Author Topic: Agilent N1996A software unlock  (Read 29673 times)
Offline yamakasi8686Topic starter
  • Country: ru
« on: April 04, 2018, 09:03:42 am »
Hello, everybody.
I have an old Agilent N1996A spectrum analyzer.
Could you to help me software unlock tis device to have got more option? How can I get root?
Offline PA0PBZ
Re: Agilent N1996A software unlock
« Reply #1 on: April 13, 2018, 07:36:17 pm »
Did you try to search the forum?
  • Country: ru
« Reply #2 on: April 14, 2018, 04:28:17 pm »
Hello, PA0PBZ, thanks for your responce.
Ofcourse, I tried.
I had red the post: https://www.eevblog.com/forum/testgear/agilent-e7495-linux-root-account/ , but I can't start FTP session on my N1996A, all my login/password do not right.
Offline PA0PBZ
« Reply #3 on: April 14, 2018, 05:53:44 pm »
You have mail.
Offline geekdoug
« Reply #4 on: May 23, 2018, 02:18:34 pm »
I know this is an older thread, but I'm having the same issue. I've been through the other thread, but keep hitting roadblocks. Any help would be appreciated!!
Offline PA0PBZ
« Reply #5 on: May 23, 2018, 06:48:33 pm »
You got mail.
The following users thanked this post: Netsniper
Offline startronic
  • Country: br
« Reply #6 on: June 11, 2018, 10:57:52 pm »
Hello PAOPBZ
you can also send root to min for the N1996a
tanks
Offline analogRF
« Reply #7 on: April 08, 2019, 12:58:36 pm »
Hi
I have got a N9320B spectrum analyzer which is stuck at boot. after the Agilent splash screen there is a Keysight logo splash screen and then it gets stuck on that screen.
I am hoping I can connect to it through the LAN port (haven't tried yet) but I have no idea what the root username and password might be.
I thought maybe the passwd from N1996A could work if someone can send it to me.
BTW, I tried the USB host at the back but it was not detected on my laptop
I was also thinking maybe a CMOS reset (taking out the CMOS battery which is the only thing accessible on CPU board) might do something, any advice? I have no idea about its past history. All I know is that it came from a university lab and apparently it just stopped booting one day
Offline TheSteve
  • Living the Dream
« Reply #8 on: April 08, 2019, 04:12:07 pm »
The N9320B and N1996A don't share any hardware/design as far as I know.
VE7FM
Offline tv84
  • Country: pt
« Reply #9 on: September 26, 2020, 08:55:33 pm »
With this picture, you don't need patching...  ;)
The following users thanked this post: analogRF, zrq
Offline analogRF
« Reply #10 on: September 26, 2020, 09:19:27 pm »
this is not for N9320B, is it?
Offline tv84
  • Country: pt
« Reply #11 on: September 26, 2020, 09:29:57 pm »
 :-// Can't you test it?
Offline analogRF
« Reply #12 on: September 26, 2020, 09:35:22 pm »
not at the moment because i dont have access to it for a while (it's all opened and boards are piled up for later because needs repair)
but I dont think it is based on flexlm. I have looked into the debug port many times and i have also looked around the instrument's flash rom
Never saw any reference to flexlm anywhere.
Offline rogersstuart
« Reply #13 on: January 14, 2021, 07:25:51 pm »
I tried to enable an option on the N1996A through the UI and neither of those keys worked. How should I use them?
Offline PA0PBZ
« Reply #14 on: January 14, 2021, 07:35:28 pm »
From memory: enter the option, then enter the generated key.
If you want help post your hostid, the option and the key you generated and we can have a look.
Or if you don't want to post that public send me a PM with the same.
« Reply #15 on: January 14, 2021, 08:26:51 pm »
Actually, I just typed in what I saw in the screenshot a few posts back. So, there's a FLEXlm keygen? My host ID is 307929DE. Most of the options are enabled. I just figured it fully option it out. The only locked options remaining are 271 Spectrogram, AFM AM/FM Tune and Listen, and N8996A-1FP AM/FM Modulation Analyzer. There's also 330-380 but I think those are installable programs that Agilent/Keysight used to offer.
« Reply #16 on: January 14, 2021, 10:10:12 pm »
Okay, so I was able to telnet in. I'm not exactly sure what I should be looking for. I did search Google for the key generator in the image but I wasn't able to quickly find anything. I would try adding a line to this file but surely there's more security than that?
guest@N1996A:/flash/toroServer/license$ cat elgato.lic
FEATURE GPS agilent 1.000 permanent uncounted \
        HOSTID=ID_STRING=307929DE
FEATURE P03 agilent 1.000 permanent uncounted \
FEATURE 500 agilent 1.000 permanent uncounted \
FEATURE 503 agilent 1.000 permanent uncounted \
FEATURE 506 agilent 1.000 permanent uncounted \
        HOSTID=ID_STRING=307929DE SIGN=B7C02E16A4D2
FEATURE P06 agilent 1.000 permanent uncounted \
        HOSTID=ID_STRING=307929DE SIGN=959C790C5ECC
FEATURE TG3 agilent 1.000 permanent uncounted \
FEATURE TG6 agilent 1.000 permanent uncounted \
FEATURE 271 agilent 1.000 permanent uncounted \
FEATURE N8995A agilent 1.000 permanent uncounted \
FEATURE N8995A-SR6 agilent 1.000 permanent uncounted HOSTID=ID_STRING=307929DE \
        SIGN=4D9A17588B14
Offline PA0PBZ
« Reply #17 on: January 15, 2021, 07:50:09 am »
Only the options where the second line contain a SIGN= are enabled. Try to add the SIGN= to the line below FEATURE 271 like this:
   HOSTID=ID_STRING=307929DE SIGN=EE8797F25E0C
That should enable the waterfall (option 271), give it a try and let me know.
You can also enter the option without changing the file using 271 and the SIGN in the menu.
The following users thanked this post: rogersstuart
« Reply #18 on: January 16, 2021, 01:52:43 am »
That worked. Thank you! Out of curiosity, did you use a keygen or is there a table of these codes? I'd like to enable all of the listed options and see what I get.
« Reply #19 on: January 16, 2021, 04:18:45 am »
If you don't mind me asking here, I have a general question about spectrum analyzers. I've never touched a new and/or freshly calibrated unit, so I'm a bit unsure about how their output is supposed to look. The last one I owned had a function where I could attach a 50 ohm load and it would self calibrate and kind of "flatten" out a bit. This particular unit has a discontinuity around 2.7 GHz and no self calibration procedure. Is this simply an artifact caused by the architecture or is it a sign that it needs to be sent in for servicing?
Offline TheSteve
  • Living the Dream
« Reply #20 on: January 16, 2021, 04:27:47 am »
The N1996A switches bands internally at 2.7 GHz which is why you see some changes there.
That is also a hint that both the 3 and 6 GHz models have 6 GHz hardware in them :)
VE7FM
Offline PA0PBZ
« Reply #21 on: January 16, 2021, 08:45:49 am »
You can even see this 'wobble' at 2.7GHz in the product brochure so I consider it as normal.
I have a keygen which unfortunately I can't share for undisclosed reasons, but if you tell me what options you still need I will generate the keys for you.
Here's what I think you need:
AFM               D8031F9C907E
N8996A-1FP   D146D7D42F30
The following users thanked this post: rogersstuart, nixie_tube
Offline TheSteve
  • Living the Dream
« Reply #22 on: January 16, 2021, 09:15:36 am »
Some fun stuff for those of you with a 3 GHz N1996A:
***All done at your own risk***
Login via telnet and go to:
/flash/toroServer/Dragonfly/Receivers
Make a backup of the original 3 GHz profile:
cp  N1996A-503  N1996A-503-orig
Copy the 6 GHz profile to the 3 GHz profile:
cp  N1996A-506  N1996A-503
Reboot and your N1996A will now go to 6 GHz instead of 3 GHz!
The amplitude will not be at the proper calibrated level from 3 to 6 GHz as there is no cal data beyond 3 GHz. It is still very useful for relative measurements.
The tracking gen also works to 6 GHz and will normalize fine.
And while you're messing about how about changing the start frequency of the tracking generator from 10 MHz to 1 MHz:
Edit "Start  10e6^M" to "Start  1e6^M" in the file "N1996A-503" you just copied. This is very useful for checking out antennas in the amateur radio HF spectrum.
One other thing I found useful at times was enabling permanent ftp root login, to do this add the file /flash/linux/etc/shells with contents "/bin/bash".
VE7FM
The following users thanked this post: tv84, ktgun
Offline tv84
  • Country: pt
« Reply #23 on: January 16, 2021, 10:14:50 am »
Wouldn't it work by only activating the 506 option?
Offline TheSteve
  • Living the Dream
« Reply #24 on: January 16, 2021, 05:36:16 pm »
I don't have a N1996A to do any testing anymore. When I was experimenting a few years back I had the license verification bypassed and tried using option 506 and recall having a problem with it. I think the issue is that the Digital IF board is programmed as 3 or 6 GHz and it gave an error because it was initialized for 3 GHz instead of 6 GHz and would only boot with an error.
« Last Edit: January 16, 2021, 05:38:38 pm by TheSteve »
VE7FM
« Reply #25 on: January 16, 2021, 08:15:06 pm »
AFM               D8031F9C907E
I got those installed. The only other option that I'd like to try to enable is TG6. From what I can tell the tracking generator is, for the most part, only meant to be used with the Stimulus/Response suite. That works, but in spectrum analyzer mode the tracking generator does nothing and there's a suspiciously empty menu when I press the source button.
Offline TheSteve
  • Living the Dream
« Reply #26 on: January 16, 2021, 08:21:00 pm »
The TG works pretty good for antenna swr measurements. The source function can be made to work but was never officially sold and has limited use.
VE7FM
Offline PA0PBZ
« Reply #27 on: January 16, 2021, 08:31:52 pm »
TG6 - 3758B5467118
Offline gslick
« Reply #28 on: January 16, 2021, 09:26:07 pm »
Is the "Generic FlexLM Crypt Generator v0.5 by Haldir" shown in the keygen.png image attached to reply #9 available somewhere on the net? I haven't found any exact references to that tool anywhere else yet.
https://www.eevblog.com/forum/testgear/agilent-n1996a-software-unlock/msg3251066/#msg3251066
Does that tool generate a signature generator given the encryption seed1 and seed2 values, vendor name, and FlexLM version?
I have a different product for which I found a manual process to observe the correct signature value so I don't need a standalone signature generator for it, although the manual process is time consuming and it would be nice to have a standalone signature generator.
« Reply #29 on: January 16, 2021, 09:41:20 pm »
It did accept the code but nothing changed. Well, there are more on the list (like GPS), but I'm satisfied with the way it is now. I won't be transmitting (noticeably) and I do have an OCXO here.
My highest frequency signal generator is 2.4 GHz, and personally I haven't worked with anything past 1 GHz so far. I do intend to move on to learning about and attempting to design microstrip filters. The stimulus/response suite combined with my 3 GHz USB VNA and signal generators should let me somewhat comfortably work at around 2 GHz, which is enough for now. The ability to test something at up to 6 GHz is just a bonus.
My only gripe about this SA is the fact that it's quite obviously meant for older technologies. Basic 3G tests and AM/FM modulation. I was originally looking at the SSA3021X Plus but wanted that extra range past what the hack would offer. I'm actually upgrading from a Spectran HF6065, so dropping below 6 GHz felt like a downgrade. After making an offer I got this thing for $1600 with free shipping. At first glance the Siglent looked better, but upon closer inspection the Agilent takes the lead despite being a 2003-2006 vintage machine. Also, the TestEquity label says 20 AUG 12. So there's even a chance that it was recently calibrated!
Thanks for all the help with this! I appreciate it!
Offline tv84
  • Country: pt
« Reply #30 on: March 07, 2021, 02:52:57 pm »
No, N9320B uses a MD5 hash licensing method similar to N9340B.
Offline nixie_tube
« Reply #31 on: March 08, 2021, 11:34:56 am »
Hi PA0PBZ!
Would you be so kind as to also help me unlock the options on my old Agilent 1996a spectrum analyzer? I have this beautiful 6 GHz-enabled unit, but with all other options inactive and this makes me very sad :((
My hardware details are:
Model #: N1996A
Serial #: MY47053252
Host ID: 3079A480
The options available are as follows:
271 -- Spectrogram;
N8995A-SR6 -- Stimulus/Response Measurement Suite, 6 GHz
P06 Preamplifier, 6 GHz;
AFM -- AM/FM Tune & Listen;
N8996A-1FP -- AM/FM Modulation Analyzer
Thank you so very much!
Offline PA0PBZ
« Reply #32 on: March 08, 2021, 02:57:12 pm »
Hi, try this:
271               7F8560783A8A
N8995A-SR6        D0CD3F4411F0
P06               50C7BF6C5F6A
AFM               7B448F54463E
N8996-1FP         4617E83A4C7E
Offline QH54
« Reply #33 on: March 28, 2021, 08:02:43 am »
Hi PA0PBZ!
Yesterday i happened to find this Community Forum and was very suprised to find posts from a few days ago.
After finishing my registration i hope you can help me to activate missing options of my old N1996A.
Would you please be so kind as to do me this favour?
Model #: N1996A
Serial #: US45310402
Host ID: 30795D4F
Offline PA0PBZ
« Reply #34 on: March 28, 2021, 09:25:32 am »
Hi QH54
Try this:
AFM               EDF7F7D8C332
N8996A-1FP   D494828277D8
Offline QH54
« Reply #35 on: March 28, 2021, 09:39:04 am »
Dear PA0PBZ ,
Thank you very much for your prompt reply. Everything works fine and i am very grateful.
Hope i can help you some day.
Stay well!
Offline broadcast33
  • Country: br
« Reply #36 on: August 26, 2021, 06:51:24 pm »
Dear friends, I am new in forum. Can you help me?
I need to activate the options:
271
N8995A
P06
TG6
Model#N1996
Serial#MY45371214
Host Id 3079ED59
Thanks in advance
Regards
Offline ghikasir
  • Country: gr
« Reply #37 on: January 01, 2022, 04:47:51 pm »
Hi there and happy new year.
Can anybody help me to install these followinq options?
Model #: N1996A
Serial #: US45310316
Host ID: 3079CFFE
- 271--Spectrogram
- N895A-SR6 -- Stimulus/Responce Measurement Suite, 6 GHz
- P06  Preamplifier, ^ GHz
- N8996A-1FP -- AM/FM Modulation Analyzer
Offline PA0PBZ
« Reply #38 on: January 02, 2022, 01:19:04 pm »
Taken care of already ;)
Offline wd5jfr
« Reply #39 on: April 26, 2022, 05:13:24 pm »
I bought  a nice one couple of weeks ago and still trying to get used to it, big  upgrade from HP 141 and  HP 8935.
I'd like to add AFM and N8996A-1FP but the codes listed fail instali so I'm guessing they're unit specific.
My specifics are:
Model # N1996A
Serial # MY47052808
Host ID 30790D22
Can someone please help me unlock the 2 locked features?
Thanks
Hank
Offline PA0PBZ
« Reply #40 on: April 26, 2022, 09:03:06 pm »
Here you go:
AFM          89F8A90CCDD4
N8996A-1FP   1390EE4ADE22
Offline wd5jfr
« Reply #41 on: April 27, 2022, 06:04:13 pm »
Both installed with little effort, thanks. I tried  to listen to local AM and FM stations  but I only get a second or so of sound interupted by static and repeating, no luck in chaining timing.  I checked the instructions and found that it states "allows the detection of audio", so I wonder if I can set it so I can listen without interruption, if not seems like a waste of a speaker.  My HP 8935 allows listening to AM, FM, as well as SSB.
Hank
Offline TheSteve
  • Living the Dream
« Reply #42 on: April 27, 2022, 07:35:13 pm »
You will only get audio demodulated during the sweep. You can increase the sweep time to something really long which will decrease the cutouts. End of the day though most SA's are not intended to be used as an AM or FM general purpose receiver.
VE7FM
Offline duplexer
« Reply #43 on: May 19, 2022, 11:07:21 pm »
Hello,
I also have an N1996A that is new to me that I would like to activate the additional software items.
Model# N1996A
Serial# US45310391
Host ID 3079CDB8
Available options shown are:
271 -- Spectrogram
P06 -- Preamplifier, 6 GHz
Thank you so much for helping....
Offline PA0PBZ
« Reply #44 on: May 20, 2022, 09:45:20 am »
AFM         33ADCD5E129C
271         3A953242A578
P06         E0577BEE5294
N8996A-1FP  1677E356FBEC
Offline ktgun
  • Country: ru
« Reply #45 on: September 12, 2022, 02:09:12 pm »
Silly situation: i can't login into SA, because it ask's me login and password :o
Can somebody tell, where i can find them? maybe some default values? i was read programming manual for N1996A, but no any default login or password :-// Or my telnet connection is wrong?
« Last Edit: September 12, 2022, 02:11:18 pm by ktgun »
Offline PA0PBZ
« Reply #46 on: September 12, 2022, 02:36:26 pm »
You have mail.
The following users thanked this post: ktgun
Offline TylerH53
« Reply #47 on: October 28, 2022, 12:47:39 pm »
Would anyone happen to have access to a Service manual for the N1996A? I'm trying to perform a performance verification on one but have been unable to locate a good manual.
Offline PA0PBZ
« Reply #48 on: October 28, 2022, 12:55:52 pm »
Hi Tyler,
I just responded to your PM, see the link there. That's all there is for the instrument afaik.
Offline TrazorGr
  • Country: gr
« Reply #49 on: February 17, 2023, 09:32:26 am »
Good morning.
Model #: N1996A
Serial #: MY47052822
Host ID: 30796AA3
- N8995A-SR6 -- Stimulus/Responce Measurement Suite, 6 GHz
Thanks.
Offline PA0PBZ
« Reply #50 on: February 17, 2023, 11:19:44 am »
Replied to your PM
The following users thanked this post: kl
Offline TrazorGr
  • Country: gr
« Reply #51 on: February 17, 2023, 12:51:41 pm »
Dear PA0PBZ ,
Thank you very much for your prompt reply. Everything works fine.
Offline ktgun
  • Country: ru
« Reply #52 on: February 23, 2023, 08:13:02 am »
Hi!
Maybe somebody here was same issue like me: So i have N1996A, 3GHz version, with A.02.04 GUI version, in my lab, and i activated options 506, P06 (and edited profile for 6 GHz like in post above), 1FP, AFM.
Everything works great, but after that i decide to activate SR6. System says ok for option key, and key is appear in option list. But button 'Stimulus/Response' in 'Mode' menu is still disable!!!
Maybe it need to edit some profile for 6GHz SR6 like it was with P06?
« Last Edit: November 18, 2024, 10:08:16 am by ktgun »
Offline PA0PBZ
« Reply #53 on: February 23, 2023, 09:33:01 am »
Just as a quick test, what happens when you activate SR3?
Offline ktgun
  • Country: ru
« Reply #54 on: February 23, 2023, 12:23:20 pm »
Em, the problem is that after i input code for SR6, option menu became disable too. Or in other words, there was no any variants for selecting avialiable options.   :-//
Now I understand that I was in a hurry, and it must be input SR3 code first, but 'do first, think after' bited me in that moment  ;D
I think, that now i must delete SR6 code via SCPI and then try to input SR3 first. Will try next week and share results.
Offline PA0PBZ
« Reply #55 on: February 23, 2023, 01:11:43 pm »
You can telnet into the machine, user root, password c00lbull (that's zero's). In /idata/toroServer/license there is a file elgato.lic where all licensed options are kept. Each option has an entry like this:
        HOSTID=ID_STRING=12345678 SIGN=0123456789AB
You can add/change/delete the entries for the different options there.
Having said that, I have no idea how you could lose the options menu  :-//
Offline ktgun
  • Country: ru
« Reply #56 on: February 23, 2023, 01:48:55 pm »
Thanks, will try via telnet and will write results!
Offline TheSteve
  • Living the Dream
« Reply #57 on: February 23, 2023, 04:15:37 pm »
You can't use the 6 GHz options on a 3 GHz unit. You can edit the frequency range and get it to work to 6 GHz of course. But you don't want to install those options - they don't match the official hardware installed and it knows it :)
VE7FM
Offline ktgun
  • Country: ru
« Reply #58 on: February 24, 2023, 08:16:33 am »
Hmm, the thing is that P06 and 506 options works fine on my SA. In attached example are results of measurements after activation of these options and edit P06 profile. The measurement error was about 1 dB without any calibration and with bad cable. So, i doubt that problem with S6 is related with some firmware protect system. More probably the reason is some editable parameters in S6 profiles. :-//
« Last Edit: November 18, 2024, 10:10:05 am by ktgun »
Offline flukeandhp
« Reply #59 on: March 11, 2023, 09:54:55 am »
Model#: N1996A
Serial#: MY47052738
Host ID: 3079FE12
It has the 6 GHz option as:
- 506 (B7D58CBE2E82)
but nothing else at the moment.
It lists the following additional options could be added:
- 271 - Spectrogram
- N8995A-SR6 - Stimulus/Response Measurement Suite, 6 GHz
- P06 - Preamplifier, 6 GHz
- AFM - AM/FM Tune and Listen
- N8996A-1FP - AM/FM Modulation Analyzer
To make this analyzer more useful, it would nice to have these additional options, especially the stimulus/response option. It would be greatly appreciated if you would be able to help.
Offline PA0PBZ
« Reply #60 on: March 11, 2023, 10:29:38 am »
Host ID: 3079FE12
271         CB1B5184BAF2
N8995A-SR6  1D7C998CBB32
P06         977065EE4438
AFM         38D4BDBEF716
N8996A-1FP  166C6C80DCDA
Offline ktgun
  • Country: ru
« Reply #61 on: March 17, 2023, 12:03:26 pm »
Well, i connected with device via LAN and delete option N8995A-SR6 via SCPI command and reboot. Option name disappeared from option list in device interface, but meny "Install option" -> "From list" didn't unlock and in "Install option" -> "From File" says that "no valid options available to install".   :-//
After that i activated option N8995A (SR3). Option name appears in option list but menu "Stimulus/Response" still disabled.  :palm:
Any thoughts?
Offline PA0PBZ
« Reply #62 on: March 17, 2023, 03:31:02 pm »
Did you copy the 6GHz profile to the 3GHz profile? In that case it's not necessary to activate option 506 because you told the machine that the 3GHz is now 6GHz. Remove all the 6GHz options and try to use the 3GHz ones.
Offline ktgun
  • Country: ru
« Reply #63 on: March 17, 2023, 05:51:39 pm »
Yep, i copied 6 GHz profile to the 3 GHz profile))) Will try to go back on 3 GHz version and see what will be in this case.   :-+
Another idea was to update firmware, as i remember there is FW version newer, than in my device in present moment.
Offline ktgun
  • Country: ru
« Reply #64 on: March 27, 2023, 11:58:57 am »
It works! Thanks to all! :-+
So, if it necessary to make 6 GHz device from 3 GHz device with all options, follow these steps:
1) Copy the 6GHz profile to the 3GHz profile via 'TheSteve' tutorial;
2) Activate all options that you need in their '3GHz' - version;
3) Enjoy!
« Last Edit: June 29, 2023, 08:17:58 pm by ktgun »
Offline hmisy
« Reply #65 on: May 01, 2023, 05:42:46 pm »
Hi PA0PBZ!
Would you be so kind as to also help me unlock the options on my old Agilent 1996a spectrum analyzer? I have this beautiful 6 GHz-enabled unit, but with all other options inactive.
Firmware #: A.02.04
Model #: N1996A  100khz-6Ghz
Serial #: MY47052461
Host ID: 3079A821
271 -- Spectrogram;
Offline PA0PBZ
« Reply #66 on: May 01, 2023, 07:30:05 pm »
Try this and let me know:
271        09F0F070A528
N8995A-SR6 07D63E1E0254
P06        05884A4ECD72
N8996A-1FP C1EA2AD21CD0
Offline hmisy
« Reply #67 on: May 01, 2023, 08:00:15 pm »
Hi PA0PBZ,
Thank you very much for the unlock code.
Now all options are activated and i am going to test the operation of the options.
 Tnx. 73! YO6UI
Offline zzif
« Reply #68 on: June 20, 2023, 07:51:20 pm »
Hi PA0PBZ!
I have an old N1996A, which lacks all software options other than 6 GHz bandwidth. If you could provide the keys for the following options I would be really grateful:
271
N8995A-SR6
P06
N8996A-1FP
AFM
Kind regards,
73 OH6GMT
Offline TheSteve
  • Living the Dream
« Reply #69 on: June 20, 2023, 08:14:00 pm »
If he can do it he will need the serial # and hostid of your machine.
VE7FM
Offline PA0PBZ
« Reply #70 on: June 20, 2023, 08:35:03 pm »
Serial # is not needed, but the hostid is.
Offline zzif
« Reply #71 on: June 21, 2023, 07:04:58 am »
Oh, sorry - forgot the important stuff :) The host ID is 30790A51.
zzif
Offline PA0PBZ
« Reply #72 on: June 22, 2023, 09:25:14 am »
zzif, try this and let us know if it worked:
271        F5503F480B8E
N8995A-SR6 307E1842C3F8
P06        9CCA312EA4CE
N8996A-1FP F4510B0E20C4
AFM        2F62591452E6
Offline zzif
« Reply #73 on: June 27, 2023, 09:08:35 pm »
It works - thank you again!
The following users thanked this post: PA0PBZ
Offline madmac
« Reply #74 on: July 07, 2023, 02:05:59 pm »
I dug out a N1996A-503 (3GHz) that has not been used for a couple of years after a loan to some students for summer project. Plan was to impose on PA0PBZ to get some license keys as it has no options.
On power up I get a warning message that license for option 503 is not there.....press REBOOT to correct error.  It just repeats on power up.   Updating with latest firmware exactly the same.
Does anyone know if there is volatile storage in this unit?
Or any ideas to trouble shoot?
Thanks
Madmac
Offline TheSteve
  • Living the Dream
« Reply #75 on: July 07, 2023, 03:07:43 pm »
Everything is stored in flash memory. I believe to recover the unit you may need to get the hostid, get a new license generated and then transfer it to the unit via telnet and a usb flash drive(or ftp).
VE7FM
Offline PA0PBZ
« Reply #76 on: July 07, 2023, 09:32:59 pm »
Use telnet to log in: user root, password c00lbull (zero's for the 'oh's). In /idata/toroServer/license there is a file elgato.lic which holds the licenses, can you post the contents of that?
Offline madmac
« Reply #77 on: July 10, 2023, 03:06:07 pm »
Three files in that directory....
elgato.lic    empty
hostid        3079A5F0
lic               empty
Thanks
madmac
Offline PA0PBZ
« Reply #78 on: July 10, 2023, 03:40:50 pm »
hostid and elgato.lic should be there, don't know what lic is but I guess it won't hurt.
Put the following text in elgato.lic and you should be good to go with all options.
Let us know.
HOSTID=ID_STRING=3079A5F0 SIGN=31AEE3DC61E2
FEATURE AFM agilent 1.000 permanent uncounted \
HOSTID=ID_STRING=3079A5F0 SIGN=230909167924
HOSTID=ID_STRING=3079A5F0 SIGN=6AB4AEDE2F20
HOSTID=ID_STRING=3079A5F0 SIGN=128137962E70
FEATURE N8995A-SR3 agilent 1.000 permanent uncounted \
HOSTID=ID_STRING=3079A5F0 SIGN=F997FEA4ABB8
HOSTID=ID_STRING=3079A5F0 SIGN=AF2913345FCE
FEATURE N8996A-1FP agilent 1.000 permanent uncounted \
HOSTID=ID_STRING=3079A5F0 SIGN=6E0CBA900D20
FEATURE N8996A-2FP agilent 1.000 permanent uncounted \
HOSTID=ID_STRING=3079A5F0 SIGN=32CC0444E142
Offline madmac
« Reply #79 on: July 10, 2023, 05:28:32 pm »
Thank you for your help.
Loads into the SpecAn app and all options come up enabled.
I might have a hardware issue as it has frozen a couple of times, does not respond to any button presses and screen stops being updated.
Time to take the top off.
madmac
Offline arsh_vv
  • Country: ua
« Reply #80 on: October 17, 2023, 06:54:09 am »
Hello PA0PBZ!
Would you help me unlock the options on my Agilent N1996a?
The details are:
Model #: N1996A
Serial #: MY47052509
Host ID: 30790E72
FW: A.02.04
The available options are the follows:
271 -- Spectrogram;
Thank you in advance!
Offline PA0PBZ
« Reply #81 on: October 17, 2023, 09:38:12 am »
Try the following:
271        E9FBCFFA6912
N8995A-SR6 702D0442683A
AFM        7E19D51A0280
N8996A-1FP B9EF313C003C
The following users thanked this post: arsh_vv
Offline Uwe42
« Reply #82 on: November 11, 2023, 08:18:17 pm »
Hello PA0PBZ
is it possible to unlock options on an N9010A EXA Signal Analyzer ?
Kind regards
Offline PA0PBZ
« Reply #83 on: November 11, 2023, 09:48:39 pm »
It looks like the options are still available from the manufacturer so I'm not going to try, sorry.
Offline wtrevine
  • Country: br
« Reply #84 on: December 27, 2023, 05:33:47 pm »
Hi PAOPBZ...
I would be very grateful if you could unlock my N1996A as well.
Model # N1996A
Serial # MY47052783
Host ID 30790954
271 -- Spectrogram;
Offline PA0PBZ
« Reply #85 on: December 27, 2023, 07:53:04 pm »
Hi PAOPBZ...
Host ID 30790954
Try this and let us know:
271        B20848B46300
N8995A-SR6 C7E29832EB2A
P06        4C7331649CBA
AFM        281C757490B8
N8996A-1FP DEA77BC8A472
Offline imett
« Reply #86 on: March 10, 2024, 10:17:28 pm »
Hi, i need help for my N1996A:
simetime it doens't boot up and the GUI is freezed on the mask "Copyright..." after that with the unix command "restart" (telnet..) the GUI restart and is possible use the instrument normally
I've to do two or three time the restart command to have the normal use!
For these reason i investigate and i found a serial console in J9 connector (on the bottom of the instrument) and post what'ts happen when GUI doesn't starts. Is an infinite loop of:
hub.c: new USB device sm501-1.2, assigned address 8
ti_usb_serial.c: detected TI USB 3410 1 port adapter, vendor 0x0451, product 0x3410, serial number 'TUSB3410        '
ti_usb_serial.c: TI USB 3410 1 port adapter now attached to ttyTIUSB0 (or usb/ti/0 for devfs)
port 2, portstatus 100, change 1
usb.c: USB disconnect on device sm501-1.2 address 8
ti_usb_serial.c: TI USB 3410 1 port adapter now disconnected from ttyTIUSB0
port 2, portstatus 101, change 1
hub.c: new USB device sm501-1.2, assigned address 9
usb.c: USB disconnect on device sm501-1.2 address 9
some one could help me? it is a problem of the USB3410 controller?
thanks in advance matteo
Offline shashitej
  • Country: in
« Reply #87 on: March 27, 2024, 06:29:31 am »
Hello PA0PBZ,
 I need ur help to activate the options in Agilent N1996A Spectrum Analyzer
I would be very grateful if U could help me to get the keys for the following unit
Unit HOST ID : 307934B2
available options:
(1) 271 ---Spectrogram
(2) N8995A -SR6---Stimulus/Response Measurement Suite, 6GHz
(3) P06 ---Preamplifier, 6GHZ
(4) AFM --- AM/FM Tune & Listen
(5) N8996A--1FP --- AM/FM Modulation Analyzer
Thank you
SHASHITEJ
« Last Edit: March 27, 2024, 06:33:55 am by shashitej »
Offline PA0PBZ
« Reply #88 on: March 27, 2024, 10:23:53 am »
Try these:
271         26C916D0CB14
N8995A-SR6  C7ACBA280B68
P06         B80F7E26D7E4
AFM         7E644BE65510
N8996A-1FP  C26853F674CA
The following users thanked this post: shashitej
Offline shashitej
  • Country: in
« Reply #89 on: March 27, 2024, 11:25:02 am »
Hi PA0PBZ,
I was able to activate the options with the keys provided by u.
thanks a lot
Shashitej
Offline Harrry
  • Country: ru
« Reply #90 on: April 10, 2024, 11:47:28 am »
Hi PA0PBZ!
Model #: N1996A
Serial #: MY47053163
Host ID: 307994B1
271 -- Spectrogram;
Igor, RU3GX
Offline bobmat
« Reply #91 on: July 25, 2024, 10:26:55 pm »
Hello PA0PBZ,
I have a N9342C Spec An and would like to activate options:
 Host ID = 64C56FBB
options
AMA
DMA
SIM
SCN
Thank you & 73,
bobmat   KM6GYV
PS I designed the front ends for HP/Agilent SAs for 110 GHz.
Offline PA0PBZ
« Reply #92 on: July 26, 2024, 08:41:29 am »
I'm taking this to PM
The following users thanked this post: Doctor_MYheart
Offline vmaksimo
« Reply #93 on: August 11, 2024, 01:50:45 am »
Hello PA0PBZ,
Can I have a Service Manual for it as well, please. N1996A that is.
Also I am Linux illiterate, is there a detail instructions for unlocking features?
Options I may add are:
271
P03
AFM
N8996A-1FP
Model #: N1996A
Serial #: MY47052138
Host ID: 3079FFF2
FW: A.02.07
Appreciated if U can help.
(BTW learning Linux as we speak)  :-DD
« Last Edit: August 11, 2024, 02:19:43 am by vmaksimo »
Offline PA0PBZ
« Reply #94 on: August 13, 2024, 01:01:30 pm »
Host ID: 3079FFF2
Here are your keys:
271        637E48CCFBE4
P03        346D5DDCED36
AFM        96C23968208A
N8996A-1FP 4D7248C89984
The service guide (not component level) can be downloaded here:
https://community.keysight.com/s/question/0D52L00005Idoo5SAB/n1996a-service-documentation
The following users thanked this post: vmaksimo, Doctor_MYheart
Offline vmaksimo
« Reply #95 on: August 14, 2024, 12:57:55 am »
Did install all of them. Worked like a charm. Not even used Linux, just Options Manager in the System menu.
Many thanks to PA0PBZ for the keys.
Best regards,
Max
Offline dixonkean
« Reply #96 on: November 17, 2024, 01:43:31 pm »
Hi PA0PBZ!
I've got an old 3Ghz N1996A that I'm stuck with on a jobsite, and it only has the 503 option installed. If you'd be so kind as to provide the keys for the for the remaining options, I'd be extremely grateful!
Model #: N1996A
Serial #: MY47052265
Host ID: 30796AC0
FW: A.02.07
Options:
271
N8995A-SR3
P03
AFM
N8996A-1FP
Offline PA0PBZ
« Reply #97 on: November 17, 2024, 02:45:04 pm »
Host ID: 30796AC0
Here you go:
271        CDFD368815E4
N8995A-SR3 3DCB93E662EE
P03        B2660698521C
AFM        1BB927B2EA36
N8996A-1FP 4CECE3CEECFA
The following users thanked this post: dixonkean, Doctor_MYheart
Offline dixonkean
« Reply #98 on: November 18, 2024, 08:37:52 am »
All options installed successfully, you're a legend! Thank you, you've really helped us out.
Offline Doctor_MYheart
« Reply #99 on: December 06, 2024, 12:10:55 pm »
Hello PA0PBZ,
I have a two N1996C Spec An and would like to activate options:
Model N1996A
Host ID = 30795AA1
Options
271
N8995A-SR3
P03
AFM
N8996A-1FP
Model N1996A
Host ID = 30795BE1
Options
271
N8995A-SR3
P03
AFM
N8996A-1FP
Thank you SO MUCH.
« Reply #100 on: December 07, 2024, 10:29:40 am »
I need an analyzer for research work in college
For my students
Best wishes,
Erik
Offline PA0PBZ
« Reply #101 on: December 07, 2024, 10:51:48 am »
Here you go Erik, let me know.
HostID 30795AA1:
271        F4756604D03A
N8995A-SR3 28836A7AF092
P03        BC47EF943754
AFM        B1E2BEF05EF0
N8996A-1FP 406DCF826DBE
HostID 30795BE1:
271        8E9E82EC6B2A
N8995A-SR3 294C80B2FD80
P03        F49ED1F0C910
AFM        4135AC2E0898
N8996A-1FP 9162FC908292
« Reply #102 on: December 07, 2024, 12:00:46 pm »
thank you very much
Best wishes,
Erik
Offline ReijoK
« Reply #103 on: December 28, 2024, 03:29:33 pm »
Hello,
If I may ask for the codes, too? Not that I would know how to use all those features, but for me a (the?) meaning of life is learning…
Model #   N1996A
Serial #   MY47052282
Host ID   3079C885
271 -- Spectrogram
N8995A-SR6 -- Stimulus/Response Measurement Suite, 6 GHZ
Thanks,
Reijo
Offline PA0PBZ
« Reply #104 on: December 31, 2024, 11:30:29 am »
Host ID   3079C885
271        B14E77C27146
N8995A-SR6 BB6251206FD6
P06        05033A8EC1C0
AFM        722F41F41DD4
N8996A-1FP CA49665A6370
The following users thanked this post: ReijoK
Offline ReijoK
« Reply #105 on: December 31, 2024, 02:12:16 pm »
Hi PA0PBZ,
Thank you, very much appreciated! Features successfully activated. This will keep my (both) brain cells active :-)
- Reijo
