I'm in the process of recapping my ebay 2015THD and I was annoyed to find two extra capacitors C260 and C261 both 47uF 50V that aren't listed on the parts list of the repair manual.
On top of this, the nearby capacitor C146 turned out to be 2,200uF 16V whilst it is listed as 3,300uF 16V so I replaced it with the listed value (as that is what I'd ordered).
BUT - I just looked again at muvideo's teardown:
https://www.eevblog.com/forum/reviews/keithley-2015-teardown/msg114429/#msg114429and in the sixth photo down labelled
"Digital control, processor and firmware, divided in even and odd bytes:"
I see that on his instrument capacitors C260 and C261 are missing!
I guess this means they decided at some stage to do without them and perhaps, as a related move increased the size of 146 from 2,200 to 3,300 uF.
At the moment I'm planning to replace them as I've ordered the parts (last night) so it seems silly not to use them but it means that perhaps I'll be using an excessively large value for C146 but it shouldn't matter as it is only for smoothing the 5V supply.
My main problem at moment is trying to work out the correct size for replacement screws as almost all my screws are badly corroded - that and trying to clean some of the corrosion off the main case without leaving it in a condition where it rusts again immediately.
