unless I've been duped, the supplied TL75 leads are truly horrible.
Some clear focused pictures of both ends would help us determine if they are fake or not. I'm guessing about 5 or 6 years ago, Fluke starting putting the make/model and date code on the actual cabling. I believe it is white lettering.
Real TL75s can be stiff. They are not silicone. Modemhead has some pictures of the real TL75s cut apart.
http://mrmodemhead.com/blog/no-name-vs-branded-test-leads/
As for the oxidation, some IPA might remove it.
I didn't expect silicone, it's just that I've seen more flexible PVC leads... but my main problem is that you can't trust leads that are susceptible to corrosion. I have more leads than I'll ever need, so this is not a problem, it's just a bit weird, considering that these are sold for twice the price of a quality Brymen silicone set.
I'm inclined to believe that these are genuine, maybe adjusted for the Chinese market (attached are the pictures, best I can manage now, sorry).
Other than the leads, what do you think of the meter?
So far it's very nice, just what I expected. Small but not too small, not very rugged, but not cheap either. Functionality covers any household need I can think of. Accuracy seems good:
Resistance (.1% parts) :
100k: 100.2k
20k : 20.02k
1k : 1.001k
DCV (compared to a BM857a):
BM857a Fluke 106
0,6003 0,598
6,007 5,992
25,009 24,92
50,002 49,83
DC current (compared to a BM857a):
BM857a Fluke 106
0,1107 0,109
0,5000 0,498
1,0019 0,999
ACV (compared to a BM857a):
@ 100Hz Sine
BM857a Fluke 106
0,0704 0,071
0,7091 0,708
7,007 6,99
@ 50Hz Sine
226,2 224,3
A weird quirk is that you can sometimes rotate the switch without turning on the device, but this is rare.
Continuity is quite slow, worse than a non-latched would be, and it's volume is too low. This kinda feels like an artificial limitation.
Overall I'm quite satisfied with it, and I'm really looking forward to gifting it
Thank you guys for the previous recommendation and help!
