Author Topic: Anyone recognizing this 12-pin instrument connector?  (Read 405 times)
Offline RBBVNL9Topic starter
« on: September 18, 2024, 07:08:34 am »
Does anyone happen to recognise this instrument connector (type, brand)? It has 12 pins in 4 rows (2-4-4-2), a larger notch/key at the right upper corner, and smaller notches at three other corners.
It's present on the Racal 6103 Digital Radio Test Set and used to power a mobile phone and communicate with it (using the Agilent E6392-60001 accessory).
I already took a quick browse through some supplier's catalogs but did not yet find this type.
Thanks!
Rudi
Online Psi
Re: Anyone recognizing this 12-pin instrument connector?
« Reply #1 on: September 18, 2024, 07:23:03 am »
Pretty sure the brand is Hirose, or at least, Hirose make something quite similar RP13A-12PD-13SC however your one is 12P and that one is 13p.
It might be something custom. Have a look around the Hirose website.
It's also possible Hirose are making a copy of some other connector design. So keep that in mind.
The fact that the keyways are arcs on your one and square on this one makes me wonder if Hirose is copying the design of someone else
« Last Edit: September 18, 2024, 07:29:41 am by Psi »
« Reply #2 on: September 18, 2024, 07:35:39 am »
Thanks a lot Psi!
Indeed, this Hirose connector looks like it is the same one! And, unless I am mistaken, the one you refer to actually has 12 pins, just like mine (not 13).
Perhaps not surprising there is a Japanese connector on this device. Even though it is a Hewlett Packard (/Agilent) device, it says it is made in Japan and also inside several PCBs have "Made in Japan" written on them ;-)
Best Rudi
Online Psi
« Reply #3 on: September 18, 2024, 07:37:31 am »
na RP13A-12PD-13SC is 13pin,  i checked.
Row of 2
Row of 4
Row of 4
Row of 3.
Your one only has 2 on the bottom row.
« Reply #4 on: September 18, 2024, 07:42:40 am »
Oh, sorry, I was indeed looking at another one, RP13A-12PD-13SC, as sold from TME.
That is one one I am looking for! (At least, a plug that goes in there ;-)
Thanks again!
Online Psi
« Reply #5 on: September 18, 2024, 07:46:19 am »
ah, i see.  RP17 is 12p
Digikey has some Hirose RP17 plugs and connects. See if any of those looks right.
« Last Edit: September 18, 2024, 07:48:27 am by Psi »
« Reply #6 on: September 18, 2024, 07:51:41 am »
Thanks again; this has been very helpful!
Case closed  :)
