Author Topic: AR- 488 first time.  (Read 2057 times)
Offline simba15Topic starter
AR- 488 first time.
« on: December 13, 2022, 10:28:48 pm »
So I built a arduino mega/AR488 adapter.
I used 1/2 of an old gbib cable from a box and a authentic arduino mega.
I uploaded the code ( after adding devnull) and it didn't seem to have any indication of working.
Maybe I am missing too many of the configuration steps. Is there a guide to show a basic operation like *idn?
I read alot of the documentation but I was unsure if I need to modify the config from default ( I enabled macro 0 and startup and set the address to 22 ( for my 34401) , but I didn't see any thing in the arduino serial console. Should I?
TIA.
Re: AR- 488 first time.
« Reply #1 on: December 14, 2022, 03:45:55 pm »
So I can get a response from ++ver, thats a good sign.
I will test further with sending ++auto 2 and ++addr 22 then *idn?
I am trying to communicate with a 34401 or a HP5316A
Thanks,
« Reply #2 on: December 14, 2022, 04:14:32 pm »
So I tried with the 34401 ( set to addr 22 and gpib 488) and I tried ++idn 1 and *idn?
Both get no response. I tried enabling ++verbose mode and it shows sending idn but no reply.
Any suggestions on how to troubleshoot? I am confident in the wiring ( but I will re check all connections.)
Thanks.
Offline Hexley
« Reply #3 on: December 14, 2022, 05:33:58 pm »
Maybe this snippet of dialog (taken from TestController) for a similar instrument with a Prologix interface will be of help. Specifically, don't forget to "++read eoi" to get the data back:
;; Start thread for: PrologixEthernet A:3 - HP 53131A
;; 192.168.0.36: Tx: <++auto 0.> 2B 2B 61 75 74 6F 20 30 0A
;; 192.168.0.36: Tx: <++mode 1.> 2B 2B 6D 6F 64 65 20 31 0A
;; 192.168.0.36: Tx: <++addr 3.> 2B 2B 61 64 64 72 20 33 0A
;; 192.168.0.36: Tx: <*IDN?.> 2A 49 44 4E 3F 0A
;; 192.168.0.36: Tx: <++read_tmo_ms 3000.> 2B 2B 72 65 61 64 5F 74 6D 6F 5F 6D 73 20 33 30 30 30 0A
;; 192.168.0.36: Tx: <++read eoi.> 2B 2B 72 65 61 64 20 65 6F 69 0A
;; 192.168.0.36: Rx: <HEWLETT-PACKARD,53131A,0,3703> 48 45 57 4C 45 54 54 2D 50 41 43 4B 41 52 44 2C 35 33 31 33 31 41 2C 30 2C 33 37 30 33 0A
« Reply #4 on: December 15, 2022, 05:04:49 pm »
Thanks, Hexley
I will review and try these commands manually and with Testcontroller.
How do you set a device to use GPIB in Testcontroller?
Thanks,
Offline HKJ
    • Tests
« Reply #5 on: December 15, 2022, 06:22:47 pm »
The device must be define to support GPIB, then you can click on the "Type" column and select GPIB. Address is letter:gpib_address and you must define the letter in the GPIB popup as the id on your GPIB controller:
Offline Hexley
« Reply #6 on: December 15, 2022, 07:07:22 pm »
While testing your AR-488, don't forget that the '5316A won't respond to *idn? since that is SCPI even though it does not look like it. The HP5316A doesn't know about SCPI.
If you decide to make a Device File for the HP5316A in TestController, you might want to check out the entry  "HP3478A.txt", as it illustrates how to use simulated SCPI commands to handle these devices with early (i.e., non-SCPI) implementations of HPIB.
« Reply #7 on: December 15, 2022, 10:18:43 pm »
Thanks!!! I sure I would have gotten there but you just saved me days of testing.( I bet.)
I got communication with the 34401!
But I don't understand how to set a gpib device in testcontroller. Do I simply set to rhe com port of the gpib and it will work? ( seems to easy)
Thanks again!
Offline coromonadalix
« Reply #8 on: December 16, 2022, 11:41:36 am »
Testcontroller has the 34401a meter in the selection list  BTW,    you should be able to slect it and choose if you connect to gpib and or serial
It would be more practical to use the 34401a in gpib mode with an DIY ar488 dongle,  thread is here ...
« Reply #9 on: December 16, 2022, 02:56:58 pm »
So see the attached screen cap,
I can communicate with the AR488 with Putty but cant get any data with Testcontroller.
Any ideas what I may have set incorrectly?
Thanks.
« Last Edit: December 16, 2022, 03:00:24 pm by simba15 »
Offline HKJ
    • Tests
« Reply #10 on: December 16, 2022, 03:14:53 pm »
TC do not always support directly communicating with a device, it depends on the device configuration. Only for SCPI devices are there direct communication and answers are only expected on commands that ends with ?. All other device drivers has a internal SCPI like layer that translates a couple of commands* to something the device understands and translates the answers back to ascii.
*These commands are often defined in the definition file, but not always and will for many drives be shown in the help window.
On the "Load devices" page it look like this (With the AR488 definition posted above):
But it is not support for the 34401A.
It can easily be added, open the file: AgilentHP34401A.txt and change the line: "#port com" to "#port com gpib"
Then restart test controller (If the HP34401A is already added, remove it and add it again).
I have no idea if it works, but if somebody can report here that it works it will be added to the next release version of TC.
Also note: I still have a bug in the GPIB implementation, that means only one loaded device for each GPIB interface.
« Reply #11 on: December 16, 2022, 04:36:42 pm »
Thanks HJK,
I set the def file as stated but unfortunately it seems it is still not working,
I cant see why tho, as the com port responds when I use putty. With TC I get no RX in the debug (you can see it send the correct gpib commands and *idn? but there is no RX.)
Any ideas what the issue could be? It seems to be related to the com port setup.
Thanks.
Offline HKJ
    • Tests
« Reply #12 on: December 16, 2022, 04:47:06 pm »
Is the baudrate correct?
You can start TC with the debug .bat file and get more information about the communication (Note: Many errors will go to the DOS window, not the log).
« Reply #13 on: December 21, 2022, 12:35:21 am »
Hi HJK,
The baud rate is 115200, same is it is set in putty
Attached is the debug console and putty working with the same commands. ( I'm pretty sure i tried 9950ms and was the same result but will confirm)
If you have any ideas, I wonder if it is a setting related to the gpib.
Thanks.
Offline HKJ
    • Tests
« Reply #14 on: December 21, 2022, 09:47:35 am »
I have no idea why it fails, everything looks correct.
