Author Topic: anyone tried the dreamsource labs u3 pro 16?  (Read 108 times)
Offline psxpetey1
« on: January 26, 2021, 11:09:59 pm »
This product seems ok for my uses I need 14-16 lines currently however it only comes with 16 clips, do I need to buy more to use the full range of connectors because their will be grounds etc? Product reviews are vague and there are not many youtube videos on this device any advice would rock. I'm trying to use it to decode commands going to and from a 48pin tsop nand datasheet here: https://datasheetspdf.com/pdf-file/607807/Samsung/K9HAG08U1M/1. A few members of sigrock said I may need to write my own python for that but I may be able to get started with parallel or something. So What all do I need to use the device to its fullest potential and to work when it hits my doorstep and also do you recommend. I using a nand socket: https://www.ebay.ca/itm/1PCS-TSOP48-TSOP-48-Socket-For-Programmer-NAND-FLASH-IC-NEW-S/182395938731?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m2749.l2649 so leads will be easy to connect.
