Author Topic: Amazon attenuators, any good?  (Read 1827 times)
Offline W4PJBTopic starter
« on: January 12, 2024, 04:31:11 pm »
Has anyone tested any of the inexpensive attenuators from Amazon, or have experience how they would compare to a much more expensive units from companies like Pasternack or MiniCircuits?
Here is an example:
https://www.amazon.com/BECEN-Male-Female-Connector-Attenuator/dp/B07DXPT3FT/ref=sr_1_8?crid=SM5W8UHDV7B3&keywords=30%2Bdb%2Battenuator%2Bn%2Bconnector&qid=1705076905&sprefix=30%2Bdb%2Battenuator%2Bn%2Bconnector%2Caps%2C92&sr=8-8&th=1
Thanks!
Offline fourfathom
Re: Amazon attenuators, any good?
« Reply #1 on: January 12, 2024, 05:12:30 pm »
I've purchased a few attenuators from Amazon / BECEN.  They are usually OK, with decent performance up to 1GHz (at least the smaller-attenuation 10W SMA connector ones I've got)  Sorry, I don't have any test data handy.  But one 100W "50dB" N-connector one I got from BCEN actually just has about 40dB attenuation.  It was reasonably flat over my frequency range of interest, and it managed to handle the 50W or so I ran through it.  I put a "40dB" label on it and still use it.
These attenuators are commonly available from aliexpress.com, and they all look the same -- I don't know who actually makes them, or where "BECEN" gets theirs.  QA rejects, perhaps?
So if you are able to test the attenuator before using it, it's probably worth a shot.  If you want something with better-guaranteed precision Amazon/BECEN is probably not your best source.
And watch out for power ratings on Chinese attenuators and dummy loads.  I can buy the exact SMA dummy load, sold as "1W" and "2W" devices.  They get pretty hot at 1W.
We'll search out every place a sick, twisted, solitary misfit might run to! -- I'll start with Radio Shack.
Offline Bud
« Reply #2 on: January 12, 2024, 06:18:13 pm »
For casual use or for Ham radio you can use those, they likely have a vanila axial resistor inside. For use with expensive test and measurement equipment and for measurements i would get one from Minicircuits. The Chinese ones may ruin your equipment connectors because of poor mechanical tolerances. That is beside poor attenuation accuracy, frequency range and return loss.
Online DaJMasta
    • medpants.com
« Reply #3 on: January 12, 2024, 11:11:08 pm »
For not so much more, you can get used or NOS name brand attenuators on ebay or similar - while they will probably work at least to some degree and that may be enough, as others have said, the real deal as a surplus part will likely be a lot more reliable and better manufactured provided the connectors are in good shape.
Offline David Hess
  • DavidH
« Reply #4 on: January 12, 2024, 11:12:38 pm »
I usually consider single stages of attenuation above 20dB to be questionable anyway.
Online DaneLaw
« Reply #5 on: January 13, 2024, 07:08:26 pm »
Got two attenuators from "Becen" though with SMA-connectors, and they seem solid - as far as I can tell (with the price in mind).
One 5W -40Db that is rated for 3 or 4GHz weight around 45.5g and another 5W but way smaller,  also -40db and rated for 13GHz.
I don't have linearity to 13Ghz to check it, but with TinySA Ultra 30Mhz test-signal they both at least seem db accurate and were quite cheap at under 12 USD incl. 25% VAT & delivery.
« Last Edit: January 13, 2024, 07:12:30 pm by DaneLaw »
Online nctnico
« Reply #6 on: January 13, 2024, 07:18:45 pm »
Now test the power rating using a DC power supply... See if they hold up. The fact the sticker is restricting is much of the airflow, doesn't look good to me.
« Last Edit: January 13, 2024, 07:20:19 pm by nctnico »
Online DaneLaw
« Reply #7 on: January 13, 2024, 07:38:06 pm »
The somewhat beefy silver 5W unit works fine with 5 to 7 watts, from handheld transmistters though gets a little hot after extensive tests, but that goes without saying..
- the small -40db 13Ghz jobby, Im not even gonna try to challenge its powerrating, its small... its not its questionable 5W power rating that appeals, more if it's linear a good part up in these higher frequencies, as most relative cheap attenuators drops of quite fast.
Offline mojoe
« Reply #8 on: January 14, 2024, 06:16:01 am »
I just received a Becen 50 W, 50 dB attenuator. It's rated to 3 GHz. First thing, I checked it on my Lite VNA. Yes, it is 50 dB +/-1 dB or less out to 3 GHz. However, the return loss gets progressively worse past 500-600 MHz, and goes to hell above 1 GHz.
For my needs, this is OK. I doubt I'll ever need a high wattage attenuator at those higher frequencies.
As for the 2 W attenuators, see my other post in this section. They fair much better.
Offline Randy222
« Reply #9 on: January 15, 2024, 10:19:56 pm »
There are two main specs you should ask from any maker of this stuff.
VSWR chart
DC ohms test to nearest 1mOhm
Actual power handling is gonna be a crap-shoot unless vendor actually specs out a DC power level point where the thing burns out or has some level of degradation.
If the unit says 0-3GHz and the VSWR goes higher than 1.5, garbage. Good stuff should stay around 1.2 (or lower) in the specified range.
If VSWR is 1.2 up to ~500MHz and you'll be under 500MHz, then perhaps you lable it "0-500MHz", but don't expect the little 10w item to handle continuous 10w.
Offline Solder_Junkie
« Reply #10 on: January 15, 2024, 10:30:19 pm »
Generally cheap SMA attenuators tend to have a better return loss measurement than cheap N types. Being physically small, SMA types tend to have a better specification in terms of matching/return loss. I have bought eBay (Chinese) SMA attenuators and had no issues with them up to the limit of my test gear (3 GHz).
SJ
