Author Topic: Agilent L4411A (headless version of 34410A and 34411A) troubleshooting  (Read 1266 times)
Offline zrqTopic starter
Does anyone have information on the power supply module in Agilent L4411A?
I got one from ebay when in the US for a conference, but when I returned to Switzerland, its power supply got unhappy. When it works, it can keep running for a few hours without problem. But it appears if I leave it on for a time more than 30min, then it will not start in the next turn on. When it's dead, the 12V output of the SMPS module is 0V, and it somehow recovers automatically after disconnecting the power cord for a few minutes. It doesn't look like there is a short in the main board, as the same can happen even when the meter is not turned on and left plugged in for a while.
The power supply part of L4411A seems to be quite different from the human interfaced cousins (34410A and 34411A). Instead of a transformer and linear regulators to power everything, a basic 12V 2A OEM SMPS (Phihong PSA25L-120-R) is used to obtain unregulated DC, then switchers and an additional transformer are used to power the floating part. Finding a 12V 2A SMPS sounds not too hard, but the original seems to be discontinued. Anyone can suggest a replacement? Is there any risk of using power supply modules in adapter form factor? Common mode voltage?
Offline TheSteve
  • Living the Dream
I'd start by swapping all of the electrolytic capacitors in it - chances are that will fix it.
VE7FM
Yeah that can be an option, but I'm not sure if this is going to be cheaper than swap out the entire module. Or have anyone seen this failure mode before can point out where in particular should I look around for failing caps, so I don't need to change all.
The meter is actually less than 10 years old and it would be a bit surprising that capacitors already start failing this soon.
Offline coromonadalix
There is 34410a  schematics floating around (attached here) who is maybe 85 -90% of the same technology, there is none for the L4411A and none for the 34411a
you have a thread here with picture wich i contributed
https://www.eevblog.com/forum/testgear/agilent-l441a-multimeter-teardown/
The main psu is based on a MSC Lx  ic ....  you can find the spec sheets,  it work with the red colored xformer put on the frame  to give +18 -18 and a 5vdc to the analog part
and you have the other  smps  module under the flat cable  ....
And pls   dont rush to change parts to change parts ......   if not send me the meter ill check it   loll,  i had one of theses  not too long ago and now im on a 34410a, i needed buttons  loll
Fully controllable with the old agilent  dmm software, and some R&S  visa drivers ( better than Keysight )
There is TestController who could control it, but you need to define some coding to properly use it.
It would not be a problem  to change this smps with another of the same specs,  just take one who can go up to 240 - 265 Vac   ....  like some meanwell, traco, avoid china crap
traco TPI 50-112A-J  .... and they dont cost a fortune, mmmm   sure slightly expensive over china crap  loll
sorry  i did not want to insult you in any ways by the way  ...
« Last Edit: May 16, 2023, 04:49:00 pm by coromonadalix »
It's an interesting design to use a class D power amp chip (LX1722CDB) to drive transformers for the in-guard power transformer. Maybe Agilent was considering making DC power an option, so took such a detour in the power supply? Or just because the 34410/1A transformer is too big to fit in 1U height?
It appears the PSU is getting quite hot when the meter refuse to turn on, maybe it overheats and fall to protection, either because of itself or something is wrong on the main board. Going to try powering the main board with a lab PSU and see if it drains too much current.
yeah  myself  i was surprised to see this technology used to create some smps supply  loll
Tried to replace the power supply with a Meanwell EPS-65S-12, it should have worked fine after modifing the connector from 5 pin to 4 pin. However, I'm too stupid to properly fix the open frame PSU to the chassis and something on the AC side shorted to the earth by the screw hole, a big boom and RIP the Meanwell. Luckily the meter itself is intact.
I'll revert to the original PSU before I can justify my next digikey order.
mmm you played hard in this one  lolll
