Author Topic: Value display is not stable  (Read 940 times)
Offline hongthiet1994Topic starter
  • Country: vn
« on: April 12, 2019, 08:10:49 am »
I have a DMM 12gw eevBlog
I do not know my DMM was error or normal
May be show your DMM ?
Thank you so much
https://youtu.be/E6-Pspjto0g
Offline BravoV
  • +++ ATH1
Re: Value display is not stable
« Reply #1 on: April 12, 2019, 08:18:44 am »
Its normal, as the input is very sensitive when opened.
Try short both probes.
Offline Psi
« Reply #2 on: April 12, 2019, 08:24:42 am »
Yep, its picking up RF/EMF noise in the air.
Totally normal.
Should go to solid zero when you short the probes together.
Some meters have added hackery/code to try and show 0.0000 if it looks like very small noise, but this is bad because if you actually have a very low signal your meter may lie to you and says its zero.
Offline Brumby
« Reply #3 on: April 12, 2019, 01:06:32 pm »
This is absolutely normal, especially for low range readings and floating probes.
