Author Topic: AN8008 US $19, 9999count, 1uV, 0.01uA, 0.01Ohm, 1pF resolution meter  (Read 308425 times)
TizianoHV and 2 Guests are viewing this topic.
Offline stj
Re: AN8008 US $19, 9999count, 1uV, 0.01uA, 0.01Ohm, 1pF resolution meter
« Reply #750 on: June 23, 2018, 11:46:20 am »
the aneng meters can be modded for 20mm fuses.
and you can get ceramic 20mm FF rated fuses - so that's the way to go.
The following users thanked this post: exe
Offline Zimphire
« Reply #751 on: June 28, 2018, 02:30:47 am »
I've read a good 20 or so pages of this. While it's not the best DMM on the planet, for the price it's perfect for what I need it for. Better than anything in that price range a few years back.
And after doing this mod to it, and getting better probes, it works even better.
https://www.jackenhack.com/aneng-an8008-modify-for-better-accuracy-faster-readings/
The following users thanked this post: kripton2035, Marco1971
Offline bitseeker
« Reply #752 on: June 28, 2018, 09:54:10 pm »
Welcome to the forum, Zimphire.
Interesting how much noise was in the meter and how much better performance was after Jack made those cap mods.
Looks like he recently fixed up the AN8009 as well. https://www.jackenhack.com/aneng-an8009-improve-accuracy-response/
« Last Edit: June 28, 2018, 10:29:38 pm by bitseeker »
The following users thanked this post: Zimphire
Offline tooki
« Reply #753 on: June 29, 2018, 07:04:21 pm »
Zimph, from MacNN forums, is that you?! :P Blast from the past!!!
Offline Zimphire
« Reply #754 on: July 15, 2018, 07:54:04 am »
Ack! PLZ don't ban me!
Offline tooki
« Reply #755 on: July 15, 2018, 02:33:43 pm »
Hahaha I’m not an admin here. And you deserved it! ;) Anyway, nice to see a familiar face (well, username!).
Offline lordvader88
« Reply #756 on: July 15, 2018, 11:31:49 pm »
Wasn't there something very common missing on these like mA ability, just Amps ?
Online floobydust
« Reply #757 on: July 16, 2018, 01:17:24 am »
Full featured DMM's using this chipset have a fouth input jack: COM, V, mA/uA, A
AN8008 has three and is missing the low mA range, it has uA, high mA + A. So it reads:
0-99.99uA at the V jack with 100R shunt.
0-999.9uA at the V jack with 100R shunt.
0-999.9mA at the A jack with 0.01R shunt
0-9.999A  at the A jack with 0.01R shunt
Missing is the 9.999mA/99.99mA range with 0.99R shunt.
So you can only get 0.1mA resolution on mA measurements.
Also, it cannot measure past 9.999MEG ohms  :--
The following users thanked this post: Stinger
Online Fungus
« Reply #758 on: July 16, 2018, 10:36:49 am »
Yes. They don't have a range in the 10mA area. They jump straight from uA to A.
Offline exe
  • self-educated hobbyist
« Reply #759 on: July 16, 2018, 10:54:40 am »
I like having only three jacks -- that's convenient for me. But I'd love to have an audible warning if plug not in the right socket.
Offline stj
« Reply #760 on: July 16, 2018, 12:25:33 pm »
you do, it makes a bang or large crack sound!  >:D
The following users thanked this post: Gandalf_Sr, Fungus, cpt.armadillo
Offline exe
« Reply #761 on: July 16, 2018, 01:41:39 pm »
Considering the DMM itself costs just a bit more than a good HRC fuse, that's fine with me :). A single-use DMM...
PS could you remind me why it should bang? I thought it has fuses on all ranges...
Offline JanJansen
« Reply #762 on: July 16, 2018, 02:30:13 pm »
How long does it take before a 99.999 counts meter is to be released for this price ?
aliexpress parachute
Offline exe
« Reply #763 on: July 16, 2018, 02:59:49 pm »
You mean a 5-digit DMM for $15? Well, if you only care about number of digits it's not a problem at all :D. A 16-bit sound DAC with some oversampling will do it... But precision will suffer.
Offline wolferl1210
  • Country: at
« Reply #764 on: July 31, 2018, 02:37:41 pm »
I want to make the mods to my AN8008 according to the info at:
https://hackaday.com/2017/11/24/a-few-caps-for-a-faster-multimeter/
It's the first time that I re-solder SMD, but a do have a lot of experince in soldering.
I use a solder ATTEN ST-80 station with temp setting, so what temp should I use for the 0805 caps?
Is the tip (attached pic) OK for that job?
Thanks for your advise in advance!
Online ebastler
« Reply #765 on: July 31, 2018, 04:12:08 pm »
That tip looks like something my dentist would use...  ;)
If you have a pencil or fine chisel tip for your normal through-hole soldering, there is no need to buy a special one for soldering 0805 SMDs. The same considerations apply as for through-hole soldering: The tip needs to be fine enough to touch the desired solder joint only, but shold not be thinner than necessary (for good heat transfer). Just hold your pencil or chisel tip into the angle beween PCB and the side wall of the 0805, and you will be fine.
Also, your temperature setting should be the same as for small through-hole components.
The following users thanked this post: wolferl1210
Offline stj
« Reply #766 on: July 31, 2018, 06:09:48 pm »
that's a common miss-understanding.
meters only have fuses on the current inputs.
Offline In Vacuo Veritas
  • I like vacuum tubes. Electrons exist, holes don't.
« Reply #767 on: July 31, 2018, 07:26:07 pm »
Oh I think I met her once.
("miss-understanding"? Really? You guys invented the language, not sure what you're doing with it these days, though.)
Offline Zimphire
« Reply #768 on: July 31, 2018, 11:33:33 pm »
Buying better test leads also makes this DMM alot better..
Offline stj
« Reply #769 on: August 01, 2018, 01:52:32 pm »
shouldnt you be speaking french?  >:D
Offline GreyWoolfe
  • NW0LF
« Reply #770 on: August 01, 2018, 04:46:34 pm »
+1 for this.  I replaced the leads on my Aneng 8009 in my toolbag with Brymen gold plated leads.  Much more accurate for the low resistance measurements I will be using it for.  I threw the OEM leads out.
Offline jackenhack
    • Jackenhack Blog
« Reply #771 on: September 20, 2018, 07:58:28 pm »
I've got a lot of responses from people doing the upgrade on the AN8009 and not getting any significantly better results. I did on my unit, but maybe they've improved later batches.
Offline Mr. Scram
  • Display aficionado
« Reply #772 on: September 20, 2018, 11:40:24 pm »
One thing that lets the Anengs down compared to "real" multimeters is the wobbly lead sockets.
Offline stj
« Reply #773 on: September 21, 2018, 12:10:29 am »
strange, i have 2 and they arent wobbly or loose in any way.
Offline Mr. Scram
« Reply #774 on: September 21, 2018, 12:41:52 am »
The sockets are only attached on the bottom and soldered to the PCB through a long springy connector. It's inevitable that leads that don't neatly fill the gap produce a lot of force on that bottom bit due to them essentially being levers. The supplied leads and maybe the often used Brymen leads seem to fill the gap between the socket and the case and stabilise the whole affair that way, though you can still wiggle the leads from side to side a bit. With the original leads the range of motion is much closer to higher end meters, though.
It should be said that higher end leads also don't seem to be firmly held inside the socket.
