Author Topic: Another MSO5102D bricked....!  (Read 463 times)
Offline zolTopic starter
« on: March 24, 2024, 02:59:02 pm »
Hello to all...!
After a bad firmware upgrade , my MSO5102D is stuck at the beguinning start cycle : at switch ON appears the blue screen with strips of different colors ( as usual ) but suddenly turns black with some little dots at top and, after some seconds, start again with the blue screen ( in an eternal loop...).
I have attached a serial-usb converter inside the circuit internal ( after some intense search info ) and I have the initial boot log (attached to this message) (I guess is well attached...)
The serial number is : T 1G/012 009551
The soft version is : 2.07.1 ( 130321.0 )
The hard version is : 10070x555583e9
Of course I don't have any backup of the original Filesystem...!! |O
I guess some upgrade of a correct image or some important files are needed to turn the MSO to life....
Any help is well received ....!
...and thanks in advance too...!!!
Zol
« Last Edit: April 08, 2024, 04:38:59 pm by zol »
