anyone here own or ever used a lecroy LC584 scope?
Not the LC Series, but several other LeCroy scopes. The older LeCroys have a consistent user interface amongst the various models (9300 Series, LC Series, WR LT Series, WR2 LT Series, WP 900 Series), so they all operate more or less the same. The probe interface (ProBus) is also the same across the older scopes to even the latest ones, which makes it easier sharing probes.
i found out about them a week ago, i love the way it looks. but im not sure about performance. nobody talks about it.
There are various discussions in this forum touching LeCroy scopes, just use the search function.
As to performance, well, the LC 500 Series is from around 1997/1998, which means it's a roughly 16 year old high end oscilloscope which at the time was unmatched in capabilities by other scopes and which even today offers some capabilities which even today you'd only find in very expensive high end scopes from other manufacturers, if at all.
if you have any experience with it, negative or positive i would enjoy hearing about it.
any input appreciated.
Well, these are great scopes, and the unified user interface means that if you can drive one you can drive all of them. Some things are different than on other scopes (i.e. horizontal left, vertical right) but in my experience it doesn't take long to get used to it. However, the real strenghts of these scopes lies in the available software options which for the 9300 Series and the LC can be had for free now.
The LC584 is essentially a 9384 with faster processing (PPC instead of M68k) and color screen instead of monochrome. The front ends are the same, as are many other parts. The LC584 also shares the 9300's tendendcy for the auto-range circuitry in the PSU going south-side, but there's a fix for it which removes the auto-range board and fixes the input voltage to 110v or 230V, whatever is required. The build quality of the LC Series is decent, it's a bit more robust than the 9300 Series. None are a match for the later Iwatsu-made scopes (WR LT, WR2 LT, WP900), though.
On the other side, the LC Series is now quite old, and the 500 models uses color CRTs which aren't great in terms of sharpness and convergence (the later LC600 models got LCDs instead which were much better). If you don't have one already then I'd seriously consider getting a WaveRunner LT or WavePro 900 instead, which both are newer/faster and of better build quality (but not necessarily more expensive than the LC Series).
