Author Topic: Rigol DP2000  (Read 1432 times)
Offline tangramTopic starter
Rigol DP2000
« on: September 12, 2022, 11:21:24 pm »
Been running through a repair (again!) and recalibration on my DP832, it occurred to me that this is a pretty good PSU, but it's getting a bit long in the tooth. I asked the question, has there been any mods done recently? The answer was 'yes' and it comes in the form of a couple of new, at least new to me, models. I can't see that the DP900 is much of a step, but the DP2000 has a couple of interesting features, including better accuracy on output values (V & I), better resolution of current output and, a feature I've missed on my box, 4-wire voltage output, I. E. Its got voltage sense control, a real boon for high current applications.   There's very few reviews out there, however. Has any one of you guys/gals got one of these puppies? Is it worth the outlay?
"All specifications are subject to change!"
Offline Xoff
Re: Rigol DP2000
« Reply #1 on: December 28, 2022, 09:03:23 am »
I've just got DP932E. Main improvements over DP832 are:
- quick setting (larger touch-up screen),
- low-noise fan,
- internal parallel/serial connectivity of CH1 and CH2 (max 6A/60V),
- 3 independent (separated) output channels (CH1 30V/3A, CH2 30V/3A, CH3 6V/3A).
