Author Topic: Analog CRO - One Shot Triggering Use?  (Read 877 times)
Offline TomKattTopic starter
« on: February 28, 2023, 02:00:38 pm »
I've got an old HP 180A analog crt scope.  Still running great with a sharp trace despite being nearly as old as I am.  I believe this was HP's first "fully transistorized" scope, which is mostly true but does use neon bulb type voltage regulators on a few rails (side note - apparently these neon regulators are actually very stable, which is likely why they were used despite all other active elements going to silicon (or germanium lol).
Anyhoo - the 1821A timebase in my scope includes a resettable Single shot mode.  As the crt display is not a storage type, I've often wondered if the Single shot trigger was useful for non storage scopes - perhaps using a mounted camera to get a clean waveform image?  Or was this feature only applicable to storage scopes?  Because otherwise, the Signle shot is about useless as the waveform is gone as soon as it's displayed on the crt.
Several Species of Small Furry Animals Gathered Together in a Cave and Grooving with a PICt
Offline Zero999
  • 0999
Re: Analog CRO - One Shot Triggering Use?
« Reply #1 on: February 28, 2023, 02:04:50 pm »
Yes, a camera is necessary for one shot mode. You could use a phone camera to record a video and merge the frames together, or there's probably an app which will do it for you.
The following users thanked this post: MK14
Offline tggzzz
« Reply #2 on: February 28, 2023, 02:35:05 pm »
With skill and imagination, single shot on a non-storage scope can still be useful. It is easier with a (Polaroid film) camera, but possible without. For example, I simply looked at the trace when calibrating a 1953 mechanical camera's shutter speed.
You need to have set it up so that the interesting part of the trace will be on the screen. That requires thinking and understanding what will happen, with a little experimentation.
You need to understand what small piece of information you want to measure, because you won't be able to remember every feature of the trace. For my example, it was where the second transition occurred on the screen (the first was used as the trigger).
You need to have a bright enough trace to be visible, which is a combination of the beam current (i.e. brightness), sweep speed, external illumination, phosphor persistence and retina persistence.
But overall, the only USP of early digitising scopes (1980-2000) was their ability to capture single shot events. And even then common digitising scopes had noticeable disadvantages until after, say, 2010.
Online Ian.M
« Reply #3 on: February 28, 2023, 03:16:44 pm »
Back in the day, I used to use one shot mode in a darkened room (or under a black felt hood), with a sheet of acetate cut to fit the display and an OHP pen to trace the trace before it faded.
Offline TimFox
« Reply #4 on: February 28, 2023, 03:22:05 pm »
Analog CROs were characterized by their "writing speed" with a given Polaroid film and camera settings to work with single-shot trigger mode.
One opened the shutter, armed the trigger, then closed the shutter after the sweep (indicated by panel lights) completed.
If I remember correctly, the discovery of the antiproton was done with a CRO and a cine camera to capture multiple single shots, which were then investigated after developing the film to determine the time of flight between two detectors.
https://indico.cern.ch/event/104466/attachments/15569/22575/The_Bevatron.pdf
Side note:  the "B" in Bevatron stands for (American) billion (109).  The "BeV" was sometimes called the "Berkeley" or "Brookhaven" eV, while the "GeV" was the "Geneva" eV.
« Reply #5 on: February 28, 2023, 03:39:44 pm »
I know that the crt tubes were available in a number of different phosphors, some explicitly meant for film camera applications.
Offline Kleinstein
« Reply #6 on: February 28, 2023, 03:54:15 pm »
One can use the single shot mode with an anlog scope, but it is limited. I have a single shot mode also with my analog scope (Voltcraft 2040) but I am not sure I have ever really used it.
Offline TimFox
« Reply #7 on: February 28, 2023, 05:16:57 pm »
Correct.  The normal P31 green phosphor (replacing P1) was good for direct human observation, but the blue P5 and P35 phosphors have short decay time and are efficient for film.
P7 is a dual-layer phosphor, where the blue layer excites the yellow layer that has a very long persistence.  It was used in old-style EKG displays and was useful in single-shot mode CROs with pulsed waveforms.
P4 is the normal white phosphor for monochrome TV CRTs.
