I have two, one that I re-capped has a great display (after re-capping) but has a u/s main port after I inadvertently Tx'd into it (I don't actually ever remember transmitting, but it was directly after testing a transcevier on it). There is an expensive attenuator on the main port that's broken that I can't figure out how to replace (can't undo screws). The aux port works fine for my use.
The display on the first unit has developed a more recent fault where, particularly in warm weather, it randomly writes to the screen, but otherwise works fine. I can still control it perfectly via GPIB once I figure out the commands, which are much easier to figure out when you have a working display! Reseating the cards seems to fix the display random writes for a few days, only for it to return later. Of course, with the lid off the problem never happens.
The other unit has a very dim display plus its signal generator seems to be kaput (about 20dB down) on both ports, but I've never had it apart to fix it.
Edit: more recently I switched to using an Agilent 8935 for most of the measurements I'd been using the Anritsus for as part of a production test suite process. A shame, as the Anritsus offer significantly greater bandwidth over the Agilent, but the reliability of the Anritsus is none too special.
