I like to do some reverse engineering of my equipment internals. At least have a part listing with parts datasheets.
After some Internet searching I have a partial hardware parts listing. Thanks for this forum, some Russian and Chinese sites for internal pictures and discussion.
PARTS for DM40C versionMotherboard PCB reference: DM40 V1.1
BATT LN425272 Battery LiPo 3.7V 2000mAh 7.4Wh with protection circuit
IC HY3131 DMM front end, one High-precision 24-bit ADC, two high-speed 19-bit ADCs,
XTAL 4.9152 MHz Crystal oscillator for HY3131
IC MAX6190 High-precision voltage reference chip 5PPM/C
UN metallic box Shielded case - Oscilloscope analog vertical amplifier??IC GD32F427VGT6 MCU 32-bit Cortex M4 core, 200 MHz, 1 MB ROM, 256 KB RAM
XTAL 26.000 MHz Crystal oscillator for MCU
IC W25Q128JV 128Mb memory
IC BP2A838-20A2 8-pin by JL (Zhuhai Jieli Technology Co., LTD), BT Bluetooth chip
XTAL 24.000 MHz Crystal oscillator for BT IC
IC EL3H7 Optocoupler
IC CA-IS3741HW By ChipAnalog, High-Speed Four-Channel Digital Isolators
IC LT61-117 6-pin VPS8505 transformer
IC LT61-113 6-pin VPS8505 transformer
IC VPS8504B Micropower Isolation Power Supply
IC VPS8504B Micropower Isolation Power SupplyIC TP4056 Battery charging management
IC HC4051 Single-channel analog multiplexer/multiplexer,
IC 3PA1030 By 3peak, 10-Bit, 50-MSPS, CMOS Analog-to-Digital Converter
IC TC1746B6 High-precision voltage divider resistor network divider (
DM40A does not use it - Just a few resistors in its place)
IC RUH30J51M By Ruijun Semiconductor (Ruichips), dual-channel symmetrical N-channel MOSFET field effect tube, current 50A, withstand voltage 30V
K HFD4/3-LS By Hongfa, Subminiature signal relay of 4th generation, DPDT, 100MHz contacts, 3V / 90R coil
IC 174 F163H 4-pin smd (DM40A uses 174 F215H) - Optocoupler
IC 174 F163H 4-pin smd (DM40A uses 174 F215H) - OptocouplerD's SD B0520LW Schottky Barrir Diode 20V 500mA
Concerning the unidentified chips, I put a question on the another thread at:
https://www.eevblog.com/forum/chat/what_s-this-please-(component-advice)/msg5964329/#msg5964329Hopefully someone will know what these chips are. datasheets would be nice too.
EDIT: Many Thanks to
Gamalot member who was able to identify the unknown components above.
https://www.eevblog.com/forum/profile/?u=112468
