Author Topic: ARCHIVE: HP 54621D Mainboard Pics  (Read 2566 times)
Offline mnementhTopic starter
« on: July 20, 2022, 01:37:18 am »
Just as the title says: Hi-res pics of the mainboard from my 54621D made while doing some diag work. Archived here in case they help someone else with one of this family of scope.
TOP
« Last Edit: July 20, 2022, 02:03:03 am by mnementh »
The following users thanked this post: coromonadalix, bd139, shakalnokturn
Re: ARCHIVE: HP 54621D Mainboard Pics
« Reply #1 on: July 20, 2022, 01:38:06 am »
BOTTOM
« Last Edit: July 20, 2022, 02:02:17 am by mnementh »
« Reply #2 on: July 20, 2022, 01:39:07 am »
Memory + IO Side of PCB
« Last Edit: July 20, 2022, 02:01:57 am by mnementh »
« Reply #3 on: July 20, 2022, 01:40:04 am »
Input & Acquisition Side of PCB; Frontend & MegaZoom FCBGAs
« Last Edit: July 20, 2022, 01:11:06 pm by mnementh »
« Reply #4 on: July 20, 2022, 01:40:57 am »
FRONTEND
« Last Edit: July 20, 2022, 01:59:58 am by mnementh »
« Reply #5 on: July 20, 2022, 01:42:18 am »
MegaZoom & MSO MegaZoom FCBGAs
« Last Edit: July 20, 2022, 01:11:26 pm by mnementh »
« Reply #6 on: July 20, 2022, 01:43:59 am »
J900, J400, J200 & J201 Mainboard Connections - J900 Bared
« Last Edit: July 20, 2022, 01:53:16 am by mnementh »
« Reply #7 on: July 20, 2022, 01:51:17 am »
Comparison of monitor cable pinouts of 54621D vs 54645A/54600A. This is the pinout of the J900 connector ribbon cable AT THE MONITOR.
This is Q960-Q961 in the video out to J900-Pin 11 on the 54621D. Q961 base goes to the Megazoom IC through a 50Ω resistor. Q960 Emitter goes to J900 pin 11. I'll update this post with more details as I continue this diag work.
UPDATE:
So this evening I decided to try and fake out one of my monitors to make it sync on this bastard VGA signal by building a pulse with my little PWM generator to mimic the duty cycle and amplitude of the orignal HSync from the 54621D, but at a frequency the monitor might actually try to display. Doubling that frequency got me to this point; good proof of concept but not enough granularity in the adjustment on my little $3 Chinesium generator to actually get it more legible than this.
By fiddling with the symmetry on my old ProTek analog function generator, I was able to get the duty cycle low enough that the monitor almost locked onto the signal; well, close enough to get these pics and see what it is actually saying.
Now that I know why this scope became a monitor PCB donor, I'm actually even more pissed off than I was before at those fucking g'rillas...  :rant:
« Last Edit: July 22, 2022, 02:44:52 pm by mnementh »
« Reply #8 on: July 20, 2022, 01:52:32 am »
These three pics were taken while I was investigating a replacement CDM-7SX191 monitor. I figured I'd add them here. If I have time, I may take more pics at different angles so a component list can be built.
So, while I'm working on this, I dismantle both the  CDM-7SX191 and CDM-7SF191 monitors; after comparing the two mainboards side by side til my eyes watered, I couldn't find any material difference between the two. While the layout appear different between the CDM-7SX191 and CDM-7SF191 mainboards, the component list appears the same.
Voltages at the ribbon cable also appeared comparable aside from those I expected to be different due to the VGA analog video, but I'd literally need to draw out the entire schematic for both monitors to be sure.I didn't have time or energy for that tonight, so I took one for the team and just swapped the CRT neck board over and tried it.
Franken-monitor is no joy; it is not possible to make a CDM-7SF191 serve as a CDM-7SX191 just by swapping the CRT neck PCB. :P
I'll update here as I have time.
 :-/O
« Last Edit: August 09, 2022, 01:38:15 am by mnementh »
« Reply #9 on: July 20, 2022, 01:53:55 am »
Okay, I'm done for now. ;)
 :-/O
« Last Edit: July 20, 2022, 02:09:08 am by mnementh »
The following users thanked this post: 1xrtt, coromonadalix
Offline shakalnokturn
« Reply #10 on: July 20, 2022, 11:55:47 pm »
Thanks for posting.
This answers one of my doubts on the L.A. side of the MSO: Inputs on pin #5 on 1NB4-5036's appear unused, can be handy when one logic input is dead...
Aren't you tempted to hack it up to 100MHz?
« Reply #11 on: July 21, 2022, 01:18:11 pm »
Ehhh.... my work thus far with this 54621D has been directed at trying to reverse engineer the video. This scope uses a CDM-7SX191 industrial monitor, which has been destroyed/parts robbed by gorilla abuse.
I have a backup/parts mule 54600A which uses a CDM-7SF191, which is all TTL. The CDM-7SX191 is TTL Sync with a single (probably some variant of VGA) analog video signal. At this point I'm convinced that the difference between the two monitors is entirely in the CRT neck board... so I am trying to reverse engineer that.
Any other hackage would come after that fundamental problem is resolved, though honestly, there is little motivation to go there, as I have a 54645A I'm perfectly happy with, the 54600A, and a just-acquired Teledyne/LeCroy T3DSO2102 to play with. If and when I go hacking, it will probably be to convince that scope that it is indeed a SDS2000X-series MSO.   :-DD
 :-/O
« Last Edit: August 04, 2022, 04:00:42 pm by mnementh »
« Reply #12 on: July 22, 2022, 08:59:16 am »
Ehhh....
and a just-acquired Teledyne/LeCroy T3DSO2102 to play with. If and when I go hacking, it will probably be to convince that scope that it is indeed a SDS2000-series MSO.   :-DD
 :-/O
:horse:
SDS2000X !
« Reply #13 on: July 22, 2022, 02:28:48 pm »
ouchies, mr sqweek...!
sorry... fixed now.
*whimper*
Offline TCPMeta
« Reply #14 on: August 05, 2024, 10:38:52 pm »
I know it's been a hot minute but any further progress been made with this?
