Author Topic: Heathkit IT-1121 Curve Tracer Repair  (Read 14266 times)
Offline jcrubinTopic starter
    • Technocoma
Re: Heathkit IT-1121 Curve Tracer Repair
« Reply #25 on: April 10, 2017, 12:58:43 pm »
Second Movie Posted
CVM CATAPVLTAE PROSCRIPTAE ERVNT TVM SOLI PROSCRIPTI CATAPVLTAS HABEBVNT
https://www.youtube.com/c/jordanrubin6502
    • Technocoma
« Reply #26 on: April 17, 2017, 12:12:38 pm »
Final movie posted
Transistor test from moped ignition
« Last Edit: October 22, 2018, 12:23:55 am by jcrubin »
Offline tnjent98
« Reply #27 on: August 03, 2018, 08:12:03 pm »
this is a great thread and shows many experts on this blog....so, my question is , since I do tube amp design, repair and upgrades, can this tracer by modified to test common audio tubes, like 12ax7, 6sj7, 6v6, 6l6 6bq5....looking forward to hearing the comments
thanks
tom
    • Technocoma
« Reply #28 on: August 04, 2018, 02:01:08 am »
thanks
tom
Modified the way a car CAN be modified into a boat, or a house.  It would be a crazy modification that would outweigh the effort of building a uTracer.
Offline xxx2fan
« Reply #29 on: October 21, 2018, 10:58:21 pm »
Reading your post on curve Tracer Repair
Just wondering if you found R61 to be the 1.2M resistor that was where the 1.5K was placed by the builder by mistake.
Interesting thought.
Thanks if you happen to see this
know its an older post.
That 1.2M in the kit had to end up somewhere LOL
    • Technocoma
« Reply #30 on: October 22, 2018, 12:14:29 am »
A great question!
After rejoicing in finding the mistake that someone decades ago spend countless hours banging their head against the wall and seeing it function, I did an inventory first for that resistor, and then every other. Turned out to be that one mistake and the subsequent burned out opamp, though, id imagine at the time the opamp was in working order.
thanks for asking
Offline WalterG
« Reply #31 on: October 22, 2020, 12:16:24 pm »
I also have a IT-1121 in use. And made some modifications. I added the possibility to test enhance mode FET's. Originally this was not possible, only depletion mode.
If interested go to my webpage. It's in Dutch but on top is a Google tanslate button, and you can enable it by hand.
https://people.zeelandnet.nl/wgeeraert/drblan.htm#IT-1121
    • Technocoma
« Reply #32 on: November 07, 2020, 04:37:27 am »
Thats cool.... I wonder, given 12VAC and enough DC supply of a 12AX7 could be traced on the unit with those mods.
