Hello 👋
Is there a way to Adjust\Calibrate Aneng Q1 Multimeter.
Short story, I got the Multimeter and noticed it's a "Battery hungry" so I replaced the normal AA batteries with 3.7 lithium-ion.
During the process I "accidently" ripped off the traces of positive and negative of the AA battery holder.
After resoldering the traces, the Multimeter started showing Inaccurate measurements, here are a few examples:
Measuring AC 238V, It's actually 230V
Measuring DC 4V, It's actually 3.9V
Measuring Ohm 5.86K, It's actually 5.65k.
Measuring Temp starts at 45C/113F. and so on.
The Multimeter doesn't have a potentiometer inside it.
There's a component inside labeled ICL8069, I think it's called TVS, it should be 1.2V voltage reference, but it's measuring 1.236V
Yes, I replaced the leads. No, the Multimeter doesn't get any voltage above 3.6V from the lithium-ion battery.
Any help is appreciated.
Full review for Q1 Multimeter from eevblog YT channel:
