So far I've tried 02.65, 02.35, 02.20, 02.10 and 01.10
Versions older than 02.35 just hang indefinitely at
ProcessStartupFolder: \usb\Startup\
running \usb\Startup\infiniivision.lnk...
Here's the spew from U-Boot from the corrupt flash. Does it give an indication of which firmware version would be needed to restore it @TheSteve?
U-Boot 2010.03 (Jan 26 2011 - 12:37:34)Agilent P500
CPU: SPEAr600
DRAM: 128 MiB
Flash: 512 KiB
NAND: 128 MiB
In: serial
Out: serial
Err: serial
SerNum:serial number not programmed
Chip: BD Board Rev: 4
Net: smsc
Press space to stop autoboot: 0
## Booting kernel from Legacy Image at f8050000 ...
Image Name: PBOOT
Created: 2011-01-27 11:38:14 UTC
Image Type: ARM Linux Kernel Image (gzip compressed)
Data Size: 36703 Bytes = 35.8 KiB
Load Address: 00000000
Entry Point: 00000000
Uncompressing Kernel Image ... OK
Starting kernel ...
Debug serial initialized ........OK
Microsoft Windows CE Bootloader Common Library Version 1.4 Built Jan 27 2011 02:04:15
Microsoft Windows CE 6.0 Ethernet Bootloader for the Agilent P500 board
Adaptation performed by Agilent Technologies (c) 2008
