Author Topic: Another MSO5000 logic probe design  (Read 1604 times)
Offline festTopic starter
  • Country: lv
« on: March 17, 2023, 02:41:49 am »
As I mentioned in Gandalf_Sr's thread, I'm taking a stab at cheap'o MSO5000 logic probe design which does utilize voltage threshold selection in oscilloscope (since it's there, why not use it?).
I have come up with the following design: https://github.com/festlv/mso5000-logic-probe
I'll order the PCBs as soon as I finish some other designs, so proceed with caution if you want to build one yourself.
  • Country: lv
Re: Another MSO5000 logic probe design
« Reply #1 on: April 11, 2023, 05:09:34 pm »
Just got back the rev0 PCBs and can report that the design works as expected (with one BOM change as documented in repository)- I can select the threshold on the scope which sets the VCC for the input buffer accordingly.
I'll perform some more testing later (i.e. how well do the thresholds work for various common use cases, what happens when the input actually exceeds the VCC of the buffers etc).
The following users thanked this post: luma, mwb1100, MaTkEOxjC
Offline Robbie-Mac
« Reply #2 on: August 24, 2023, 07:33:20 am »
I ordered a set of boards tonight... some parts not available from my regular (read familiar) supplier. This is the first board I am attempting with parts this small... any suggestions? Also, before I sink money into parts, how has the testing gone? Any results you can share?
  • Country: lv
« Reply #3 on: August 24, 2023, 08:47:51 am »
I didn't get around to a rigid test procedure, but so far it has held up nicely for my use cases.
The most complicated thing it has seen is ~single clock cycle pulses at 176MHz (6ns or so), which showed up fine.
Offline Robbie-Mac
« Reply #4 on: August 24, 2023, 04:01:03 pm »
Awesome! That will cover my use cases very nicely as well. Thank you very much for the quick reply.
  • Country: lv
« Reply #5 on: August 24, 2023, 08:54:48 pm »
BTW I think I have parts for a few sets left over. If you're in Europe AND can't find the parts from mouser/digikey, PM me with the parts you need, might be able to ship them to you.
