I'm setting up an educational experiment using RTB2004 for which I would need to show result of a math expression v.s. one of the channels. XY mode would work perfect, but according to the manual I can only use channels as inputs.
While searching the forum for ideas I noticed that not all features of the scope are documented in the official manual, so maybe someone knows a trick how to map a math expression to one of the X/Y axes?
I'm using SCPI commands to set up the scope, and replacing CHx with Mx in the source selection command does not work.
