Author Topic: Bside.cn ADM01 - $13 multimeter - First impressions  (Read 8714 times)
Offline SA007Topic starter
« on: April 29, 2015, 05:53:43 pm »
For our hackerspace we were intrested in a number of multimeters for during arduino trainings etc.
So budget is low and this seems to be the cheapest non-toylike multimeters.
Received 2 today for evaluation, but it seems we are going to order more.
So far it seems very good value for money:
  • Quite a good blastshield embedded in the casing.
  • Ceramic UL marked fuses
  • 2 PTC's as input protection
  • Beeper is non-latching but very quick
  • Autoranging is quite fast, < 1sec for 3 ranges
  • So far accuracy seems on-par with the manual
  • Manual is not useless at all
  • Range selector has a solid feel, but not goldplated or anything special
  • Casing itself also seems very solid, like it could easily survive a drop from a bench
  • Probes have quite nice finish and good strain relief.
  • Even a threaded insert on the battery cover
The are of course downsides
  • No battery included
  • Probes are not even remotely sharp
  • Buttons are cheap trough-hole switches and take quite some force to operate, often shifting the meter, but not falling over.
  • You have to take it apart to swap the fuses, not in the battery compartment.
  • Volt and milli/microamp are on the same connectors, making it easy to accidentilly fry the fuse
  • Hz function has a minimum resolution of 10 Hz and can only go to 20kHz
Some things I noticed so far:
Hz: quite accurate on sine/square/pulse, inaccurate on sawtooth.
On the back it says 'PATEN PENDING', don't know where you can register those... :)
View angle of the LCD is reasonable in all directions but up.
So far it seems like a very good meter considering the price, can't find any mayor downsides.
If anyone has any (not explicitly destructive) tests the want to see you can ask, but I don't have a cal lab or anything.
Offline Wytnucls
Re: Bside.cn ADM01 - $13 multimeter - First impressions
« Reply #1 on: April 29, 2015, 06:18:40 pm »
Made by Mastech.
Online Vgkid
« Reply #2 on: April 29, 2015, 06:46:09 pm »
Pics would be nice.
Offline rsjsouza
  • Eternally curious
    • Vbe - vídeo blog eletrônico
« Reply #3 on: April 29, 2015, 06:59:37 pm »
« Reply #4 on: April 29, 2015, 08:05:08 pm »
Of course pictures :)
I tried to snap some pictures of the meter and insides.
Lighting is a bit of a hassle, so some are a bit grainy, but most are ok.
Fyi: they are multilevel-clickable up until the camera's full 10mp.
Gallery-ish: http://fotos.sa007.nl/Bside_ADM01/
« Last Edit: April 30, 2015, 10:22:41 am by SA007 »
Offline radhaz
« Reply #5 on: April 30, 2015, 03:16:03 am »
Looks pretty good for what it is. Are the banana jacks supported on the z axis?
Online Vgkid
« Reply #6 on: April 30, 2015, 03:42:11 am »
That actually looks pretty good.
Offline miguelvp
« Reply #7 on: April 30, 2015, 04:02:48 am »
Source for the $13 price range would be nice as well :)
Although I did find it on ebay for close that price, I like that you can keep the probes attached to the back of the meter  :-+
Offline paulie
« Reply #8 on: April 30, 2015, 04:39:42 am »
Appears to be a copy of UTI UT136b. Same features, specs, and price too. After the $5 bottom enders it is my favorite. It would be my number one if you didn't have to push the "func" button to get continuity and had signal generator like the cheapies.
Offline iloveelectronics
  • Country: hk
« Reply #9 on: April 30, 2015, 04:43:28 am »
I believe it's a rebadged Mastech MS8233D (which usually goes under the brand name Hyelec instead of Mastech, but it's the same factory).
« Last Edit: April 30, 2015, 04:45:37 am by iloveelectronics »
My email address: franky @ 99centHobbies . com
My eBay store: http://stores.ebay.com/99centhobbies
Offline paulie
« Reply #10 on: April 30, 2015, 05:11:37 am »
I wonder who was first?
Anyway looking closer it appears the UT136b has advantages: Separate current jacks and 10mhz instead of 20khz. The jack thing is not that imporant to me but I do wish they had chosen continuity as default instead of diode check. The former is far more useful to me.
« Reply #11 on: April 30, 2015, 07:36:51 am »
I bought them from here:
Ebay url...
$13.40 and discount is you buy more.
for unknown reason the seller does not list it as brand/type...
Could be a rebranded MS8233D, it doesn't have the non-contact voltage detector, but some parts are missing.
It is a new case though.
Offline Lightages
  • Canadian po
« Reply #12 on: April 30, 2015, 03:32:03 pm »
It actually says MS8233D on the circuit board. It probably a down featured version. For $13 it is better than many from the looks of t.
« Reply #13 on: April 30, 2015, 06:12:55 pm »
I was also pleasantly surprised by the quality.
I've had $20 meters that were 'rated' 600V literally blow up in my face on regular mains voltage.
Our initial idea was to buy these, strip off the '600V max' and sticker it with 100V max.
But the build quality seems good enough that it would actually survive 600V without issues.
For the 'real' measuring we just grab a fluke, but buying 10 of them to measure 3.3 and 5V is a tad expensive.
Offline broderp
« Reply #14 on: April 30, 2015, 10:57:12 pm »
Interesting find.
Can you tell us what the accuracy claimed on this is? Any specs of the meter as stated in the manual vs. what you found?
I'm a sucker for decent cheap electronics, but more importantly, would make a good gift for my 13 year old son, and if it breaks or he doesn't stick with electronics~ I would get to use it.. :P
Offline Lightages
  • Canadian po
« Reply #15 on: May 01, 2015, 12:00:13 am »
Except for the fuses not matching the CAT rating, I would basically trust this for CATII 600V as rated. I generally don't trust anything made by Mastech but this looks OK especially for the price.
Offline 001
  • Country: aq
« Reply #16 on: December 12, 2015, 10:21:15 pm »
it is  actually clone of mastech MS8223E
Few my mods:
- 8MHz quarz instead 4MHz gets unit more responsive
- main chip is FS9952 — You can add manual range. etc
- it is simple to combine hold and backlight functions in one button (quick or continuous pressure)
Offline firewalker
  • Country: gr
« Reply #17 on: December 12, 2015, 10:29:34 pm »
Does it measure voltage with the mA fuse blown?
Alexander.
