Author Topic: Analog vs digital scope  (Read 10990 times)
Offline nctnico
Re: Analog vs digital scope
« Reply #50 on: April 09, 2020, 10:08:48 pm »
Trade-Offs
The probes still have a resistive path to ground - so if a
circuit is sensitive to leakage currents then differential
Well, every probe using whatever isolation method will have some resistive and capacitive leakage to ground. The only way to really avoid having any leakage is to use a probe with an optical interface for both the signal and power. But even then you'll influence the circuit due to the capacitance and inductance of the electrical leads and circuit. In reality most high voltage circuits have a low enough impedance where a bit of leakage to ground doesn't matter.
Offline Gandalf_Sr
« Reply #51 on: April 09, 2020, 10:15:22 pm »
To all intents and purposes, the high voltage differential probes are very high input impedance (many Meg Ohms) even though not actually isolated.  The OP could use them without worry and that's why I said he was right in his/her summary.
If at first you don't succeed, get a bigger hammer
Offline ToddWTopic starter
« Reply #52 on: April 09, 2020, 10:33:27 pm »
So no, in general it's safe to assume they're not isolated, and do have a high input impedance (5 Meg + 5 Meg) to provide safety.
Such high resistance values are isolation. It is possible to come up with an 'isolated' circuit (using a transformer for example) which has effectively a lesser degree of isolation due to creepage/clearance paths. The use of a string of high value / high voltage resistors is a well proven technique and most of the high voltage differential probes out there are made this way.
Seems to me that with those high resistance values the whole issue of isolation becomes, while technically true, a bit irrelevant. Other than, as Techtronix says, if the circuit has leakage currents then (non-isolated) diff probes might not be the best choice:
"Differential probes provide a safe method to adapt a
grounded oscilloscope to make floating measurements.
In addition to the safety benefits, the use of these probes
can improve measurement quality. Differential probes
provide balanced measurement input capacitance so
any point in the circuit can be safely probed with either
lead. Differential probes also typically have better CMRR
performance at higher frequencies than voltage
isolators.
Another benefit is the full use of the oscilloscope’s
multiple channels with the simultaneous viewing of
multiple signals, referenced to different voltages.
Trade-Offs
probes may not be the best solution.
Other trade-offs include an added layer of cost -
depending on the oscilloscope capability an independent
power supply may be required, adding cost and bulk.
The gain and offset characteristics must be factored
manually into every measurement."
Just read that too.  But don't know what in a tube amp would be sensitive to leakage currents.
« Last Edit: April 10, 2020, 12:19:09 am by ToddW »
Those that know their history are doomed to repeat it.  It just takes longer than those who don't know their history.
« Reply #53 on: April 09, 2020, 10:36:22 pm »
There goes another perfectly good thread... sigh!
This is the best thread eva!
The following users thanked this post: Electro Detective
Offline engrguy42
« Reply #54 on: April 09, 2020, 10:50:23 pm »
Okay, but more importantly...
Long ago I had a Fender guitar and electronic amp. We're talkin' late 1970's. And at the time the guitar world scoffed at electronic amps, and said tubes are the only way to go. Kinda like the guys who were conviced that vinyl records were vastly better than all that digital rubbish. But personally I was amazed at how good the electronic guitar amps sounded. I forget the brand...
So does anyone make tubes anymore? Or are they just recycled from old equipment like Ham radios and stuff?
- The best engineers know enough to realize they don't know nuthin'...
- Those who agree with you can do no wrong. Those who disagree can do no right.
- I'm always amazed at how many people "already knew that" after you explain it to them in detail...
Offline engrguy42
« Reply #55 on: April 09, 2020, 10:56:16 pm »
Hold on...
It was a Crate G-40C. Beauty.
Offline 0culus
« Reply #56 on: April 09, 2020, 11:06:58 pm »
Yes, there are plenty of then still being made. Nowadays the cork sniffers prefer hand wired point to point construction over PCBs. Gotta get them toanzzz! I have an Egnater 15W head (definitely PCB construction) and 1x12 cab. It sounds freakin awesome and it's light enough to carry to a friend's house for jamming without breaking your back.
[edit] I thought you were asking about tube amps...but to answer your question, yes, tubes are still being made. Mostly in China, Russia, and Eastern Europe last I heard. They tend to not be as well made as the stuff made in the golden age of vacuum tubes, but they work fine for guitar amp use where the running parameters tend to shorten their lives anyway, as opposed to say a Tektronix 5xx series oscilloscope where the original tubes often still work fine because they were well made to begin with and are used strictly in a linear regime.
« Last Edit: April 09, 2020, 11:10:21 pm by 0culus »
Offline engrguy42
« Reply #57 on: April 09, 2020, 11:14:40 pm »
Wow, I never dreamed that tubes were still around, much less tube amps. Is Marshall still a big player?
So who uses tubes now? I assumed that the Ham radio world had pretty much dried up long ago (?), and the only folks using tubes would be the hobbyists fixing old scopes and radios and amps and stuff.
Offline 0culus
« Reply #58 on: April 09, 2020, 11:32:34 pm »
Audiophiles and guitar players mostly. The former annoy me because they rape classic test equipment for tubes.  >:( >:( >:( >:(
Marshall is still around, yes.
Offline WattsThat
« Reply #59 on: April 09, 2020, 11:37:54 pm »
Where can you find the “The technology the 1900’s meets the the technology of the 2000’s”?
That’s where you can buy overpriced vacuum tubes from an online store.
https://tubedepot.com/
A matched pair of old stock 300b’s will only set you back $10,000.00. But hey, they’re good for 40 watts each.
https://tubedepot.com/products/nos-western-electric-300b-black-plate-1961-matched-pair
They don’t call ‘em audiofools fur nuttin. With my apologies for helping to drag the thread off topic.
« Reply #60 on: April 10, 2020, 12:51:46 am »
Tell me your not jealous.
[ Specified attachment is not available ]
« Last Edit: April 10, 2020, 12:53:46 am by ToddW »
Offline james_s
« Reply #61 on: April 10, 2020, 04:22:28 am »
Have you been living under a rock? There are many thousands of tube amplifiers in service, a mix of vintage stuff and modern boutique equipment, both hifi and guitar amplifiers, they're as popular today as they've been any time in the past 40 years if not more so. Not all of the old types are still made but modern versions of many of the popular audio tubes are still manufactured. There are even high end $$$ audiophile tubes hand made in small quantities. Musicians and audiophiles are the primary users, then of course there are millions of vintage items out there. I have at least 3 vintage tube radios.
A quick google search for "tube amplifier" comes up with dozens and dozens of sites.
Offline Cubdriver
  • Nixie addict
    • Photos of electronic gear
« Reply #62 on: April 10, 2020, 07:02:30 am »
Tubes are definitely still around and popular.  I've built several tube-type audio and guitar amp kits over the past several years.
Dynaco ST 70 clone:
Transcendent T-16 Output Transformerless amplifier:
Encore and LF guitar amp kits from Allan Amplification and a tweed 5F1 kit from Tube Depot.  Also have a pair of VTA M-125s in the build queue.
As for differential scope probes, over a few years I bought a pair of Dave's EEVBlog HVP-70s.  The don't come out to play too often, but are very useful when they do.
-Pat
Offline engrguy42
« Reply #63 on: April 10, 2020, 10:34:19 am »
Living under a rock?? How the hell would anyone know that tubes are still used without going out of their way to investigate? Y'know, like going to a club or concert where some guy happens to be using a tube amp and go up on stage and say "hey, are those tubes in there?"  :D
Or spending time, as you say, searching google asking "hey, do tubes still exist?".
Most/all of my limited youtube time is looking at tech stuff, and the only thing I've stumbled on about tubes is the guy who does these 50 year old tube radios and stuff, which, honestly, is a big yawn for me. I never had any interest in tubes.
So back to the basic question: WHY? Why does anyone care about or use tubes? Is it just a boomer hobbyist or "I love old stuff" thing, or do people actually think there's a benefit?
« Last Edit: April 10, 2020, 10:35:57 am by engrguy42 »
Offline nctnico
« Reply #64 on: April 10, 2020, 10:57:16 am »
Probably the same reason people collect old cars, telephones, home computers, etc, etc.
Offline Gandalf_Sr
« Reply #65 on: April 10, 2020, 12:02:43 pm »
...So back to the basic question: WHY? Why does anyone care about or use tubes? Is it just a boomer hobbyist or "I love old stuff" thing, or do people actually think there's a benefit?
Apparently, musicians think that the sound of tube amplifiers is better than silicon.  I didn't realize until recently that the sound we associated with stars such as Jimmy Hendrix was where they had a specific effects pedal combined with a specific (almost always tube in the 'good' old days) amplifier. Such as the Fuzz Face.
Offline Fungus
« Reply #66 on: April 10, 2020, 12:14:19 pm »
You know CRT oscilloscopes are still around, even though they're "worse".
They give a different sound. Audiophiles call it "warmer" but really it's just noise/distortion.
Why would you want that? Depends on who you are.
Using a tube amp if you're a musician/guitar player it's no different then using a distortion pedal. It overdrives, it distorts, it gives you the sound you want.
If you're an "audiophile" it's usually a sign that you grew up in the 1970s when amplifiers were crap and that's what your ears are accustomed to hearing. Amplifiers without "warmth" sound cold and clinical to you, despite being better.
nb. A similar thing is happening in the younger generation. Their "warmth" is the all nasty artifacts caused by audio compression.  Audio sounds worse to them without it. :-//
https://www.google.com/search?q=youngsters+prefer+mp3+to+lossless
Offline Fungus
« Reply #67 on: April 10, 2020, 12:18:36 pm »
It is better when you're a musician.  Using a distorted amplifier is no different than turning a knob on a synthesizer, putting a mute in the end of a trumpet, pressing a pedal on a piano, etc., etc. It's what gives you your particular sound.
Offline nctnico
« Reply #68 on: April 10, 2020, 12:45:54 pm »
You are seeing this wrong. The 'amplifier' together with the guitar is the musical instrument. Not just the guitar.
The following users thanked this post: Fungus
Offline engrguy42
« Reply #69 on: April 10, 2020, 12:46:50 pm »
I guess I assumed that whatever people believe sounds "better", at the end of the day it's pretty much just a waveform. And presumably you can reproduce that with newer electronics.
I was never sure if the "tubes sound better" thing was an actual thing or just what people want to believe. Like I said, way back when there were those who were convinced that vinyl records sounded better than CD's and all that digital stuff.
I recall reading that Van Halen (a rock guitar god, IMO) never used any distortion effects to get his "brown sound". I suppose it's one of those things that's so difficult to prove that people can argue about it until the end of time. Like they've been doing since when I was a kid decades ago.
Offline nctnico
« Reply #70 on: April 10, 2020, 01:01:53 pm »
Ofcourse you can reproduce that with newer electronics. Tubes tend to clip softer resulting in even harmonics which are more pleasant to listen to.
Offline engrguy42
« Reply #71 on: April 10, 2020, 01:06:33 pm »
So all the audio tube amp afficionados are wasting their time?  :D
Uh oh....
Offline nctnico
« Reply #72 on: April 10, 2020, 01:17:50 pm »
This is getting wildly off-topic...
It can be a great hobby. Years ago I bought a piece of test equipment from an electronics enthousiast. He had build two huge horn loudspeakers (the size of a big fridge) which where extremely efficient. According to him this meant that the voice coils (self wound!) where operating in a very linear area so distortion from the speakers was minimal. He drove these from a (self build) class-A tube amplifier able of delivering just a few Watts. And yet he could crank the volume up to club-like sound levels. He also build his own turn table in which he used the ball from a ball-point-pen as a bearing for the arm. All in all very impressive!
Offline Gandalf_Sr
« Reply #73 on: April 10, 2020, 01:59:34 pm »
As nctnico said...
Offline exe
  • self-educated hobbyist
« Reply #74 on: April 10, 2020, 02:05:04 pm »
the gremlin called aliasing
Peak detect to the rescue.
The following users thanked this post: nctnico
