Author Topic: Hickok 3410 Microvolt Multimeter  (Read 5571 times)
Offline radhazTopic starter
« on: August 28, 2016, 07:38:42 pm »
This is an early '70s 5 digit DMM. Observations about it's design and construction are welcome.  :-DMM
P8270398 by ryuuoh, on Flickr
P8270397 by ryuuoh, on Flickr
P8270396 by ryuuoh, on Flickr
P8270395 by ryuuoh, on Flickr
P8270394 by ryuuoh, on Flickr
P8270393 by ryuuoh, on Flickr
P8270392 by ryuuoh, on Flickr
P8270391 by ryuuoh, on Flickr
P8270389 by ryuuoh, on Flickr
P8270388 by ryuuoh, on Flickr
P8270387 by ryuuoh, on Flickr
P8270386 by ryuuoh, on Flickr
P8270384 by ryuuoh, on Flickr
P8270383 by ryuuoh, on Flickr
P8270382 by ryuuoh, on Flickr
P8270380 by ryuuoh, on Flickr
P8270378 by ryuuoh, on Flickr
The following users thanked this post: chickenHeadKnob
Offline Rbastler
  • Wörk Wörk
    • Rbastlers Blog
Re: Hickok 3410 Microvolt Multimeter
« Reply #1 on: August 28, 2016, 07:44:04 pm »
This is really awesome   ;D
And it has Nixies  ^-^ Does it work  and what is the reference ?
http://rbastlerblog.jimdo.com/
Gamma spectrometer works. Now some yellow crystals need regenerating and testing.
The following users thanked this post: radhaz
« Reply #2 on: August 28, 2016, 08:14:14 pm »
It works. It appears to be out on AC volts and AC/DC current. On DC voltage, it matches my in-cal Iwatsu 7602. I think that aluminum block with what looks like metal can diodes might be the reference.
« Last Edit: August 28, 2016, 08:24:50 pm by radhaz »
« Reply #3 on: August 29, 2016, 04:24:59 am »
For camera nuts, these pics were taken with an Olympus EM-1 with 60mm Macro and 12-40 Pro zoom, all hand held.
Offline Muxr
« Reply #4 on: August 29, 2016, 04:28:47 am »
That's a great system. I am still using my e-m5, love the 60mm macro. Beats the pants of my full frame 105mm Nikkor Macro lens.
Online Vgkid
« Reply #5 on: August 29, 2016, 06:29:01 am »
Thanks for the teardown. That AL block is very interesting, the datecodes are all over the place. From 74-78
Offline Cubdriver
  • Nixie addict
    • Photos of electronic gear
« Reply #6 on: August 29, 2016, 08:14:58 am »
Cool old meter and nice photos, especially impressive as you're hand holding.  What are you using as a light source?
-Pat
Offline Gyro
« Reply #7 on: August 29, 2016, 10:28:01 am »
That aluminium block looks a bit more like an optical chopper to me. Two LEDs and 2 phototransistors as part of a chopper stabilised amplifier.
Best Regards, Chris
« Reply #8 on: August 29, 2016, 05:16:26 pm »
Look at all those vanished companies that made the parts in there, almost all of those companies either no longer exist, or are part of another through mergers and such.
« Reply #9 on: August 29, 2016, 11:38:15 pm »
Lamps are a combo halogen desk lamp with a Chinese LED ring light attached and an Ikea goose neck table lamp.
-Pat
Offline Cubdriver
  • Nixie addict
« Reply #10 on: August 29, 2016, 11:44:50 pm »
Nicely done.  I normally use ambient lighting, a tripod, cable release and long exposures with the lens stopped down to about f/11 for decent DOF.
-Pat
« Reply #11 on: August 30, 2016, 12:11:06 am »
Hopefully the manual I ordered for the 3400 series meters will reveal the secrets. >:D
« Reply #12 on: September 03, 2016, 11:44:17 pm »
Got the manual yesterday. The aluminum block is indeed a chopper amplifier using CL9D6CS photo cells and OSL6-3 solid state lamps. The voltage reference is a 1N827A temperature compensated zener diode and LM201A opamp.
Offline Gyro
« Reply #13 on: September 04, 2016, 03:01:10 pm »
Ah, that's good - they used solid state rather than the flickery neons that HP used in their early opto choppers. I went over those photos with a fine tooth comb looking for a 1N82x, I still can't see it! :D
Best Regards, Chris
« Reply #14 on: September 04, 2016, 04:31:35 pm »
The 1N827 is near the three grey trim pots. Picture P8270386  has the best view if it.
Offline Gyro
« Reply #15 on: September 04, 2016, 07:17:41 pm »
Aha, yes, got it. The white body threw me.  :)
Best Regards, Chris
« Reply #16 on: September 29, 2017, 02:39:23 am »
Correction on the display technology, this is a VFD display multimeter. Sorry nixie fans. :palm:
Offline Whiteygabe
« Reply #17 on: June 14, 2018, 06:27:22 am »
Hi everyone,i need the squematic or the service manual
Thanks to all
Gabe
