Author Topic: EEVblog 121GW Disassembly?  (Read 1667 times)
Offline ANTALIFETopic starter
  • ( ͡° ͜ʖ ͡°)
    • Muh Blog
« on: January 09, 2018, 08:40:52 am »
How on earth do you remove the little brass insert?
Offline andtfoot
Re: EEVblog 121GW Disassembly?
« Reply #1 on: January 09, 2018, 10:32:34 am »
There's a circlip style thingie (e ring/clip) behind the circuit board that keeps it retained on the front housing.
The following users thanked this post: ANTALIFE
Offline EEVblog
« Reply #2 on: January 09, 2018, 10:52:23 am »
Once you undo the screws holding down the PCB, the PCB should just lift out (may need a bit of a lever) leaving the brass insert behind in the case.
You do NOT have to remove the plastic clip in order to get the PCB out of the case.
