Author Topic: Anyone (else) using a vector voltmeter?  (Read 3441 times)
Offline pdenisowskiTopic starter
  • Product Management Engineer, Rohde & Schwarz
    • Test and Measurement Fundamentals Playlist on the R&S YouTube channel
Re: Anyone (else) using a vector voltmeter?
« Reply #25 on: June 26, 2024, 12:15:16 am »
I had a go at logging my newer HP 8405A  VVM (made in 1986) to see how stable the phase is over time. This is done using a DVM connected to the phase recorder at the back of the meter.
Very cool.  Now I'm wondering if that methodology could be used to measure Allan variance of sinusoidal signals ....
Test and Measurement Fundamentals video series on the Rohde & Schwarz YouTube channel:  https://www.youtube.com/playlist?list=PLKxVoO5jUTlvsVtDcqrVn0ybqBVlLj2z8
Offline G0HZU
« Reply #26 on: June 26, 2024, 08:36:02 am »
I have read that the NPL used the HP 8405A to compare frequency standards in the long and short term but I don’t know what they use now.
My HP 8405A had to be on for about 2 or 3 hours to get the stability in my previous plot. I think it would be even better if left running 24/7 in a controlled lab.
The following users thanked this post: egonotto, pdenisowski
« Reply #27 on: June 26, 2024, 11:20:32 am »
The two main ways I see Allan variance measured are either using (good) counters or using phase noise analyzers, but I assume that a VVM could be used to do this as well.
Even today, most modern T&M instruments (even ones with OCXOs, external references, etc.) get their optimum performance after being given time (minutes to hours) to warm up.
If you're measuring Allan variance, you're probably going to be leaving your instrument (whatever you use) on for a long time anyway :)
The following users thanked this post: G0HZU, egonotto
Offline G0HZU
« Reply #28 on: June 26, 2024, 06:31:54 pm »
I found a link to the classic HP app note AN-77-3. This shows how to measure impedance using a vector voltmeter and a decent directional coupler.
https://www.hpmemoryproject.org/an/pdf/an_77-3.pdf
The HP 778D coupler is the usual choice here as it offers >40dB directivity (typical) across 100MHz to 1GHz and it can be used a bit below 100MHz because the directivity is still good here.
I've got a 778D coupler here and use it fairly regularly for various tasks. There is a nice image of an HP engineer using the classic combo of the HP 8405A and the HP 778D coupler in figure 2 of the link above. I've also added the figure 2 image below for convenience. The engineer can be seen using a smith chart to convert the reflection coefficient (indicated by the dials of the HP 8405A) to impedance.
The AN-77-3 app note provides all the theory and equations for this.
How lucky we are today to have modern VNAs to compute all this stuff across hundreds of frequency points in the blink of an eye  :)
« Reply #29 on: June 26, 2024, 11:09:32 pm »
Wow - I somehow missed that app note.  Thanks!!!
(And the pictures in the app note are absolutely priceless)
Offline shabaz
« Reply #30 on: June 27, 2024, 03:42:18 am »
Experimenting a bit further with the previous setup (and realized that the ~10 Hz was simply the sum from the mixer, aliased due to sample rate, and not a frequency discrepancy between the two input signals!).
The addition from the previous experiment, is that I've added a 500 kHz low-pass filter on the output, so that I can remove the sum and retain just the DC value. As before, I then adjusted the phase from -180 to +180 manually turning the dial, and captured that to a 'scope. This time I'm using 1 MHz signals because I forgot to set them to 10 MHz when I captured the 'scope trace. Everything is quite wideband in the circuit anyway, so that doesn't change anything material.
The output is pretty rock-solid, easy to measure with a multimeter or view with 'scope.
I *think* this could be useful to observe phase noise. This is for no real reason, I'm just kicking tyres with this experiment.
Currently I'm just using two outputs from a single 'sig-gen, but might try to split that across two tomorrow just to see what happens. Or I could try to use a scrap AliExpress OCXO for one of the inputs, I have a few and been meaning to do something with them.
Offline RBBVNL9
« Reply #31 on: July 26, 2024, 08:31:03 am »
Hi all,
For those interested, I just posted a video on getting an R&S ZPU Vector Voltmeter to work...
I loved the quite advanced electronics used, given this is 50 years old, like the thin film sample & hold circuitry hidden in the little probe heads!
Best, Rudi
« Last Edit: July 26, 2024, 08:42:07 am by RBBVNL9 »
The following users thanked this post: egonotto, pdenisowski, srb1954
