Author Topic: RIGOL MSO5000 series waveform colour  (Read 573 times)
Offline sdevTopic starter
  • Country: in
« on: December 23, 2022, 12:57:35 pm »
Dear All,
This is first time I am using RIGOL MSO5000 series oscilloscope. Two issues. Channel 4 waveform is Blue which is not clear. And when using inverted image, it shows yellow in white background. Both cases it is difficult to see waveform. Also there are some lines when saving waveform in gray scale. Is there any work around for this.
Offline Martin72
  • Testfield Technician
Re: RIGOL MSO5000 series waveform colour
« Reply #1 on: December 23, 2022, 04:54:59 pm »
Unfortunately, you can't change the colours like you can with the siglent(SDS2k+).
Much worser is the fact that every math-trace got the same colour on the rigol... :P
Would be a good idea to post it as a feature wish in the rigol 5000 feature thread.
Martin
(Kierkegaard)
  • Country: in
« Reply #2 on: December 23, 2022, 05:28:34 pm »
Then what would be a reasonably good setting.. especially showing waveforms during presentation/ paper publication..
Offline Martin72
« Reply #3 on: December 23, 2022, 06:47:14 pm »
A little conversation about different trace colours, starting here:
https://www.eevblog.com/forum/testgear/siglent-sds2000x-hd-12bit-(published-for-chinese-domestic-market-only)/msg4550321/#msg4550321
On the next side you can see a pic from a printed sheet with different trace colours...
(Kierkegaard)
