Bonjour a tous,
Discovered another one here with leaky damaged battery compartment, so I am removing cleaning and swapping the small battery rear cover, 2" x 5.5"
I can receive in either EU or USA . In case someone turns up a spare cover, I am grateful.
I just unearthed the Triplett 630NA, which had severely corroded AA battery, but otherwise in great cond.
After cleaning the extensive alkaline corrosion and soldering back the wire to the battery holder, then contact clean on ohms control pot, its perfect and in CAL on every range.
Inside the Triplett has a MUCH higher quality PCB, resistors and design than the Simpsons.
Many thanks again!
Jon
