Just thought I would post some quick pictures of this Bryman based Amprobe meter. Pretty nice meter. The accuracy is very good. The control feel isn’t bad at all. The backlight is… well better than nothing. The built in safety isn’t bad either but the case could feel a bit more robust.
Anyway, this is clearly yet another of the Bryman designs that has been sold as an Extech, Greenlee, and who knows how many other brands. At least it’s a generally good model. Base accuracy is 0.08% DCV. Certainly quite respectable. The continuity test is a bit slow but not too bad. It also has an optical out on the back. Speaking of the back, plastic screws to hold the battery door in place. Thumbs down.
It’s clear this meter was part of a family of Fluke 87 like meters that Bryman did and OEMed for other brands. Most of the other versions were more rectangular and had a protective boot. I’m not a big fan of the overmold instead of boot. The overmold offers almost no additional protection. It does perhaps improve gripping the meter but little else. On the other hand it gets dirty and is hard to clean. I am simply much happier with a real case or, well nothing. The Fluke 87 would be very robust even without the case.
