Got a second hand phillips PM3244 scope this weekend (for free!
). However, internally, the .22uF capacitor for mains filtering was broken (so I removed it). After that, the scope worked fine.
When I asked someone if I should or shouldn't replace the filter cap, he told me I should consider replacing other capacitors (the larger electrolytics as a minimum) as well, since they age and could distructivly fail damaging the rest of the device. He event told me I could consider rebuilding parts of the supply.
So, should I just replace the capacitor that was actually damaged, replace the electrolytics as well or just try to see if I can manage to build an entirely new powersupply board (I haven't yet looked into the actually possibility of doing so, I know the scope uses some custom phillips IC's you can't get, but I don't know if the powersupply actually has any of those, I believe it's pretty much jellybean-only)?
