something is clearly fighting the GPS to reset the clock to some (arbitrary, it seems) earlier value. And I do mean arbitrary. I tried this procedure and I think this pretty well proves something is fighting it:
  • Turn on device, connect GPS antenna.
  • At any time (but for sake of argument, after you notice at least 5 satellites locked), log into the web interface (port 5000). Click on Date and Time, and tell the device to take the current time of the your computer.
  • It will update, but then after about 30 seconds, it will reset to this initial time.
  • No matter how long you wait, it will continue to allow you to set the time; but it will always rollback to this 1st clock set.
  • You can confirm this by changing the time zone on your host computer. This will set the clock to the same time, but it will suddenly be many hours ahead; and the device will still go back to whatever the initial setting was (this can sometimes be Jan 1 2004).
However, I do have something additional to report: You can fool the device into launching the Time Base Adjustment (... sort of):
  • When you are at the Time Base Adjustment screen (the Calibrate button will be greyed out)...
  • Log onto the web interface.
  • Click on Active STIM.
  • Select and activate the GPS stim.
  • Click on Channel I/O.
  • Set the Frequency Reference parameter (10) to 0, using the Int 10M reference.
  • This will fool the unit into believing that the 10MHz reference (e.g. the one we are trying to calibrate) is the locked signal. It will bring up the menu we are all trying to see. It will show the ADC value for the reference, and where/when it was chosen (2053, and Initial Factory).
This doesn't help us, but I think it must be the case that something is fighting us for the clock. So we just need to find what other processes/stims/whatever access/try to change the clock. Perhaps this is a sign of a hardware malfunction in a clock on the motherboard, or some other malfunction that could be tested/corrected if we could e.g. get into the BIOS? Is there a BIOS?
I rebuilt one of my battery packs, and I took pictures of the process. Unfortunately the 2nd one I rebuilt was actually already good, and I simply hadn't checked. I will be getting batteries in soon to replace the first pack.
Offline TheSteve
  • Living the Dream
« Reply #156 on: March 08, 2017, 04:36:06 am »
I was hoping you were on to something to help adjust the time base on the N1996A. On the N1996A there is a frequency/reference setting menu. It won't let you continue though unless the system is configured for GPS.
However the N1996A doesn't support a GPS - it was never enabled and the receiver is not installed.
I can set the external reference to "even second" but it locks just fine to a 1 PPS signal(even second doesn't lock).
Not a big deal but it would have been fun to adjust the timebase without using the crazy expensive calibration software Keysight sells for the N1996A.
VE7FM
Offline technogeeky
« Reply #157 on: March 08, 2017, 05:20:52 am »
Well, this may be a route toward that (if a circuitous one). I really don't know that hardware (or this hardware, to be honest). But this method let me see the the value stored somewhere (in firmware or eeprom or something) for the calibration setting (which is, in this case, an integer constant for the ADC). If we could use the screen in which this was displayed (I did not get a screenshot or photograph; I was actually driving my car at the time!) to find where it's writing a firmware setting to, perhaps we could translated this process back to your device?
Offline DogP
« Reply #158 on: March 08, 2017, 06:35:27 am »
IIRC, I came to the conclusion that it's a script running in the background that's causing the time to constantly reset.  I think it was keepTimeUpdated or something like that.  I don't think the system clock is why GPS never goes green though (I don't think there's any code for the GPS to even try updating the system clock).
That'd be great to be able to extend the sig gen freq below 375 MHz... and if it could do that, maybe it could do the insertion loss test below 375 MHz as well.  Those features would be very high on my wishlist (even though the arbitrary sig gen kinda sucks since it doesn't filter the LO or image).  Does the N1996A have an arbitrary sig gen, or just a tracking generator?
Pat
Offline technogeeky
Re: Agilent E7495 linux root account
« Reply #159 on: March 08, 2017, 10:38:10 pm »
I think you are correct. I think I might have proof, but I don't think it's (yet) needed. In any case, when I was having trouble running the Calibrate Timebase thing, it turns out the hardware clock (as displayed by hwclock) was set to Jan 1 1970. In other words, it was just counting up from epoch. There is also an 'rtc' module, which could be the source of our problem: if the RTC is faulty or resetting, then it's possible the RTC or the manager of it is fighting attempts to set the clock.
I have found some code regarding this in the GUI, so I can investigate further.
Has anyone been able to decompile the ARM code? I assume there is little to no hope to decompile the firmware for the Dragonfly chips, but the ARM code (of elgato server) should be easy to decompile. I tried downloading and using snowman, but it is unfortunately stupid and it runs out of memory at the "regenerating types" stage. It seems to have generated all of the functions from two different binaries, but because I only have 8GB of memory I can't get much further. Does anyone know how to force a process to work from a disk instead of from memory?
You can look at the elgato GUI (siege) source JAR linked here, and it's clear that there are a few checking conditions before you're allowed to enter the timebase recalibration. Also, there appears to be a direct command you can issue to some command listener to set the new timebase ADC value directly -- this may help N1996A owners. At the very least, you could GET the existing timebase ADC value and then SET a new one, then compare the clocks (though how one would go about this, I have no idea).
Offline technogeeky
« Reply #160 on: March 08, 2017, 10:46:33 pm »
Can you guys post screenshots of the noise floor of your instruments? I am wondering noise floor curve on my instrument is wrong or not. See the attached images. This is with nothing connected at all.
The screenshots show the measurements and diffs between:
  • 500 kHz and 375 MHz (+2.8dB)
  • 375 MHz and 2.7 GHz (+10.4dB)
Something tells me that a gain of 10.4dB over that range is probably not a good thing.
Offline TheSteve
  • Living the Dream
« Reply #161 on: March 08, 2017, 11:54:31 pm »
Looks pretty normal to me.
Edit:
I've attached a full span screen shot of my N1996A - however it is only valid to 3 GHz. The drop you see is when it passes 2.7 GHz. The noise floor from 3 GHz to 6 GHz should actually rise as the frequency increases. It doesn't as that portion of it is uncalibrated(I enabled the 3-6 GHz portion myself).
« Last Edit: March 09, 2017, 12:08:09 am by TheSteve »
VE7FM
Offline technogeeky
« Reply #162 on: March 15, 2017, 12:40:22 pm »
Do you have more information from this source? I'd like to see any schematics or block diagrams I can find.
Online PA0PBZ
« Reply #163 on: March 15, 2017, 01:10:21 pm »
N1996 Service manual guide: https://www.dropbox.com/s/5axcrduzvvd3rvb/N1996-90006.pdf?dl=0
Offline ferdinandkeil
« Reply #164 on: March 16, 2017, 09:30:01 pm »
Did the same test with my E7495B and got similar results. Looks to be normal.
Offline technogeeky
« Reply #165 on: March 17, 2017, 06:47:50 am »
I'm still trying to hunt down the clock problem, as unlike an above poster I do think this is the reason the GPS won't go from yellow to green (though I don't yet have any firm information on this, other than configuration information: In the web UI, the STIM # 106 says the internal clock gets its time from Time).
In any case, I can confirm that basically something is resetting the clock exactly every 60 second. This is not the hardware rtc (which for me, defaults to Jan 1 1970 epoch). You can actually look at some of this with /proc/interrupts:
  0:     323496   ADS_ext_IRQ
 26:     502791   timer
 27:          0   rtc timer
 30:         18   rtc 1Hz
 31:          0   rtc Alrm
I can confirm that "rtc 1Hz" is the number of times I have accessed the RTC with hwclock. You can easily confirm this.
I was interested to note that (I need to state this carefully): the time the clock resets back to every 60 seconds, is the timestampped value of /etc/adjclock. It didn't seem like changing the timestamp on this had any effect, so I just moved it to the side. I thought this was the end of this route. However, 30 minutes later (again, exactly) the file was recreated with the timestamp 30 minutes later, but now with zeroed contents (0.000000 0 0.0000000 / 0 / LOCAL).
Note that all of this was carried out with all of the time-related processes and local GUI processes killed. So either this is a driver, something kernel level, or elgato (the server itself) doing this.
edit 1:
More notes. It looks like /dev/receiver is a pointer to a UART where the GPS dumps raw information. Maybe.
In any case, looking at /dev/ram0 shows:
ttyS0 at I/O 0xf0100000 (irq = 50) is a 16550A
ttyS1 at I/O 0xf0120000 (irq = 51) is a 16550A
ttyS2 at I/O 0xf0140000 (irq = 52) is a 16550A
ttyS3 at I/O 0xf0160000 (irq = 54) is a 16550A
So these are all UART-things.
« Last Edit: March 17, 2017, 07:31:11 am by technogeeky »
Offline technogeeky
« Reply #166 on: March 17, 2017, 07:01:37 am »
Funny enough, they were nice enough to fill out their /etc/services with their own services:
diag            31415/tcp                       # ARMS diagnostics
elgato_cmd 5028/tcp # ElGato Command Generator
elgato_reporter 5029/tcp # ElGato Reporter
scpi            5025/tcp                        # SCPI
scpi            5025/udp                        # SCPI (to be safe ?!?)
I'm not sure if all of these are known, I will have to make yet another pass through this thread. :/
Offline kirill_ka
  • Country: ru
« Reply #167 on: March 17, 2017, 01:46:51 pm »
scpi code is missing from elgato. There's SCPI STIM in N1996A's toro, which we don't have in elgato.
Offline ve7xen
    • VE7XEN Blog
« Reply #168 on: March 18, 2017, 04:05:15 am »
I did some digging into the time setting issue, since I was pretty sure my unit successfully synched to GPS time back when I got it, but I see the same 'yellow triangle' behaviour now.
Long story short, I did some poking around with the logging. Nothing useful comes out of the client (though maybe some insight into the protocol, it's quite verbose when set to level 255), but the server application logs directly to /dev/ttyS0 at 38400 8N1 (which is also the bootloader and a Linux tty). This happens to be 'Serial 2' on the top panel of the instrument. Looking at the log output, it seems that some variant of the Y2K / Y2038 bug could be in play here, this repeats every 30 seconds:
System time less than minimum allowed. Setting clock to Thu Jan  1 00:00:00 2004
What I presume is happening is that the GPS is setting the clock, then the server process doesn't like it and resets it. Some strange things start happening if I set the system clock manually (date -s "YYYY.MM.DD-HH:MM:SS"). For example, if I set the system clock to Fri Dec  1 00:00:00 UTC 2017, I now get this error, setting the time back exactly 12 hours? Where did the new set time come from (it's not in the script mentioned below).
System time less than minimum allowed. Setting clock to Thu Nov 30 12:00:00 2017
So this is quite odd, since Linux itself has no trouble with the current date, but the egServer process seems to be rolling it over zero to 'less than the minimum'. I guess egServer must be internally representing the time in a nonstandard way. Maybe just patching the comparison would make it work again?
In case you're curious, the keepTimeUpdated mentioned is a simple script that writes the current date every 20 minutes to another script that is part of the startup of the instrument. I guess to get it 'closeish' to the previous time when it boots.
73 de VE7XEN
He/Him
Offline technogeeky
« Reply #169 on: March 18, 2017, 06:15:48 am »
I wonder if this is as simple as Agilent assuming the epoch is Jan 1 2004. I think 'hwclock' is happy to set an epoch that is different from the typical 1970 one. This is, of course, the RTC. I don't know if they are reading this directly or not, but I think they could be (e.g. I think elgato could be bypassing the interrupts and going directly to the RTC).
I also wonder if this issue happened in the previous firmware. Does anyone still have it? I didn't keep it, unfortunately.
Offline TheSteve
  • Living the Dream
« Reply #170 on: March 18, 2017, 06:40:13 am »
I am thinking that the GPS used to lock fine on the E7495A as that surely would have been a fixed bug if it was always present. I also didn't find any service note related to it.
VE7FM
Offline technogeeky
« Reply #171 on: March 18, 2017, 07:11:48 am »
I learned a little bit more. First:
* We can be 100% sure the time resetting is caused by elgato itself.
* If you kill elgato and run your own copy, you get a shell. This isn't the most friendly shell, but we might be able to find useful commands by searching through the elgato binary.
First of all, we can directly see this system time problem:
Second, we can do the one thing they suggest doing, which is:
debugIPub=1; (or 2, or maybe 3?)
Samplers/timeLicense.p1 publishing {argArray with 10 elements} as 'timeLicense'
gui1.s23 receiving data as timeLicense
Samplers/timeFreqRef.p1 publishing {argArray with 10 elements} as 'timeFreqRef'
gui1.s9 receiving data as timeFreqRef
With the same setting to 2, we get:
<ArgArray length="10">
<UInt32>1</UInt32>
<UInt32>1072915200</UInt32>
<Int32>3397774</Int32>
<Int32>-8440589</Int32>
<Int32>32993</Int32>
<Int32>4</Int32>
<UInt32>2</UInt32>
<UInt32>1</UInt32>
<UInt32>0</UInt32>
<UInt32>3</UInt32>
</ArgArray>
We've seen this before, this is the data gotten directly from the GPS unit STIM.
And we also get:
<Int32>-1</Int32>
<Int32>-1</Int32>
<Int32>-1</Int32>
<Int32>-1</Int32>
<Int32>-1</Int32>
<Int32>-1</Int32>
<Int32>-1</Int32>
<Int32>-1</Int32>
<Int32>-1</Int32>
<Int32>-1</Int32>
</ArgArray>
I don't think turning off the hack has any effect on this problem, but maybe someone should double check that.
In any case, there are a *bunch* more symbols to turn on and off. Certainly anything that starts with debug. I'll keep looking...
Offline kirill_ka
  • Country: ru
« Reply #172 on: March 24, 2017, 07:14:44 pm »
Today I have some progress in decoding serial protocol used to communicate with power meter.
Below is the shell command to enable 50 MHz power reference. GUI shouldn't be in power meter mode while you run it.
(stty 38400; sleep 2; printf "\x83\xf8\x04\x08\x01\x00\x01") < /dev/ttyS4 > /dev/ttyS4Turn it off with
(stty 38400; sleep 2; printf "\x83\xf8\x04\x08\x01\x00\x00") < /dev/ttyS4 > /dev/ttyS4However, it turns off when you open the port. Opening the serial port seems to reset some power meter state.
Offline Puffin
  • Country: scotland
« Reply #173 on: March 25, 2017, 05:47:35 pm »
Has anyone else had issues with the remote GUI not responding to clicks on the right-side buttons?   I had it working once, but struggling to make those buttons work again which severely limits what you can do with the GUI.
On the subject of the date reset, it's every 30 seconds, not every 60.  Done by the elgato process itself (killing that stops the time getting reset anyway).    A crude hack to run hwclock --hctosys every few seconds is a kind of work-around.
I'm also noticing the GPS seems somewhat unreliable - and even when it does get 6 sats locked, I've never seen the GPS indicator with anything other than the yellow triangle.
I'll likely prod at this some more, but I'm somewhat nervous to try hacking things further due to fear of bricking this otherwise nicely functional kit.
Offline lectrohamlincoln
« Reply #174 on: April 19, 2017, 07:46:46 am »
Hello Everybody,
I picked up an E7495A described as "LOCKS UP ON POWER UP." I suspected that the firmware was corrupted and it would be easy enough to flash the latest A.06.25 version. I've tried using both a Sandisk 512MB and a 8Gb Compact Flash formatted to FAT32. With no luck :(
So, I followed the "Update via Load Firmware Utility" procedure described in the Service Guide. I removed the RF section and set the DIP Switch as instructed. I tried again with both Sandisk CFs, but my E7495A would only turn on with a blank display. Is it possible this factory reset requires a PCMCIA instead of CF?
I'm beginning to suspect there might be a hardware problem. I also noticed that there was a red LED lit on the controller board. I'm hoping for any suggestions before I start doing a component level debug tomorrow.
Offline DogP
« Reply #175 on: April 19, 2017, 08:21:05 am »
Did you try doing a fresh firmware install?  When you put the CF card in with the 6.25 update, and are promted to install... press the bottom right button, across from NO.  I believe that does a rebuild of the drive.  That error does look more like a Linux/disk kinda error than a general hardware error (other than bad flash maybe).
Other than that, if you can connect into it over a serial port, maybe you can check the logs for more specifics on the crash?
DogP
Offline kirill_ka
  • Country: ru
« Reply #176 on: April 21, 2017, 04:12:24 pm »
Hello Everybody,
That's the right thing to do. I don't know if it's supposed to work from CF. If it doesn't boot kernel anymore, "utility" was able to erase it at least...
I think that "load firmware utility" should write something to the screen or serial port. Maybe you should try it again and check the output?
« Reply #177 on: April 22, 2017, 12:52:10 am »
I was able to get serial port 2 working. It says all DRAM tests have passed at least. If anyone's curious the baud rate is 38400 and it expects a return CR on transmitted text.
I also tried the A.06.25 firmware on a CF to PCMCIA adapter to no avail. I know its loaded too because without the PCMCIA inserted it says "There is no PCMCIA card on Socket 0"
With DIP switch set to 1&2 I get the same error message on the bottom of the screen: "Kernel Panic: No init found. Try passing init= option to kernel"
With DIP switch set to 2&3, 1&3 or 1&2&3, I get the following menu options from the serial terminal:
[1] Display Register
[2] Set Register
[3] Dump Memory
[4] Set Memory
[5] Erase Blocks of Flash
[E] Set Ethernet MAC Address
Select Menu & Hit Enter Key:
The "Dump Memory" returns real looking values. I'm unsure how to use the "Set Memory" and I feel a little uneasy using the "Erase Blocks of Flash."
I wish we had a board level Maintenance Manual. I just have a feeling that Red LED means somethings gone bad. I was able to find this brief BOOT ROM manual that seems to correspond to the E7495 http://support.eurotech-inc.com/developers/linux/files/boot/bootrom.pdf
I'll do some more investigating this weekend.
Offline DogP
« Reply #178 on: April 22, 2017, 02:58:42 am »
Did you try the full fresh reinstall (not just the standard firmware upgrade)?  IMO, it sounds like a file system problem... you can read a bit about the "No init found" message here: http://lxr.free-electrons.com/source/Documentation/init.txt?v=3.13 .
DogP
« Reply #179 on: April 22, 2017, 03:38:26 am »
I believe I am doing a full reinstall. The boot process never gets to stage where I am prompted with a Yes or No about firmware upgrades and the buttons are all unresponsive.
The only sign of life I have gotten out the E7495 is through the Serial Terminal after following what the Service Guide calls a "Update via Load Firmware Utility." Which is "used to reload firmware on an E7495A/B just as it is loaded at the factory," according to the Guide.
Is there another way to initiate a full fresh reinstall? I scoured the manual and can't find any reference. I fear my only option might be to Block Erase the Flash and hope for the best. But, I think I'm first going to write a program to try and download the flash before I do anything irreversible.
Offline DogP
« Reply #180 on: April 22, 2017, 04:52:12 am »
Ah... if it never actually gets to the yes/no, then it's probably not actually doing any sort of reinstall.
I think you want to do switch 1 and 4 off, switch 2 and 3 on, as described in the manual.  I believe that will reconfigure the board to boot Linux from the PCMCIA card, rather than internal flash.  With the firmware upgade CF card in a PCMCIA adapter in the PCMCIA slot, it should boot.  You mentioned that you get a debug menu over the serial port... does nothing show up on the screen when you do that?  And the debug menu is all you can do... there's no way to log into a terminal over the serial port?
One thing you might want to try is the OLD firmware version (1.60) that's still available on the Keysight website: http://www.keysight.com/main/software.jspx?ckey=sw411&lc=eng&cc=US&nid=-11143.0.00&id=sw411 .  In the root of that zip is a script called reloadFFS, which does a reinstall.  In version 6.25, that file exists, but is empty.  This might be the key difference between the instructions and what you're seeing.  There's also readme describes how to use it.
This contains directions on how to recover a /flash file system that
has been corrupted.
WARNING: DO NOT DO THIS UNLESS ABSOLUTELY NECESSARY!  IF YOU'RE NOT
SURE, DON'T DO IT.
To use reloadFFS:
- Boot the elgato
- Log in as root through the serial port
  - This assumes that you can log in.  If you can't then this won't work.
  - If you must log in through telnet follow "Log in through telnet"
    instructions below.
- Install PCMCIA card
- "mount /xdrive"
- "sh /xdrive/reloadFFS"
- Follow instructions given by script
Log in through telnet:
- Log in as root
- mv /etc/passwd.old /etc/passwd
- mv /flash/linux /flash/linux-
- reboot -f
- After reboot is complete (30 seconds or more) log back in as root
- Continue instructions above
Pat
Offline TheSteve
  • Living the Dream
« Reply #181 on: April 22, 2017, 05:15:42 am »
I don't have an E7495A but I do have the close cousin the N1996A. Firmware updates on it are generally done via USB. If you have a failure during flashing there is an internal PCMCIA slot that can be used to recover the unit. The instructions do say a CF card is supported via an adapter. You do need a different image compared to the USB image though which has the update and a boot image with a kernel etc.
Is there a special PCMCIA image for the E7495? And if so does it also have cmdline.txt, ramdisk.gz, register.txt, version and zImage?
If you don't have those files check out the USB and PCMCIA updates from the N1996A - maybe you can borrow the needed boot files.
VE7FM
Offline kirill_ka
  • Country: ru
« Reply #182 on: April 22, 2017, 09:31:55 pm »
It means that flash filesystem is corrupt (because of software error, or flash is failing). I can't imagine how other hardware problem can prevent linux from finding init executable.
"Then 2 & 3 ON Copy any/all of zImage, ramdisk.gz and flashfs1 file to Flash ROM and
copy zImage & ramdisk.gz from Flash ROM to RAM and Boot from RAM"
It's clear that it expects zImage and ramdisk.gz on the card. Note that bootloaders a quite picky about filesystem format. Some require fat16 for example. Hopefully it would say something if it can't read the files.
« Reply #183 on: April 26, 2017, 06:36:37 am »
The filesystem is definitely corrupted. Most likely the ram disk is corrupted in a way that the kernel can't load it. The start-up log has the following, "RAMDISK: Couldn't find valid RAM disk image starting at 0"  (I can copy the entire boot log if anyone is curious)
The 1.60 firmware did not work. It definitely detects the PCMCIA when DIP 2&3 are set, but does not boot from it. It just gets to Serial Terminal with a the menu options I described in the previous post.
I'm a little confused by the 1.60 directions. What does it mean by "To use reloadFFS: - Boot the elgato" Is "elgato" just referring to the E7495?
Does anyone know how to recover from a corrupted filesystem? The only ideas I have right now are to use the Serial Terminal menu to load in data at 38400 baud, or to find a JTAG header for the SA1100 chip. In either case I'm not sure what I would load, or even what address I would load it to  :-\
Offline DogP
« Reply #184 on: April 26, 2017, 10:03:09 am »
Yeah, I don't think loading memory locations is gonna help, since it's very unlikely that the flash is simply fully memory mapped to the CPU.
Have you tried plugging it into the network to see if you can telnet into it when you boot from the PCMCIA slot?  Obviously you'll need to check your router to see if DHCP gave out an IP address.
And if it is booting from PCMCIA, then another possibility is modifying the ramdisk file on the card.  You should be able to un-gzip the ramdisk.gz and mount the ramdisk (on Linux of course).  Then make changes (i.e. automatically run upgrade scripts, give you a terminal over the serial port instead of the debug menu, etc.), re-gzip the file and put it back on the card.
When you run from the PCMCIA slot, does you see any of the boot process on the screen, or does it stay blank?
And yeah, elgato is their name for the E7495.
Pat
« Reply #185 on: April 26, 2017, 11:01:14 pm »
I tried plugging it into the network again no luck. AFAIK it never boots from the PCMCIA.
If DIP switch 2&3 are set, it looks like it just boots from the 1Mib flash ROM (the AT29LV1024 chip). The screen is blank and I only get a Serial Menu with a few crappy option and no way of booting from the PCMCIA or getting an actual command line. Although, it does detect when a PCMCIA card is not inserted (it prints an extra line over Serial saying the PCMCIA card is missing).
If DIP 1&2 are set, it gets part way through the Kernel boot then hangs. No command line, no option for firmware upgrade, no difference if the PCMCIA card is inserted.
Is there some special formatting of the PCMCIA necessary for recovery?
Offline kirill_ka
  • Country: ru
« Reply #186 on: April 27, 2017, 08:49:33 am »
Does it mean something's changed from your first attempt? There's "no init" error on the screen shot you posted earlier.
Offline kirill_ka
  • Country: ru
« Reply #187 on: April 27, 2017, 09:14:07 am »
I'd try different cards formatted as FAT16.
Offline kirill_ka
  • Country: ru
« Reply #188 on: April 27, 2017, 09:30:43 am »
No. What we see here is "GPS week rollover" problem.
http://www.npl.co.uk/reference/faqs/when-and-what-is-the-gps-week-rollover-problem-(faq-time)
The message doesn't show the time which is "less than minimum". I verified that it's current time minus 1024 weeks.
So GPS subsystem adjusts system clock and then it's immediately reset to "minimum time".
« Last Edit: April 27, 2017, 09:33:43 am by kirill_ka »
The following users thanked this post: technogeeky, eplpwr
Offline kirill_ka
  • Country: ru
« Reply #189 on: April 27, 2017, 06:24:11 pm »
Apply following patch to elgato binary to fix GPS time synchronisation:
0x0122880: replace 4b2585e2152882e2 with de2585e23f2882e2
The following users thanked this post: ve7xen, technogeeky, mlefe, eplpwr
Offline technogeeky
« Reply #190 on: April 28, 2017, 03:24:00 am »
This is why, as a citizen of the United States, I can't stay mad at Russians. The dopest hackers on the planet.
See below, finally we can calibrate out the expected timebase drift! Thanks kirill_ka. We all owe you one.
Offline DogP
« Reply #191 on: April 28, 2017, 08:57:58 am »
Awesome... I'll give this a try shortly!  And we get to look forward to this problem again in 2 years (got a patch ready for the 2019 rollover?). ;)
Thanks,
Pat
Offline kirill_ka
  • Country: ru
« Reply #192 on: April 28, 2017, 09:35:05 am »
I think the receiver was designed to operate before 1999. So it's thrown backwards not the same time GPS week count wraps. I.e. it should work for another 20 years.
In 2038 old *NIX stuff will die anyway :)
Offline DogP
« Reply #193 on: April 28, 2017, 10:24:43 am »
Just tested it, and it worked great!  For anyone keeping track, I let the unit warm up for 15 minutes (with the GPS antenna connected), like the instructions say.  From the calibration, my DAC setting went from 2162 (factory) to 2121... so a similar change to what technogeeky had.  I left it on the adjustment screen and clicked the repeat button a few times over the last 20 minutes, and it has continued to climb (it's up to 2190 now).  I'm gonna leave it on overnight and check it in the morning.
Thanks again!
Pat
Offline DogP
« Reply #194 on: April 28, 2017, 03:31:35 pm »
And, a final update... after letting it run overnight, it seems to have landed at a DAC setting of 2223 (it bounces around +/- a few values, but hasn't drifted over the last 45 minutes).
Pat
Offline alpha89
« Reply #195 on: May 05, 2017, 04:46:45 pm »
Where is the elgato binary file located?  Thanks for figuring this out as my box is needing a frequency
calibration.
Offline technogeeky
« Reply #196 on: May 07, 2017, 08:52:43 am »
I spent some time the other day looking for any spurs, and I only found one. I've attached two screenshots; the first is at RBW of 50 Hz with 10 averages and the second is at RBW of 10 Hz.
Can anyone else confirm this spur? Does anyone know of other spurs?
Offline usagi
« Reply #197 on: May 08, 2017, 05:10:52 am »
spur at 396.8 is probably the LO.
Offline hawaii596
« Reply #198 on: May 08, 2017, 06:47:31 pm »
New to forum. I have a couple of Agilent E7495B units with lots of accessory, the backpack, and transit case that I am preparing to issue out. They have a problem that they are not able to sinchronize wih GPS clock. According to one of the technicians who looked at them, it is because the onboard dates are too old (more than 12 years), and they can't synch to GPS if there is more than 12 years between today (May 8, 2017) and the onboard date.
I am not a programmer or engineer; just a metrologist in an instrument lab.  Due in part to things I read at this site, I figured out how to connect to the E7495B with Telnet. I was able to log in as "root," and using LINUX commands, check and reset both the normal date and hardware clock. But once I rebooted the system, both reset to some sort of base date. The Hardware clock, back to 1970, and the system date back to 2008. I am guessing the 1970 is a base date for the hardware, and 2008 is the initial release date of the installed firmware.
This leads me to think perhaps there may be a bad CPU battery.  However, I have been unable to physically find one in the instrument. And at least one user on a Keysight (Agilent) thread said there is no CPU battery.
If anyone has experience or understanding about this, I would sincerely appreciate any of your thoughts. Is there a CPU battery?  If not, is there a reason why the dates are reverting?
Also, could it be that once I manually update both of these dates in LINUX, do I need to do a GPS synch to get them to take more permanently (could this be the need)?  Thanks one and all for any inputs.
Offline usagi
« Reply #199 on: May 08, 2017, 06:58:19 pm »
read this entire thread, especially this post.
Offline hawaii596
« Reply #200 on: May 09, 2017, 08:07:40 pm »
I've now pretty much read through the entire thread. I did read the particular post about applying the patch per the quote below:
As a non-programmer, that is fully above my head.  If there is a set of Linux commands that do this, I would greatly appreciate some instruction on how to do this.  Otherwise, whatever other instructions for specifically how to do this. I realize this thread is mostly for techno types who experiment with these things.  I am a techno type in metrology. I have deep understanding of how accuracies work. And I am a fast learner. But unfortunately, even with my decades in metrology, communications/navigation systems/RADAR systems/instrument calibration, this is a weak zone for me.
If anyone could explain is some detail how to apply this patch, I would be forever grateful.
Offline technogeeky
« Reply #201 on: May 10, 2017, 01:28:07 am »
The original poster is basically telling us to do a binary patch on the file ("elgato" binary). The first thing you would do when doing any patch of any file (binary or not) is to make sure you have a good copy of the original, of course.
All of the important files on the device are in /flash. In prose, they are in a subfolder in the root of the filesystem. This is certainly unusual in most Linux systems. In this case, there are also a bunch of other folders in /: bin, dev, etc, lib, mnt, home, nfs, root, tmp, var, sbin, usr, xdrive. These are the usual thing you are used to in Linux systems. I think these files are generated out of files located in the /flash directory, though; but that's not important. When listing files, make sure to do ls -l so you see where the files point to (many important files point to e.g. /flash/linux/etc/...).
As for the "elgato" binary, that's in /flash/egServer/elgato. This file is the actual instrumentation server. This is what the GUI  communicates with to control the hardware. (The GUI is located in /flash/egGui, by the way).
Now that we have the location and context of the file, all we need to do is interpret the original instruction:
0x0122880[location]: replace 4b2585e2152882e2[old value] with de2585e23f2882e2[new value].
This line is telling us to use a hex editor (vi/vim has a hex edit mode, emacs has one, there are probably command line tools to hex edit too). It's telling us to starting changing the actual file (though we are representing this in hex for convenience) on disk at [location] bytes from the start of the file. It further specifies that we should see, at this location, the value [old value]. And we should change [old value][A] to [new value], then save the file.
Some/most editors are usually used to operate on text files, so you may need to tell the editor to load the file in binary (e.g. vi -b). Then once you open the file, you use some command to convert the binary to hex. Then you find the [old value], replace it with the [new value], convert the file back to binary from hex, and then save the file.
Since you have a backup, you can afford to make a mistake in this process. You'll probably get it right on the first try though. Note there are two hex changes (at two different locations) listed in this thread: one which changes the program which handles licensing to automatically allow all license options that are listed (regardless of them having a correct key). The other corrects the clock issue. Presumably there will be more of these in the future.
We go through all of this trouble for basically two reasons, in order:
  • We don't have access to the source code for this file, so we can't tell you a change in code to fix the problem.
  • Once you have found some change to make, you have to make the appropriate change in the binary file. People typically don't distribute the binary file since it is covered by copyright and various other things. So patch instructions are used instead.
I hope this is cleared up. Hopefully, you or someone else can find all of the binary file changes to allow the signal generator to go down to whatever the true lower limit of the hardware is, one day.
[A]: Notice that it was not necessary here to actually give the old value for this process to work (since you were told the location to start the edit). It's given as a checksum: if the value you see in your file is not [old value], then you are either at the wrong location in the file, are editing the wrong version of the file, or both.
« Last Edit: May 10, 2017, 01:31:11 am by technogeeky »
The following users thanked this post: mlefe
Offline DogP
« Reply #202 on: May 10, 2017, 09:49:31 am »
IMO, copying the file to a CF card, modifying in a GUI hex editor on your desktop PC, then copying it back to the box is the most intuitive way to do it... if you're familiar with hex editing.
An alternative, if you simply telnet into the box, you can run the following commands to patch the binary in place.  Once you're done, you should reboot the box to make sure it's running the modified binary.
The first line copies the binary file to be modified.  The 2nd line does the actual patch.  The 3rd line backs up the original file in case you screw something up and/or need to revert to the original.  The 4th line moves the modified binary in place of the original.  Note that Linux is case sensitive, so copy it exactly as shown (i.e. capital S on egServer).
cp /flash/egServer/elgato /flash/egServer/elgato.mod
printf '\xde\x25\x85\xe2\x3f\x28\x82\xe2' | dd of=/flash/egServer/elgato.mod bs=1 seek=1190016 count=8 conv=notrunc
mv /flash/egServer/elgato /flash/egServer/elgato.orig
mv /flash/egServer/elgato.mod /flash/egServer/elgato
Similarly, if you want to do the license patch posted earlier, you'd run this additional line (before the mv commands):
printf '\x00\x00\xa0\xe1' | dd of=/flash/egServer/elgato.mod bs=1 seek=3373692 count=4 conv=notrunc
Pat
« Last Edit: May 12, 2017, 07:21:14 pm by DogP »
The following users thanked this post: 300EVIL
Offline kr5j
« Reply #203 on: May 10, 2017, 08:18:30 pm »
Thanks for the info! been waiting for a better description of the patch.
Offline ke6iyc
« Reply #204 on: May 10, 2017, 10:36:30 pm »
Hello all!
Ordered one of the cheap units on fleabay (but it does power up and function) for a good price today.
Glad I found this thread AFTER I ordered (otherwise I would have been tempted to pay too much).
Thank you to all for the hard work and time you have put into this.
Will have to  disassemble to fix the screen gasket when it arrives mid next week.
Brian
KE6IYC
Offline technogeeky
« Reply #205 on: May 10, 2017, 11:25:11 pm »
Hello all!
Brian
KE6IYC
This reminds me...
Q: What kind of plastic is the screen protector, and how can I clean the adhesive gunk off of it?
Unless you are a better chemist than I am (entirely possible...) , you're going to find that the only solution (no pun intended) which actually releases the gasket adhesive is acetone. This same acetone will destroy the top layer of the plastic (and/or the UV coating, or something). It doesn't look great. It looks pretty awful, actually. Since I used acetone, and hence destroyed the plastic (or its coating), I decided to try and identify the exact plastic so I could find a replacement. I did some destructive testing to determine exactly what kind of plastic the screen protector is, and after some burning, melting, and inhaling burned plastic odors... I am pretty sure I came up with an answer. And probably nose cancer. PVF. Polyvinyl Fluoride. And while this link (it's a good URL to bookmark. As is the other one. Do it.) wasn't helpful, further browsing and this site convinced me that PVF is an understandable choice for this screen. It could also be any of the self-extinguishing, non-dripping ones (PPO, PVC). In any case, I couldn't find a good supplier of PVF clear sheets, and I could easily find many places to get PVC clear sheets.
In any case, I wasn't able to find any easy to way to buy PVF glass sheets, so I eventually went with plain PVC. I got them custom cut from an Amazon vendor, and I still have three sheets exactly cut to size. I will be happy to send them out if you want, or otherwise I can just share the measurements I took so you can see if you agree; and we can learn where and how to buy PVF plastic clear thick sheets.
Q: What facts do we know about the plastic type of the screen?
  • available in clear, rather rigid sheets that do not crease
  • some sort of UV or anti-reflective coating
  • softens, not burns (thermoplastic)
  • sinks in water
  • does not appear to have flames (50%?)
  • does not continue to burn (95%?)
  • does not appear to drip (50%)
No, the stuff I have does not have any anti-glare or anti-reflective coating. Yes, it's slightly worse than the original. Yes, you would about $1 plus shipping. Oh, thanks for the interest. My address is, roughly speaking:
Atlanta, GA, USA, Earth, Sol, Milky Way, Universe A
So if shipping to you would be uncomplicated, let me know. I have 3 more of them. They still have the factory tape on them, so there should not be any defects.
« Last Edit: May 10, 2017, 11:32:21 pm by technogeeky »
Offline ke6iyc
« Reply #206 on: May 11, 2017, 11:44:37 am »
That would be most helpful, but I would only need one (share the love).
I am, roughly speaking, Boise, Idaho, USA, Earth, Sol, Milky Way, Universe A
Currently sitting in Florida, however, so that might be a tad cheaper.
If you have PayPal, I would happily reimburse for any costs incurred......
Email would look something like ke6iyc (at) mac (dot) com , but with the generally accepted punctuation and symbology, instead of the parenthetical words.
Thank you in advance!
Brian
KE6IYC
Offline ke6iyc
« Reply #207 on: May 12, 2017, 03:36:45 pm »
Simple question,
Is the RS-232 cable for Telnet straight through, or null modem?
Thanks!
Offline kirill_ka
  • Country: ru
« Reply #208 on: May 12, 2017, 03:56:12 pm »
E7495 ports are normal "DTE" ports. So the cable should have TX to RX connections (null modem).
Offline kirill_ka
  • Country: ru
« Reply #209 on: May 12, 2017, 04:13:00 pm »
An alternative, if you simply telnet into the box, you can run the following commands to patch the binary in place.  Once you're done, you should probably reboot the box to make sure it's running the modified binary.
The first line backs up the binary file, in case you screw something up, or need to revert back to the original.  The 2nd line does the actual patch.  Note that Linux is case sensitive, so copy it exactly as shown (i.e. capital S on egServer).
cp /flash/egServer/elgato /flash/egServer/elgato.bak
printf '\xde\x25\x85\xe2\x3f\x28\x82\xe2' | dd of=/flash/egServer/elgato bs=1 seek=1190016 count=8 conv=notrunc
I would hesitate to use that command unless I'm absolutely sure the binary is the right one.
There are few caveats:
1. Original binary should be the same version. Probably we'd post md5sums of original and patched files.
2. Writing to the executable which is running may fail.
3. There are number of "printf" versions you can find on the same system. Some of them may not support hex escape sequences. E.g. bash built-in printf, /bin/sh built-in printf, /usr/bin/printf.
Offline ke6iyc
« Reply #210 on: May 12, 2017, 04:36:04 pm »
Thank you on the cable question.
As for the patching in place, has anyone ACTUALLY tried it?
I am out of state right now, and have a unit waiting for me at my hotel.  I would like to patch it (Would like to try out the Interference analyzer) before I return home, but not at the risk of bricking the unit.
Thanks a bunch to all!
Brian
Offline technogeeky
« Reply #211 on: May 12, 2017, 06:27:09 pm »
Brian
Once you connect to the unit via telnet, the the first thing you'll want to do is make a copy of all of the files in /flash. The easiest way to do this, in my opinion, is to setup a FTP server on your computer and run an ftp client on the E7495a. The easiest way to modify the elgato binary is simply to do it on your host computer (using a tool that does hex editing -- there are plenty of these for windows, osx, linux). Then, you can use the FTP client to get the file back.
The other obvious way to make a backup is to simply dump things onto the CF card, insert into host computer, copy, and put it back in.
Destroying the elgato binary won't brick the unit, as far as I know. You'll still have telnet access. Plus, you can just 'cp elgato elgato.original'. There is enough space to have a few copies of the binary around.
Online PA0PBZ
« Reply #212 on: May 12, 2017, 06:33:33 pm »
Yup, and a 'killall elgato' to make sure you are not trying to patch a running executable.
Offline technogeeky
« Reply #213 on: May 12, 2017, 06:36:48 pm »
For future reference, in Linux there is no risk of modifying a running executable. The entire process tree of the executable (e.g. elgato and anything it runs or calls) will only be able to reference the original file. I am about 99% sure this is the case, at least.
Online PA0PBZ
« Reply #214 on: May 12, 2017, 06:39:22 pm »
I was thinking about copying back the patched file, that doesn't work when it's running, not sure about patching.
Offline DogP
« Reply #215 on: May 12, 2017, 07:28:27 pm »
Ah, yes... before posting, I ran the commands to make sure they worked, but not on the file actually running (since mine was already patched).  I just reverted mine to the original and tested it, and dd didn't like modifying the running file, so I updated the instructions to modify the copy of the file and then move the files.
I just tested it, and the new instructions do work.  All you have to do is simply telnet into the box, log in as root, and run the commands exactly as shown.  As pointed out, no matter how you patch the files, you need to make sure you're on the correct version.  I believe all of these patches are for 6.25.
There should be no reason that you'll brick your box though, since you should be able to simply telnet back in, and move the elgato.orig file back in place of the patched elgato binary.
Pat
Offline DogP
« Reply #216 on: May 12, 2017, 07:46:27 pm »
BTW, did you rule out Polycarbonate?  That would have been my first guess, just from looks and feel, and because it's commonly used for these types of things.  It definitely had an anti-glare coating or something on it... mine was REALLY scratched up (and had a few large gouges), so I used some Novus on it, and it took care of a lot of the scratches, but of course also took off the coating.  It's really nice and shiny now though. ;)
Pat
Offline technogeeky
  • Older New "New Player" Player Playa'
« Reply #217 on: May 12, 2017, 07:55:11 pm »
Pat
Pat: I can not rule out polycarbonate by the tests that I performed. PVF actually seems unlikely since I can't find it in sheets anywhere. Polycarbonate does seem more likely. It's hard to know, really. I don't remember a "phenol" smell when I burned it.
Nevertheless, since I agree it's far more likely to be polycarbonate, I'll switch the answer in the comment.
Offline usagi
« Reply #218 on: May 12, 2017, 08:43:50 pm »
yes, far more likely its polycarbonate - the rigidity of the protector screams polycarbonate to me. also the fact acetone damaged it.
Offline ke6iyc
« Reply #219 on: May 13, 2017, 12:09:34 am »
Good evening all!
OK, got the instrument in.
Two batteries, but I suspect one to be trashed (reading as 227% charged) other one is charging.
Also had a 64 MB PCMCIA Flash card in it (BIG bonus!).
Powered up no issue (once I figured out the operation of said power button).
Has all factory hardware options installed (per internal reporting) and there is only one software option I really want to enable (Interference ID).
Measured a good test cable, and it told me it was good.
Will do an update next (currently it has 5.00 on it....)
THEN on to the patches, and figuring out where to find an SMA GPS antenna locally.....
Thanks to all!
Brian
« Last Edit: May 13, 2017, 12:20:25 am by ke6iyc »
Offline ke6iyc
« Reply #220 on: May 13, 2017, 01:09:41 am »
Update to 6.25 went smoothly, as described here.
Telnet will have to wait until tomorrow, as the computer I have with me (that has a hardware serial port) has decided not to acknowledge that telnet is, in fact, installed....
Thanks to all!
Brian
Offline technogeeky
« Reply #221 on: May 13, 2017, 02:01:33 am »
Thanks to all!
Brian
Use putty like all of us.
Offline ke6iyc
« Reply #222 on: May 14, 2017, 02:15:12 pm »
Quote from DogP on Dec. 8 2016:
"I spent a bit of time looking at this again, trying to get some remote access/control working.  As noted earlier, the E7495 has a webpage, but doesn't accept the normal login.  I noticed a similar non-working login on port 5025.  Using netstat, I saw that elgato was listening on those ports.  When looking in the /flash/egServer directory, I noticed a passwd file.  It looked different than the standard *nix passwd file, but appeared to have a hashed root password in it (RzSdSbSdye).
Rather than trying to crack the password, I decided to try simply renaming the passwd file and rebooting.  Surprisingly, it didn't recreate it, and now simply accepts any login! (on both the webpage and port 5025)."
In playing around, I did as advised above, and renamed the passwd file, then rebooted.
I had PuTTY running on Serial port 2 during the reboot, and the last thing it spat out was:
"Note: No passwd file found. Adding user 'root' with password 'changeme'"
Not overly useful info, but something...
Brian
Offline DogP
« Reply #223 on: May 14, 2017, 04:19:31 pm »
I had come across "changeme" as well, but didn't see where it was used.  It didn't work as the original password, and once I got rid of the password file, it took any login (didn't require root/changeme).  Have you found where it's actually used?
Pat
Offline ke6iyc
« Reply #224 on: May 14, 2017, 05:10:02 pm »
No, thus the limited usefulness of the result....
Brian
Offline ke6iyc
« Reply #225 on: May 14, 2017, 05:36:47 pm »
What is the 7495 calling the PCMCIA card?
Thanks,
Brian
Offline kr5j
« Reply #226 on: May 15, 2017, 09:27:58 pm »
I did the patch but it didn't seem to fix the GPS. I went to the adjustment screen to sync the unit with GPS but GPS icon stayed yellow. I also added the license patch but when rebooted it didn't show any new options. So I thought I would try it again and now the unit boots up and hangs on the Copyrights screen. How can I recover?
Thanks
kr5j
Offline technogeeky
« Reply #227 on: May 16, 2017, 02:56:14 am »
Thanks
kr5j
You need to replace the elgato binary with the original, and start over. The only thing I can think if the patches didn't work, is you started with the wrong version of the binary (e.g. you did not upgrade the firmware first).
Offline kr5j
« Reply #228 on: May 16, 2017, 03:01:13 am »
Whew! Found a copy of A.06.25 FW, put it on a CF card and installed it and the unit is back to original performance. So the patches did not appear to work for me. I went back and installed just the license one but no new options appeared. If I do the GPS one, unit appears normal but if I try to go to the GPS adjustment screen, it hangs. But I did see the GPS icon go green at one point! I was using the date command to set the time/date and maybe that got it to go green but as soon as the FW changed the time it went yellow. the saga continues...
Offline technogeeky
« Reply #229 on: May 16, 2017, 03:20:20 am »
Let's focus on one thing at a time.
Remember, for the license hack, you have to also modify the license file for each license you wish to add. The trick that the patch provides is that the key isn't ever read, so it doesn't need to be valid. Perhaps you are not doing this step.
Once you have done the GPS patch, you do not want to be setting the date/time manually. The date/time will be set properly by the GPS. At the very least, you can use the web interface to set the date/time once, using the date/time of the PC you are browsing to it from. If you ever have the green circle, then you are in a state where you can do the timebase calibration. Note you probably want to have the unit on for some 30 minutes plus, and you want to make sure you have at least 5 or 6 satellites locked.
Offline ke6iyc
« Reply #230 on: May 16, 2017, 07:16:24 pm »
@kr5j
You also need to "install" the options, done on the unit itself.
They do not automatically appear...
Brian
Offline kr5j
« Reply #231 on: May 16, 2017, 09:07:46 pm »
I started with A.06.25 FW then did the GPS patch. I rebooted and the GPS patch appears to have worked, now the GPS info has the current UTC time. Also the GPS icon turns green! Then I did the license patch and it appears to have worked but cannot access the screen to see installed options. Also cannot get to the GPS adjustment screen. The problem that is once the unit boots up, I select System then press More 2 of 2 to get to Page 2. Unit takes a few seconds then all the button labels on the left side of the screen disappear. Unit stays in this condition and does not respond to any button presses. I have to reboot to get the unit operational again. Why would either patch affect it this way?
Offline DogP
« Reply #232 on: May 17, 2017, 01:13:52 am »
I had that same problem: https://www.eevblog.com/forum/testgear/agilent-e7495-linux-root-account/msg1053888/#msg1053888 .  You need to modify the /flash/egServer/license/elgato.lic file and add a SIGN value (like SIGN=000000000000 ) to any that don't already have a SIGN.
Pat
Offline ve7xen
    • VE7XEN Blog
« Reply #233 on: May 17, 2017, 08:52:07 am »
Curious, because rollover last happened in 1999 and doesn't happen again until 2019. The instrument was released sometime around 2002-3. So I kind of thought of that but wrote it off as something else. It's definitely this though, probably the firmware is checking some arbitrary date in the past to decide what GPS epoch it is in, and how many weeks to add. We went past that boundary date, so it think it's pre-1999 again. If anyone's curious, the disassembly of the patched region is:
old
0x2122880: 4b 25 85 e2   r2 = r5 + 314572800
0x2122884: 15 28 82 e2   r2 = r2 + 1376256
0x2122888: f6 2d 82 e2   r2 = r2 + 15744
new
0x2122880: de 25 85 e2   r2 = r5 + 931135488
0x2122884: 3f 28 82 e2   r2 = r2 + 4128768
Which adds exactly 1024 weeks to the constant.
Nice work on the patch and thanks! I couldn't crack it.
73 de VE7XEN
He/Him
Offline kr5j
« Reply #234 on: May 18, 2017, 01:22:25 am »
I copied the legato.lic file to mnt but it does not appear on the CF card. There were also 2 screen shots in the mnt folder and they are not on the CF card. I did a screenshot and when I opened the CF card on my PC the screenshot was there but nothing else. How do I put the legato.lic file on the CF card? I tried the mount /devf/hdc1/ /mnt command and it said it failed: not a directory.
Offline DogP
« Reply #235 on: May 18, 2017, 09:47:57 am »
You should use the command "mount /dev/hda1 /mnt" (no trailing slash after hda1).  On my box the CF is hda, not hdc... but if for some reason yours is hdc, then use that.  And I assume "legato.lic" and "/devf/" are just typos in your reply (should be "elgato.lic" and "/dev/" respectively).
Pat
Offline kr5j
« Reply #236 on: May 18, 2017, 09:03:13 pm »
Yep the fat finger of fate struck. What are the commands to copy the license file to the CF card and then the modified file back? I think my CF card is hda1. Here is what I get with a df -h command:
[root@E749xx /]$df -h
Filesystem                Size      Used Available Use% Mounted on
rootfs                    7.7M      6.1M      1.2M  83% /
/dev/root                 7.7M      6.1M      1.2M  83% /
/dev/mtdb3               60.0M     21.6M     38.4M  36% /flash
But none of these is the CF card inserted, since it is a 500 MB card. Not sure what the disks listed are.
If I press the Media Manager button from System, it shows the CF card format button highlighted indicating it is recognized by the system.
Offline technogeeky
« Reply #237 on: May 18, 2017, 11:08:48 pm »
kr5j:
File Locations (first the ones you need, second some interesting locations):
  • /dev/hda is, for me, the PCMCIA card's device file.
  • /dev/hda1 is, for me, the PCMCIA card's first (and only) partition.[a]
  • /flash/mnt/pcmcia is the directory where the Agilent mounts and then stores screenshots and data.
  • /flash/egServer/elgato is the elgato (transponder server) binary. This is where the binary patching happens.
  • /flash/egServer/license/elgato.lic is the file where the license information is stored.
  • /flash/linux are all of the extra files that Agilent includes, on top of BusyBox (which is a barebones set of Linux commands). [2]
As far as the elgato file goes, the following sha256 hashes should tell you if you have the same file or not. Copied from sha256sum command[c]:
  • 8f4bfc453ed7aa871bba7ea2301bb29280466c36f78f703302b5348ec44612f0  elgato.original
  • 5a857ab04ce60f4a149682299bbd860649f36478e29e4693870a8624a4eafad7  elgato.nokeys
  • ec57d11b6151795ba2c6f6979cb789622dc24c263fef70ca4791780f4525e771  elgato (nokeys and clock patch)
Tips:
df reports results for each mounted disk. Until you do something with the GUI that will cause a write to the disk (try to save file, save data, or format PCMCIA), the unit won't even mount it. You can manually mount the disk, in its proper location, by typing:
mount /dev/hda1 /flash/mnt/pcmcia
Then, you can browse to /flash/mnt/pcmcia to read (or copy) files you stored on the device. Picture and data saves will now also work (assuming the device can read your partition).
[a]: Again, for me, I formatted it as ext3. You can use fat16, I think. I am not sure about fat32.
[2]: Notice they have their own copy of ps, grep. They also have some custom scripts like elgatosleep, diagServer, enable_matrix_kb. And then some are just configuration files, like the files in /etc. do "find ." in /flash/linux to see this stuff.
[c]: Since sha256sum isn't included in BusyBox or agilent's files, then you'll have to do this on your desktop or whatever.
Offline kr5j
« Reply #238 on: May 19, 2017, 04:57:56 pm »
I edited the license file with VI and now have all options. Still not clear on how to copy a file to the CF card but will pursue it.
Thanks for the help. So now my E7495A has a green GPS indicator and all options.
Online PA0PBZ
« Reply #239 on: May 19, 2017, 05:05:32 pm »
Just for the record, there is no need to edit the license file if you can't work it out. You can use the built in menu to add licenses, just use anything you like for the license key.
Offline technogeeky
« Reply #240 on: May 19, 2017, 06:45:02 pm »
If you are using the CF card, insert it, then, for instance to copy the elgato binary:
mount /dev/hda1 /flash/mnt/cf
cp /flash/egServer/elgato /flash/mnt/cf
If you are using a (CF or SD) to PCMCIA adapter:
cp /flash/egServer/elgato /flash/mnt/pcmcia
Note that it might be /dev/hda2.
Offline kr5j
« Reply #241 on: May 19, 2017, 08:10:25 pm »
Ah it was that easy to do! But I had more fun using VI editor :)
Offline technogeeky
« Reply #242 on: June 21, 2017, 01:57:17 pm »
Has anyone made any progress on unlocking whatever potential might be in the CW source (or the modulated version, 510)?
I'd really like to learn if there is potential to extend the frequency range of the output downward. 100kHz would be nice, but even 10 MHz would do just fine.
Has anyone ever opened up the CW/mod and taken a guess at what the restriction actually is? I still haven't had the time or courage to open up my E7495a, but I would be happy to do so if it would help someone figure out a starting point to getting lower frequency output.
Offline kr5j
« Reply #243 on: July 11, 2017, 08:08:04 pm »
How to enable the demod option?????
Offline kirill_ka
  • Country: ru
« Reply #244 on: July 12, 2017, 08:49:26 am »
There's no such option. E7495 demodulation options are limited to cellular phone stuff.
Offline TheSteve
  • Living the Dream
« Reply #245 on: July 12, 2017, 04:07:00 pm »
The N1996A supports AM/FM demod though - so you never know if it can be enabled on the E7495.
VE7FM
Online PA0PBZ
« Reply #246 on: July 12, 2017, 05:30:51 pm »
The option code for the N1996A is AFM so if you have a liberated E7495 just give it a try.
Offline kirill_ka
  • Country: ru
« Reply #247 on: July 12, 2017, 07:24:07 pm »
How do you know that I never know?
toroServer/Dragonfly/Measurements/KernelBasic/Superfly/Am*
toroServer/Dragonfly/Measurements/KernelBasic/Superfly/Fm*
toroServer/Dragonfly/Measurements/KernelBasic/Superfly/am.txt
toroServer/Dragonfly/Measurements/KernelBasic/Superfly/fm.txt
That DSP stuff looks like AM/FM demodulation code for N1996A, doesn't it?
It's not present in egServer. And adding functionality is not just a matter of copying missing files.
Offline technogeeky
« Reply #248 on: March 07, 2018, 04:25:01 am »
I wanted to bring to attention what I believe is an example of drifting or failing calibration. In a specific sense, none of this matters (because you are probably going to normalize, which makes the measurement you make relative to the problematic measurement below). It's still interesting, and I'd love to hear speculation on why this is happening. I can make further measurements (such as using a different spectrum analyzer to view the output, or a SDR).
The following will tell you the default settings after preset, then show which one or two things to change from the previous. For all tests, the only connection is a 0.5 meter Agilent N-to-N cable.
Two Port Insertion Loss (default settings)
* 375 MHz - 2.5 GHz
* Source Lev Auto (10 dBm)
* Optimize Accy
So when we go to a preset configuration, we have a sudden downward jump at 1 GHz. In addition, the average insertion loss is genuinely lower than it should be. Substituting a different cable has no effect:
If we pick a manual output level, then we can cut down on this effect...
* 375 MHz - 2.5 GHz
* Source Lev Manual (0 dBm)
* Optimize Accy
And if we keep reducing the output level, we can eventually make this jump very small:
* 375 MHz - 2.5 GHz
* Source Lev Manual (-10 dBm)
* Optimize Accy
If we change to "Range" mode, this sharp jump effect totally disappears but the insertion loss offset does not change.
* 375 MHz - 2.5 GHz
* Optimize Range
Likewise, if we change to Manual source level and change it to - 10dBm, we get a more or less correct measurement of insertion loss:
* 375 MHz - 2.5 GHz
* Source Lev Manual [/b](-10 dBm)[/b]
* Optimize Range
In case you think this is an effect which shows up only when you have a large span, it's exactly the same up close:
* 999 MHz - 1001 MHz
* Optimize Range
* Source Lev
Any thoughts, guesses, or further tests would be appreciated. I have SDRs which I can use to monitor the output from the CW/generator. I can use another spectrum analyzer to view the output. I think I've done this, and I didn't see any sudden jumps at 1GHz exactly. Likewise, when I use another signal generator into this spectrum analyzer (E7495a), I similarly do not see any sudden jump. So this leads me to believe that this effect is from some sort of calibration table that the unit stores for the Two Port Insertion measurement mode specifically.
It's worth noting, too, that the procedure for this originally calls for using a two 10dB attenuators (back to back) on the RF out port. Using an attenuator set  does, of course, reduce this effect but it's still noticeable.
« Reply #249 on: March 10, 2018, 11:11:15 am »
I can verify this effect with my E7495B. But this is not erroneous behavior: it is caused by the preamp not spanning the complete frequency range (see https://www.eevblog.com/forum/testgear/agilent-e7495-linux-root-account/msg621126/#msg621126).
When do the test with a short cable (RG316) and a 20dB attenuator, the insertion loss measurement is flat to within 2dB. After normalization I get a nice straight line across the whole frequency range. The insertion-loss measurement is probably designed for longer cable runs with significant loss. This would explain the use of the 20dB attenuation when normalizing. So if your cable is quite short and has negligible attenuation the preamp is saturating, thus giving you wrong results.
Offline technogeeky
« Reply #250 on: March 10, 2018, 04:52:01 pm »
Thanks!
I had another problem yesterday which I'm sure is new. The display on the unit keeps turning off the backlight, crazy fast. I can actually sometimes catch it saying in the status bar something like "Turning off backlight in 3 seconds" with a countdown.
Any ideas where this could be stopped or configured?
Offline technogeeky
« Reply #251 on: March 11, 2018, 06:18:42 am »
Thanks!
This, along with another problem (the network interface not working), just disappeared after I left the unit unplugged for a while (a few hours). So that's good and bad, but more good than bad.
I still had practical problems making two port insertion loss measurements (even with 20dB worth of pads) and Auto (+10dBm) output level. I would get sudden burst of uncertainty in the response right after 1GHz, for almost 500MHz. In any case, I managed to make the measurements by going to 0dB.
