#UPDATE
I have just restored dso_ready.bin to my DSO1062B, it can boot into linux. What can I do now?
I really need a complete backup bin file of DSO1062B, does anyone have it?
##### EmbedSky BIOS for SKY2440/TQ2440 #####
Press Space key to Download Mode !
Booting Linux ...
Copy linux kernel from 0x00200000 to 0x30008000, size = 0x00200000 ... Copy Kernel to SDRAM done,NOW, Booting Linux......
Uncompressing Linux... done, booting the kernel.
Linux version 2.6.30.4 (root@localhost.localdomain) (gcc version 4.3.3 (Sourcery G++ Lite 2009q1-176) ) #17 Sun Oct 9 14:24:29 CST 2011
CPU: ARM920T [41129200] revision 0 (ARMv4T), cr=c0007177
CPU: VIVT data cache, VIVT instruction cache
Machine: TQ2440
ATAG_INITRD is deprecated; please update your bootloader.
Memory policy: ECC disabled, Data cache writeback
CPU S3C2440A (id 0x32440001)
S3C24XX Clocks, (c) 2004 Simtec Electronics
S3C244X: core 400.000 MHz, memory 100.000 MHz, peripheral 50.000 MHz
CLOCK: Slow mode (1.500 MHz), fast, MPLL on, UPLL on
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 16256
Kernel command line: noinitrd root=/dev/mtdblock2 init=/linuxrc console=ttySAC0
NR_IRQS:85
irq: clearing pending ext status 00080100
irq: clearing subpending status 00000003
irq: clearing subpending status 00000002
PID hash table entries: 256 (order: 8, 1024 bytes)
Console: colour dummy device 80x30
console [ttySAC0] enabled
Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
Memory: 64MB = 64MB total
Memory: 61316KB available (3116K code, 333K data, 100K init, 0K highmem)
SLUB: Genslabs=11, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
Calibrating delay loop... 199.47 BogoMIPS (lpj=498688)
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
net_namespace: 296 bytes
NET: Registered protocol family 16
S3C2440: Initialising architecture
S3C2440: IRQ Support
S3C24XX DMA Driver, (c) 2003-2004,2006 Simtec Electronics
DMA channel 0 at c4808000, irq 33
DMA channel 1 at c4808040, irq 34
DMA channel 2 at c4808080, irq 35
DMA channel 3 at c48080c0, irq 36
S3C244X: Clock Support, DVS off
bio: create slab <bio-0> at 0
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
cfg80211: Calling CRDA to update world regulatory domain
NET: Registered protocol family 2
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 2048 (order: 2, 16384 bytes)
TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
TCP: Hash tables configured (established 2048 bind 2048)
TCP reno registered
yaffs Sep 30 2011 10:36:32 Installing.
msgmni has been set to 119
alg: No test for stdrng (krng)
io scheduler noop registered (default)
s3c2440-uart.0: tq2440_serial0 at MMIO 0x50000000 (irq = 70) is a S3C2440
s3c2440-uart.1: tq2440_serial1 at MMIO 0x50004000 (irq = 73) is a S3C2440
s3c2440-uart.2: tq2440_serial2 at MMIO 0x50008000 (irq = 76) is a S3C2440
loop: module loaded
Driver 'sd' needs updating - please use bus_type methods
Driver 'sr' needs updating - please use bus_type methods
S3C24XX NAND Driver, (c) 2004 Simtec Electronics
s3c2440-nand s3c2440-nand: Tacls=2, 20ns Twrph0=3 30ns, Twrph1=2 20ns
NAND device: Manufacturer ID: 0xec, Chip ID: 0x76 (Samsung NAND 64MiB 3,3V 8-bit)
Scanning device for bad blocks
Creating 3 MTD partitions on "NAND 64MiB 3,3V 8-bit":
0x000000000000-0x000000040000 : "EmbedSky_Board_uboot"
0x000000200000-0x000000400000 : "EmbedSky_Board_kernel"
0x000000400000-0x000003ff8000 : "EmbedSky_Board_yaffs2"
ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
s3c2410-ohci s3c2410-ohci: S3C24XX OHCI
s3c2410-ohci s3c2410-ohci: new USB bus registered, assigned bus number 1
s3c2410-ohci s3c2410-ohci: irq 42, io mem 0x49000000
usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
mice: PS/2 mouse device common for all mice
S3C24XX RTC, (c) 2004,2006 Simtec Electronics
s3c2410-rtc s3c2410-rtc: rtc disabled, re-enabling
s3c2410-rtc s3c2410-rtc: rtc core: registered s3c as rtc0
Linux video capture interface: v2.00
S3C2410 Watchdog Timer, (c) 2004 Simtec Electronics
s3c2410-wdt s3c2410-wdt: starting watchdog timer
s3c2410-wdt s3c2410-wdt: watchdog active, reset abled, irq enabled
mapped channel 0 to 0
s3c2440-sdi s3c2440-sdi: powered down.
s3c2440-sdi s3c2440-sdi: initialisation done.
Advanced Linux Sound Architecture Driver Version 1.0.18a.
No device for DAI UDA134X
No device for DAI s3c24xx-i2s
S3C24XX_UDA134X SoC Audio driver
UDA134X SoC Audio Codec
asoc: UDA134X <-> s3c24xx-i2s mapping ok
ALSA device list:
#0: S3C24XX_UDA134X (UDA134X)
TCP cubic registered
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
lib80211: common routines for IEEE802.11 drivers
s3c2410-rtc s3c2410-rtc: setting system clock to 2021-01-23 14:45:23 UTC (1611413123)
yaffs: dev is 32505858 name is "mtdblock2"
yaffs: passed flags ""
yaffs: Attempting MTD mount on 31.2, "mtdblock2"
yaffs_read_super: isCheckpointed 0
VFS: Mounted root (yaffs filesystem) on device 31:2.
Freeing init memory: 100K
__init s3c24xxfb_probe
setting vert: up=26, low=4, sync=2
setting horz: lft=4, rt=14, sync=32
s3c2410fb_activate_var
S3C2410_LCDCON1_CLKVAL(default_display->setclkval)=1
Console: switching to mono frame buffer device 100x30
fb0: s3c2410fb frame buffer device
lcd_init
dso-lcd1 initialized
var.xres=800
var.yres=480
var.bits_per_pixel=8
var.xres_virtual=800
var.yres_virtual=480
fix.id=s3c2410fb
fix.smem_start=866123776
fix.smem_len=768000
fix.type=0
fix.type_aux=0
fix.xpanstep=0
fix.ypanstep=0
fisetting vert: up=18, low=13, sync=3
setting horz: lft=20, rt=6, sync=38
x.ywrapstep=0
fix.line_length=800
argv[1]=16
var.xres=800 var.yres=480 var.bits_per_pixel=16
show logo,video_buf_size = 768000
bwscon:0x2201d110
fpga bank 221422
dso-fpga: install ok
bwscon:0x2201d110
fpga bank 221422
dso-fpga-la: install ok
dso-spi initialized
Init spi success!
New Log Write OK Length:21
dso-spi-la initialized
Init spi success!
s3c2440_clkcon=00FE7FF0
fpga download file_name :/dn.rbf
status: 0x1
fpga_down_load file name : /dn.rbf.
data DOWN finish.
dso-spi:FPGA_DOWNLOAD ok.
release
fpga download file_name :/la_top.rbf
In spi_ioctl:arg=-1096999046
copy-from-user ok
dn_file_name:/la_top.rbf
in opt-download-fpga
nconfig: 0x1
status: 0x1
fpga_down_load file name : /la_top.rbf.
data DOWN finish.
dso-spi-la:FPGA_DOWNLOAD ok.
release
dm9000 Ethernet Driver, V1.31
dm9000 dm9000.0: read wrong id 0x002affff
dm9000 dm9000.0: read wrong id 0xffffdfff
dm9000 dm9000.0: read wrong id 0xffffffff
dm9000 dm9000.0: read wrong id 0x2b2affff
dm9000 dm9000.0: read wrong id 0x2b2a2928
dm9000 dm9000.0: wrong id: 0x2b2a2928
dm9000 dm9000.0: not found (-19).
Try to bring eth0 interface up ...
ifconfig: SIOCGIFFLAGS: No such device
ifconfig: SIOCSIFHWADDR: No such device
ifconfig eth0 hw ether 10:23:45:67:89:ab
Hantek GPIO(buzzer/speaker),(c)20110309
gpioG11 initialized
speaker on
ifconfig: SIOCSIFADDR: No such device
ifconfig eth0 192.168.100.155 netmask 255.255.255.0 up
/sbin/net_set: line 5: route: not found
add default gw 192.168.100.255
Done
Beep
dso-buzzer initialized
i2c /dev entries driver
s3c2440-i2c s3c2440-i2c: slave address 0x10
pdata->frequency=6000
s3c2440-i2c s3c2440-i2c: bus frequency set to 9 KHz
s3c2440-i2c s3c2440-i2c: i2c-0: S3C I2C adapter
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
s3c2410_udc: debugfs dir creation failed -19
s3c2440-usbgadget s3c2440-usbgadget: S3C2440: increasing FIFO to 128 bytes
g_serial gadget: Gadget Serial v2.4
g_serial gadget: g_serial ready
s3c2440_clkcon=00FF7FF0
status: 0x1
data DOWN finish.
release
no update file to foud
now run app .....
var.xres=800
var.yres=480
fix.id=s3c2410fb
fix.smem_stsetting vert: up=26, low=4, sync=2
art=866123776
fix.smem_len=768000
fix.type=0
fix.type_aux=0
fix.xpanstep=0
fix.ypanstep=0
fix.ywrapstep=0
fix.line_length=1600
argv[1]=8
var.xres=800 var.yres=480 var.bits_per_pixel=8
Please press Enter to activate this console. mkdir: can't create directory '/param': File exists
mkdir: can't create directory '/param/sav': File exists
now pwm_value:0
now pwm_value:56
â–’*** Warning - bad CRC or NAND, using default environment
Booting Linux ...
Machine: TQ2440
NR_IRQS:85
TCP reno registered
loop: module loaded
ALSA device list:
s3c2410-rtc s3c2410-rtc: setting system clock to 2021-01-23 14:46:53 UTC (1611413213)
llkil^Ckiall dso__init s3c24xxfb_probe
lcd_init
dvar.xres=800
var.yres=480
fix.id=s3c2410fb
fix.smem_len=768000
fix.type=0
fix.type_aux=0
fix.xpanstep=0
fix.ypanstep=0
x.ywrapstep=0
fix.line_length=800
argv[1]=16
bwscon:0x2201d110
fpga bank 221422
bwscon:0x2201d110
fpga bank 221422
dso-spi initialized
Init spi success!
Init spi success!
status: 0x1
kialldata DOWN finish.
release
In spi_ioctl:arg=-1090797702
copy-from-user ok
nconfig: 0x1
status: 0x1
fpga_down_load file name : /la_top.rbf. data DOWN finish.
release
dm9000 dm9000.0: read wrong id 0x002a0028
dm9000 dm9000.0: read wrong id 0x6993bfaa
dm9000 dm9000.0: read wrong id 0xff8d6c91
dm9000 dm9000.0: wrong id: 0xff8d6c91
gpioG11 initialized
speaker on
kifconfig: SIOCSIFADDR: No such device
Done
Beep
illi2c /dev entries driver
as3c2440-i2c s3c2440-i2c: slave address 0x10
llInitializing USB Mass Storage driver...
dg_serial gadget: Gadget Serial v2.4
ss3c2440_clkcon=00FF7FF0
status: 0x1
o
data DOWN finish.
release
now run app .....
var.xres=800
var.yres=480
fix.id=s3c2410fb
fix.smem_stasetting vert: up=26, low=4, sync=2
rt=866123776
fix.smem_len=768000
fix.type=0
fix.type_aux=0
fix.xpanstep=0
fix.ypanstep=0
fix.ywrapstep=0
argv[1]=8
Please press Enter to activate this console. [root@Hantek /]# kikillall dso
-/bin/sh: kikillall: not found
[root@Hantek /]# kimkdir: can't create directory '/param': File exists
llmkdir: can't create directory '/param': File exists
now pwm_value:0
all dnow pwm_value:56
sdo
killall: dsdo: no process killed
[root@Hantek /]# killall dso
killall: dso: no process killed
[root@Hantek /]# killall dsod
[root@Hantek /]# release
sync
save exit: isCheckpointed 0
[root@Hantek /]# cp /mnt/udisk/dso.exe /
cp: can't stat '/mnt/udisk/dso.exe': No such file or directory
[root@Hantek /]# mount -f /mnt/udisk
mount: can't find /mnt/udisk in /etc/fstab
[root@Hantek /]# ls /etc/fstab
/etc/fstab
[root@Hantek /]# fstab
-/bin/sh: fstab: not found
[root@Hantek /]# /etc/fstab
-/bin/sh: /etc/fstab: Permission denied
[root@Hantek /]# cd /mnt/udisk
[root@Hantek udisk]# ls
[root@Hantek udisk]# cd ..
[root@Hantek /mnt]# ls
sd udisk
[root@Hantek /mnt]# cd udisk
[root@Hantek udisk]# ;s
-/bin/sh: syntax error: unexpected ";"
[root@Hantek udisk]# ls -i
[root@Hantek udisk]# ls -li
total 0
sd udisk
[root@Hantek /mnt]# cd ..
[root@Hantek /]# ls
OurLanguages fpgabank.conf logotype sendspi-la
bin help.db logotype.dis sys
cur_acq.type home lost+found sys.inf
dev i2c.log mnt tmp
disk_sta.info icon msg tmpdst
dn.rbf keyprotocol.inf opt tmpp
dso la_top.rbf param usr
dso-fpga-bak.ko language.img proc var
dso.exe lib protocol.inf
dst1202b linuxrc root
etc logo sbin
[root@Hantek /]#
