Author Topic: Are there any hacks for Siglent 3303x-e power supply?  (Read 11967 times)
Offline n3mmrTopic starter
« on: February 17, 2019, 12:20:09 pm »
I thought I saw a mention of a hack for the FW of the Siglent 3303X-E power supply to enable 1mV set and readout accuracy, or at least 1mV resolution.
Does such a hack actually exist?
Re: Are there any hacks for Siglent 3303x-e power supply?
« Reply #2 on: February 17, 2019, 06:49:32 pm »
Sure does, tv84 linked it.  ;)
Even for the X-E model, 1mV and 1mA resolution is available within the EasyPower software.
Offline rolfdegen
    • Degenerator Synthesizer/Sampler
« Reply #3 on: March 11, 2020, 08:19:32 pm »
Hallo siglent users
I hacked my new Siglent SPD3303X-E in to SiglenSPD3303X . I am verry happy  :-+
Its verry easy:
First installed EasyPower from Siglent on my Win10 System
Then I install NI-VISA from National Instruments
Than start EasyPower
After that connect a LAN or USB cable
Press Connect symbol under Menu "File" and set in EasyPower 0.001V CH1 (press "Set)
Now press menu "Version"  > "Upgrade" > "Normal Mode" > "UpgradeFile" and load firmware file "SPD3303X-1.01.01.02.05_ConvertFromX-E" and press "Upgrade" and  wait a little bit to upgrade file (see a blue line on LCD screen to Siglent power supply). After this press ok and the Power Supply restart automatically.
It is very simple and nice. Thanks a lot  :-+
My Siglent SPD3303X-E with 1mV and 1mA
Greetings from germany. Rolf
Electronics developer
The following users thanked this post: boggis the cat, mawyatt
Offline boggis the cat
« Reply #4 on: July 13, 2020, 04:11:02 am »
Thank you for the instructions.  Worked fine on a new SPD3303X-E.
Offline MathWizard
« Reply #5 on: July 13, 2020, 08:21:25 am »
Yeah worked on my too. On a 500kcnt DMM, it tracks well. I have never really load tested it, at least not since I have the 1mV/1mA resolution.
It's pretty quiet, it's my 1st and only PSU, but compared to any wall powered device I've had on the scope, it looks very quiet, at low power anyways.
Offline Peter_O
« Reply #6 on: January 17, 2021, 07:04:44 pm »
Just did it with a 3303X-E, bought in December.
Works without problems.
PS answers correct S/N to "IDN?" on command line, leaving possible Siglent database entries or the front sticker mismatch. I can live with that.  :D
Thanks a lot guys!
Offline xmas111
    • johnsweather
« Reply #7 on: January 20, 2021, 12:23:33 pm »
Just did it with my 3303X-E too that I bought recently.
Working for me too but does anyone know how to get the "Set" and "Out" to read the same. Mine is off by 4 or 5 mv like in the picture 3 or 4 post above mine.
Thanks
« Last Edit: January 20, 2021, 02:54:46 pm by xmas111 »
Offline Tjuurko
« Reply #8 on: January 21, 2021, 04:09:19 am »
SPD3000X Series Service Manual
https://siglentna.com/download/14764/
Chapter 3  Calibration channel parameters
The following users thanked this post: tautech, AVGresponding, xmas111
Offline xmas111
    • johnsweather
« Reply #9 on: January 21, 2021, 08:18:15 am »
Thank you very much! :-+
The procedure might be a little over my head but I'm sure if I take my time I can do it.
Thanks again and I'll let everyone know how it goes.
Offline charliex
  • Car Hacker
« Reply #10 on: March 23, 2021, 06:56:36 pm »
just updated my X-E to an X. I think i went about it in a slightly different way to others (or i didn't see it being mentioned)
setup easypower and test connections
downloaded the SPD3303X_V1.01.01.02.07R2 firmware
it's easypower that decides if the firmware is the correct version for the device , so i ran it in the debugger, set a breakpoint at the check of the IDN? which is basically right before it says "This file does not match the device!" and set the IP to jump past the check ( swap the jz to a jnz) and continued the update.
0x0434B4D 0F BE 4D 0C                             movsx   ecx, [ebp+arg_4]
0x0434B51 3B C1                                   cmp     eax, ecx
0x0434B53 0F 84 A4 00 00 00                       jz      loc_434BFD              <<----- change this to jnz or just set the IP to the target location
0x0434B59 0F BE 55 0C                             movsx   edx, [ebp+arg_4]
0x0434B5D 83 FA FF                                cmp     edx, 0FFFFFFFFh
0x0434B60 0F 84 97 00 00 00                       jz      loc_434BFD
0x0434B66 6A 00                                   push    0
0x0434B68 6A 00                                   push    0
0x0434B6A 68 44 82 4F 00                          push    offset aThisFileDoesNo ; "This file does not match the device!"
no firmware mods were necessary.
IDN?
Technologies,SPD3303X,SPD3XIDD4R5442,1.01.01.02.07R2,V3.0
cheers,
charlie
The following users thanked this post: coromonadalix, kerouanton, kevin.memi
Online tv84
  • Country: pt
« Reply #11 on: March 23, 2021, 07:06:13 pm »
Interesting find.  :-+
In my proposal no software mods were necessary.  ;D
Offline charliex
  • Car Hacker
« Reply #12 on: March 23, 2021, 07:12:01 pm »
yep this needs no mods to any of the software, just the  flow.
also there are other models listed in there, so might work for others too that are similar situations. the actual firmware update is just a couple of commands and they send over the firmware chunk at a time via visa and UPGRADE1
« Last Edit: March 23, 2021, 07:41:17 pm by charliex »
Offline xmas111
    • johnsweather
« Reply #13 on: April 08, 2021, 11:36:28 am »
IDN?
cheers,
charlie
Using this method do the "set" and "Actual Output" number match up, or are they still off a bit?
Thanks
« Reply #14 on: April 08, 2021, 12:48:14 pm »
IDN?
cheers,
charlie
Thanks
Please study this thread:
https://www.eevblog.com/forum/testgear/how-to-calibrate-siglent-spd1000x-spd3303x-spd3303x-e-series-power-supplies/
Better still RTFM.  ;)
The following users thanked this post: xmas111
Offline kevin.memi
« Reply #15 on: July 11, 2021, 08:04:04 pm »
Thanks charliex!
Which debugger did you use? It seems there is another location where it checks and throws an error msg of "This file does not match the device!".
« Reply #16 on: July 12, 2021, 10:46:28 am »
Just scored an RS Pro rebranded one of these, it will be interesting to see if it can be firmware modded in the same way.
Online tv84
  • Country: pt
« Reply #17 on: July 12, 2021, 01:32:45 pm »
Thanks charliex!
Why not do msg #2?   :-//
Don't see why not...
The following users thanked this post: kevin.memi
« Reply #18 on: July 14, 2021, 02:21:38 pm »
Thanks charliex!
Seems it's not so simple. I get the error "Failed to GetUpdateMode". This includes when trying to install the normal X-E update.
Online tv84
  • Country: pt
« Reply #19 on: July 14, 2021, 02:43:43 pm »
Show me a FW file that you have been able to flash successfully.
« Reply #20 on: July 14, 2021, 03:35:27 pm »
How can I show you something that I don't have?   :-//
The RS user manual states that the file type required is a .ugf and makes no mention of .ADS which may well be the issue.
EDIT: It just worked...   :-//
I guess maybe the EasyPower software is a big buggy, it does hang a bit easily. It now thinks it's a Siglent and the serial number has changed.
« Last Edit: July 14, 2021, 04:11:52 pm by AVGresponding »
« Reply #21 on: July 14, 2021, 09:17:19 pm »
IIRC EasyPower accepts .ugf or ADS firmware files.
Some Siglent rebrands are reconfigured to only accept .ugf firmware.
« Reply #22 on: July 15, 2021, 09:39:27 am »
It was an .ADS file from tv84's .zip file in https://www.eevblog.com/forum/testgear/siglent-ads-firmware-file-format/msg1830584/#msg1830584 that worked, eventually.
The wasn't any difference in how I went about it from the other attempts, all I would say is I had to close the app a couple of times using the task manager when it hung.
The calibration does not appear to have been affected, it tracks perfectly (well within the combined specs) against my Keithley 2000 on both voltage and current.
Offline dschrier
« Reply #23 on: December 07, 2021, 08:28:00 pm »
I got an SPD3303X-E yesterday and converted it to the X version based on the posts in this thread. The updated back to the latest X firmware from the Siglent site. (1.01.01.02.07R2)
Interesting thing happened. The MAC address is now set to ff:ff:ff:ff:ff:ff and will not get a DHCP address any longer (of course). I can assign a static IP and everything works as expected.
Wondering if anyone has seen this.
Offline optotester
« Reply #24 on: January 20, 2022, 11:35:09 am »
I just unlocked using the check bypass method and I kept my MAC address/serial number so it seems safer. You do not need a debugger by the way. The exe is not compressed so you can directly edit it with an hex editor like HxD.
1 - Open EasyPower.exe with an hex editor and look for 0F BE 55 0C (there is only one occurence)
2 - Just before that occurence, replace 0F 84 A4 00 00 00 by 0F 85 A4 00 00 00
3 - Flash the firmware using the new "no check version" of EasyPower you just created
The following users thanked this post: KubaSO
