Hi everyone,
I bought a KP184 from eBay and the mainboard is the new Version 06 with the GD32F MCU. It was sold as new but arrived without any accessories - no cables, not even the original package, just wrapped in bubble foil... It was manufactured - according to the sticker - on 2022-09-14.
First tests were OK, I was just wondering why the fan would not spin up after sinking 300W for a minute and the case already becoming hot.
Then I tried to connect it to the PC without any success - and I tried a lot of adapters, cables, USB-to-RS232 converters, etc.
Finally I opened up the device, as I wanted to change the connectors and install a power switch on the front anyways. After some poking around I found that neither the fan nor the MAX232 for the serial port got any power. Looking for the fault I found the LM317T to be defective, between the ADJ and OUT pins where only 60 Ohms. After replacing the LM317T and also relocating the LM7805 hanging under the mainboard to the heatsink just beside the LM317T, I was able to connect the unit to the PC and - bingo - the fan now ran too.
Being euphorized I went ahead and installed the new 2128 firmware, but while the upload was still running my heart stopped beating for a moment, wasn't there something with the MCU being a GD32 instead of the "old" STM32?
For a moment I was tempted to stop the upload but didn't as it already had erased the flash and was at about 30% upload, so I let it finish.
After the upload was finished the fan went to hyperspeed, the display flickered but it showed the 2128 version - for about 15s - then the normal screen appered (still flickering) and I could even use the menu, I was able to enter a new current value in CC mode too, but when I pressed SET, the unit froze.
Now I had a half-bricked device, with fortunately the bootloader still intact. Of course I tried to upload again, in the hope something went wrong the first time, but nope...
Well, that's the current state. So my question to PaWill68: did you already have a source for a firmware for the Ver.06 mainboard? I did not note the version the unit had before I bricked it, but it was something like 2021.
Andreas
