Author Topic: Help identifying unknown mystery device  (Read 2308 times)
Offline PeterFWTopic starter
    • Stuff that goes boom
« on: April 15, 2016, 01:48:57 pm »
Hello everybody!
In another forum someone asked if anybody knows what this is, it is the only picture he posted:
https://i.reddituploads.com/ce1170fa0ba143d493b1f8913e71eefe?fit=max&h=1536&w=1536&s=589725836e4ac90f155c2e066b63fb1d
My best guess so far, thermocouple meter with calibration function/output.
Maybe someone here knows what it really is.
Greeting,
Peter
Offline PedroDaGr8
  • A sociable geek chemist
Re: Help identifying unknown mystery device
« Reply #1 on: April 15, 2016, 02:20:59 pm »
According to the internet Foster Cambridge PP332 is a portable potentiometer 20/60mV. It looks more or less identical to this one. In this case, potentiometer I think is the British meaning which is a device which measures electrical potential (ie voltage). It looks to be a null voltage model. I guess the temperature aspect is to account for temperature driift.
« Last Edit: April 15, 2016, 02:22:41 pm by PedroDaGr8 »
The very existence of flamethrowers proves that some time, somewhere, someone said to themselves, "You know, I want to set those people over there on fire, but I'm just not close enough to get the job done." -George Carlin
The following users thanked this post: PeterFW
Offline DTJ
« Reply #3 on: April 15, 2016, 04:43:02 pm »
You use this to calibrate thermocouple indicators, giving an accurate voltage that corresponds to a set temperature less the cold junction voltage. Dual use as you can also use it to set the loop resistance for use with said meter, adjusting a variable resistor to set the resistance to a predetermined value with a cold thermocouple. While you could also use it to read the thermocouple using the null meter that was really just used as a test of the thermocouple. Only time you really used that was in the calibration or verification of the unit against a more precision reference voltage source.
Offline uncle_bob
« Reply #4 on: April 16, 2016, 12:44:16 am »
Hi
Back in the days that factories were full of temperature controls based on thermocouples, these boxes were *very* common. At least a couple of dozen companies made them. Keeping a machine so it ran at the right temperature might have involved multiple calibration passes each year. If shutting down the machine meant $$$ wasted ... you bought multiple calibrators and a crew of people did the calibration in a day rather than one guy doing in in a couple weeks.
There are a lot quicker / better / easier / cheaper ways to do it today. You see a *lot* of those gizmos on the auction sites. Generally they are dirt cheap compared to what they once sold for.
Bob
« Reply #5 on: April 16, 2016, 06:26:08 pm »
Hello and thank you everybody,
now i can sleep peacefully without beeing bothered not knowing what it is! :)
Greetings,
Peter
