Author Topic: analog watt meter  (Read 9607 times)
Oracle
  • Guest
analog watt meter
« on: December 23, 2012, 09:39:37 pm »
hi,
where can i buy an analog lab watt meter? and what's the average price?
specification:
single phase, max 10 A 400V class: 1,5, 1 or 0.5
Offline The Electrician
Re: analog watt meter
« Reply #1 on: December 27, 2012, 06:58:27 am »
What accuracy do you require?  Do you want an electronic meter, or will an electromechanical one do?
Oracle
  • Guest
« Reply #2 on: December 27, 2012, 10:54:57 pm »
electromechanical possibly.
« Reply #3 on: December 28, 2012, 06:22:05 am »
« Last Edit: December 28, 2012, 06:26:07 am by The Electrician »
Oracle
  • Guest
« Reply #4 on: December 28, 2012, 11:05:37 am »
ok. thanks. Price is interesting.... Guess something new would be over 250 $.
« Reply #5 on: December 28, 2012, 02:58:10 pm »
If you buy a cheap standard 60A household meter you can make current transformers to increase sensitivity. I did that for myself, using a 10:1 CT to drop the FS range from 60 to 6A, it just reads 10x faster.
« Reply #6 on: December 28, 2012, 02:58:55 pm »
The Yokogawa meters run about US$650 new.  They're really nice however.  Mirrored scale, taut band suspension, double mumetal sheilding for the movement.
An alternative might be the Gossen Metrawatt Power meter.  I think Dave used one in a review.
Oracle
  • Guest
« Reply #7 on: January 03, 2013, 07:25:00 pm »
yes, they are nice, but if a new meter runs about $650 which is the equivalent of 500 euros, probably i would take an electronic one which has better performance, and it's computer controlled so you can use some monitoring/measure software.
I don't know Grossen Metrawatt instruments: never used and heard about them. I only used a Hameg HM8115-2.
Oracle
  • Guest
« Reply #8 on: January 03, 2013, 07:27:32 pm »
 but where i get a household meter + the ferrite core for the transformer?
« Reply #9 on: January 03, 2013, 07:47:19 pm »
Electrical wholesalers or other electrical suppliers for the meter. The core is not a ferrite but a wound core from a small toroidal transformer, or you can use any small mains transformer and remove the windings with a knife and use the core and the bobbin. You are winding 2 simple windings, one of a single turn of 10mm wire as the secondary and a 10 turn one of 2.5mm wire as primary.
Oracle
  • Guest
« Reply #10 on: January 03, 2013, 09:27:04 pm »
 it's interesting... but what household meter should i have, an old electromechanical one or a digital one?
« Reply #11 on: January 04, 2013, 04:47:43 am »
Any one will do, depending on what you want to do. They both have advantages and disadvantages for measuring.
Oracle
  • Guest
« Reply #12 on: January 04, 2013, 07:55:22 am »
of course same for multimeter.
I'm looking for something like this?
http://www.ebay.it/itm/contatore-elettrico-di-energia-tipo-enel-220-volt-/170429311183?pt=Attrezzature_e_strumentazione&hash=item27ae60e8cf
Because the electronic one it's very expansive than this one.
Oracle
  • Guest
« Reply #13 on: January 04, 2013, 08:05:11 am »
I would like to share this, speaking about analog instrument/meter ecc ecc :
http://www.ganzinst.hu/products/portables/port_selector.htm
all instruments are class 0.5 or 1.
Don't know the price list....
